Thought I would post some pics of the newest build.And see if any one has additional ideas for me. Here is the case I am working with. http://img29.photobucket.com/albums/v87/diehrd/P2280829.jpg http://img29.photobucket.com/albums/v87/diehrd/P2280822.jpg I am going to water cool my Dual MP2000+ Oced to 2.16 so I did some fan holes for my Red LCD fans:And some bottom 80mm fans for more intake. http://img29.photobucket.com/albums/v87/diehrd/P2290833.jpg http://img29.photobucket.com/albums/v87/diehrd/P2290834.jpg I have started the paint:The inside will be white with Red Neon tubes and red coolant for the water cooling:UPDATED....... Paint is 99% done minor detailing left to do.Water cooling is on the way,Lighting,Red Ide cables,, All panels for Radiator and window are being cut,Red Led fans on way...Wire harness in progress for the redundant power supply. http://img29.photobucket.com/albums/v87/diehrd/P3110881.jpg http://img29.photobucket.com/albums/v87/diehrd/P3110880.jpg http://img29.photobucket.com/albums/v87/diehrd/P3110879.jpg The system will be what I am running now in an antech case: Giga-Byte dual AMD P series board. 2xmp2000+ at 2.167 9700 Pro All In Wonder at 350/350 1.5 gigs Kingston ram 2 raid0 arrays 2x30gig and 2x80gig 2 Ide Ata 133 60 gig drives 8Xdvd R/W-Cd/Rw DVD reader 16x Cd Burner 40x 500 watt FMI for main board and drives NEW ADDITIONS TO SYSTEM: 2 dedicated 300 watt supplies for fans and water coling system 2 Swiftech MCW500A water bolocks MCP600 Pump 12v Chevy Pro core radiator with 2x120 aluminum fans and shrouds.
I thought it was going to be a SavRow SR-71 case that was getting some mod lurving! I would love a server case, but i have no room lol 'doc
Murdoc What do you mean no room? You can always build one yourself, making it fit right under your bed or something diehrd I hoped you had a bit more information about the manufacturer of the case, because imo it's really sweet!
Im an 18 year old student, living with parents i have little room to put a huge case that my parents wouldnt get annoyed at. And thatt case is clearly to big to go under my bed. 'doc
I would love to.But there is no option to add atachments from what I saw so i added links which I am guessing I am not allowed to..Advice is welcome lol..
nice i like the case alot, this could be really good if you do it right . To integrate the images just put those urls in [ i m g ] [ / i m g ] tags (remove all the spaces their just there so the tags appear in my post). eg Edit: Bah to all you dialup users
Not when the images are that big you don't!!! As a rule of thumb, if the image is larger than 400 wide you link it!
Ok images ASIDE..Any Ideas for this case.I will really use them if they are good ones. I never moded a case before and really am open to suggestions.. On my own so far I have ordered: Red Ide cables. Red LED fans. Black wire wrap. Working on a Watercooling set up made by Swiftech with the 12v pump 2 water blocks, a rad with 120mm fans and shrouds,red color coolent.Red door lighting and red lighting in the main board area that I painted a brite white.I have a stainless steel PSU and 2 other PSU that will be dedicated to individual tasks.1 for Water cooling.1 for drives and fans and 1 solely for main board. I would love Ideas on what to color drive face plates,Also what to use to fill in the 28 bay's that I cannot possibly fill...Also some grapics for the case.... Thanks...........
Wow I'd love one of those cases sitting on the floor housing my machine!! Just one thing... Are they built to standard ATX specification or do you need to modify it in order for it to house a normal desktop PC? If not, I want one!! Where from, how much?
diehrd Maybe you could put cathodes behind the transparent front panel. That would be an easy start. Besides that, stuff some more windows in!!
I am going to use red cathoids for the front door and on the side where the mother board are with a window in that side panel...
Got some of the water cooling parts ! ! ! http://img29.photobucket.com/albums/v87/diehrd/P3120890.jpg http://img29.photobucket.com/albums/v87/diehrd/P3120895.jpg http://img29.photobucket.com/albums/v87/diehrd/P3120891.jpg http://img29.photobucket.com/albums/v87/diehrd/P3120894.jpg Should have more updates soon,This water system is going to rock lol..Also got my dual power supplies figured out and need to hit the shack for the fw parts I need........
