Project stacker832 mod. (Gamez convention Leipzig.) last update 20-05
Discussion in 'Project Logs' started by Ediejo, 11 May 2007.
  1. Ediejo
    Ediejo What's a Dremel?
    31 Jul 2005
    The stacker832 mod. Gamez convention Leipzig.
    Coolermaster Netherlands ask me to mod a stacker832 for the Gamez convention in Leipzig. It’s a great honour for me that CM asks me for that.
    Sponsors Stacker 832 mod.
    The planning.
    I try to give the bottom part Real flames
    At the inside I try to hide the most cables.
    Specs:
    Maiboard: MSI P35 Platinum
    Memory: OCZ Flex
    PSU: OCZ 1010
    First I must clean my modplace and than I start with this case. So the updates will come next week.
  2. Faried112
    Faried112 What's a Dremel?
    15 Jan 2007
    nice, ill watch this one, good luck!!
  3. TEAMIKKE
    TEAMIKKE What's a Dremel?
    8 May 2007
    Good luck! Although you don't need it ;)
  4. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    Subscribed ;)
  5. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Those kinds of flames are hard to get right, but they will look awesome on that case. I look forward to your progress! :D
  6. 330td
    330td Minimodder
    12 Aug 2004
    Suscribed
    these flames are very nice. Good luck for the paint job :)
  7. widmod
    widmod Minimodder
    9 Oct 2006
    fine to see you back with a new case so soon
    i really like your last mods :D
    will you do the flames-paintjob or will it be done by a specialist
  8. Ediejo
    31 Jul 2005
    Thanks for the good luck wishes. I need that because the flames are a really hard job and I try to do it by myself. :worried:
  9. Jeroenotje
    Jeroenotje What's a Dremel?
    10 Sep 2006
    I just can't wait :) . I thinks it's going to be another good Ediejo mod :), maybe even better then the last ones. We'll see.
  10. ottzen
    ottzen What's a Dremel?
    28 Nov 2006
    God, this is just the sexiest case i know...might be a reason why I got one :D
    Lookin forward to this!!
    (subscribed)
    //ottzen
  11. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Great paintwork if you can pull it off - have you seen the limited edition blue flame one that Coolermaster and Smooth Creations have just put together which is around $1000
  12. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    It is VERY, VERY hard, and I would highly recommend hiring a professional airbrusher to do the work for you.
    However, real flames have already been done on a Stacker 830/832 before - http://www.newegg.com/Product/Product.aspx?Item=N82E16811119126
    So, yeah. :/
  13. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    good luck with that paint job and the project
  14. Ediejo
    31 Jul 2005
  15. ShadowWings
    ShadowWings What's a Dremel?
    22 Jan 2006
    Your teacher does some very nice work (is he family???).
    As always with one of your projects "Subscribed"
  16. 330td
    330td Minimodder
    12 Aug 2004
    Yep i agree, look like he's got some skills :D
  17. Ediejo
    31 Jul 2005
    ShadowWings, no he is not family. But i know him for 25 years. And the last 2 years i follow his cruces.
    @330td, he's doing it for 24 years now. So when you have no skills after 24 years............. ;)
  18. Xlixen
    Xlixen What's a Dremel?
    16 Apr 2007
    Whoa, Should be really nice. Cant wait to see results :)
  19. _ferry_
    _ferry_ What's a Dremel?
    22 Apr 2004
    Knowing you you've might found a good way to create those flames. Anyway, i used this how-to to try it myself:
    http://airbrushtricks.com/forum/index.php?topic=4.0
    Might be helpful for your mod :) I was just trying it, but with the wrong paint, and little experience.
    I was thinking about modding a stacker 830/832 too, but it will be a different case. Good luck with this one.
  20. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    It's a bit off topic, but thanks for the link Ferry. I'm searching for all the information I can get about airbrushing.
