Case Mod - In Progress Project: Stainless Steel [Finished]
Discussion in 'Project Logs' started by EMF, 13 May 2015.
  1. EMF
    EMF What's a Dremel?
    9 Apr 2015
    Final shoots on first page
    Hope u like the end of build ;-)
  2. onevoicewild
    onevoicewild What's a Dremel?
    20 Dec 2014
    Incredible work, There were so many 900D that looked alike that it caused hatred from the villagers, You put the time into this to make an Unique piece of Art. The fill valve is a little odd though, If you turned it out the back of the case to a pass thru fitting, you could use a few fittings only attached when you are filling and then just put a plug on it during normal operation. I did this on my drain on my 900D. Beautiful Mate
  3. arg-ist
    arg-ist Minimodder
    21 Dec 2013
  4. MathModding
    MathModding What's a Dremel?
    23 May 2014
    Nice work, I voted for you for MOTM!
  5. EMF
    9 Apr 2015
    Tnks to all !!!
    I'm really happy to have won the MOTM with this build...see u next project
    :thumb:-C3r34L3-:thumb:
  6. EMF
    9 Apr 2015
    Tnks guy...i have mounted the drain valve in this way becouse the holes on the middle waterblock plate was a little bit disaligned. From the 3d prototype to the reality i missed 1 mm and the 2 tubes weren't perfectly stright....and here we are. :lol:
  7. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Work of art!
  8. Cheapskate
    13 May 2007
    I had to hunt down those final pics.:lol: She game out gorgeous.
