Modding Project Starwars Storm Troopers
Discussion in 'Modding' started by zulboy45, 28 Nov 2018.
  1. zulboy45
    zulboy45 Member
    17 May 2018
    I will update the worklog later. this is the final pic.
    the mod is only done for chassis and will be updated for internal component later.
    this mod is based on QBX chassis
    kim and Cheapskate like this.
  2. zulboy45
    zulboy45 Member
    17 May 2018
    found my pic broken. i repaired them
  3. zulboy45
    zulboy45 Member
    17 May 2018
    before proceed i would like to give credit for
    Psycholunatic Mod for doing the watercooling loop
    and
    Zamri (the owner of PC my client)
  4. zulboy45
    zulboy45 Member
    17 May 2018
    Meet My Galactic Empire Build ft Yoda's Lightsaber
    Specs
    Intel i7 8700k
    Mobo Asrock Z370 ITX Fatality
    RAM Patriot Viper 16gb DDR4 3200mhz RGB (8gbx2)
    GPU Nvidia GTX 1080ti Founder Edition
    Case Cougar QBX Star Wars Mod
    PSU Silverstone 650w Gold SFX
    SSD Intel 760p 256gb m.2 NVME
    SSHD 1Tb Seagate Firecuda
    Water Cooling Parts
    EK Velocity RGB CPU Water Block
    EK FC Geforce GTX FE RGB GPU Water Block
    EK FC GTX 1080ti Backplate
    EK Coolstream SE 240 Radiator
    EK Coolstream SE 120 Radiator
    EK X3 150 Standalone Reservoir
    EK Cryofuel Concentrate Acid Green
    Noctua NF-A12x15 Slim Fan
    DDC Pump with Plexi Top
    Barrow Filter
    Barrow Multilink Fitting
    Barrow 90deg Rotary Fitting
    Barrow 45deg Rotary Fitting
    Barrow 10mm Male to Female Extender
    Barrow 20mm Male to Female Extender
    Barrow 20mm Male to Male Rotary Fitting
    Barrow Mini Valve
    Barrow Stopper Fitting
    Acrylic Frosted Tube 12mm
    Custom aRGB LED Strip with Remote
    Thanks for Reading
    May The Force be With Master Race
    Play Hard Gaming Harder
  5. kim
    kim hardware addict
    10 Jan 2016
    nicely done...very cute little rig
    zulboy45 likes this.
  6. Cheapskate
    13 May 2007
    I agree. Really tidy.
  7. Landux
    Landux Member
    21 Jun 2019
    Nice rig, but what about your temperatures? 120/140mm fan for cooling GPU and CPU, it's that enough?
    Loving your rig!
