Case Mod - In Progress ⭐ Project "Stealth"Advanced Attack Drone (Thermaltake CaseMOD Invitational Season 2 2019)
Discussion in 'Project Logs' started by Y.G Casemod, 12 Sep 2019.
  1. Y.G Casemod
    Y.G Casemod Extreme modder
    8 Feb 2017
    Video worklog part 1.
    Here is the first of the 2 videos that contain the whole phase of making the custom parts of the mod.
    The second is soon to come.
    Make yourself comfortable and have a good vision.[​IMG][​IMG]
    Stay tuned.
    Worklogs on:
    https://community.thermaltake.com/index.php…
    https://www.nexthardware.com/…/91741-project-stealth-advanc…
    https://forums.bit-tech.net/index.php…
    https://www.overclock.net/…/1733164-project-stealth-advance…
    Thermaltake Technology Inc AMD ZOTAC ASRock Plextor
  2. Y.G Casemod
    8 Feb 2017
  3. Y.G Casemod
    8 Feb 2017
    Step 2.[​IMG]
    The painting phases begin.
    As anticipated at the beginning of the work, the mod will be painted entirely with the airbrush and weathering (a technique to achieve effects such as rust on the screws, gunpowder effect, etc.).
    As you can see from the first photo of the F18 Hornet, the paint is inspired by the aeronautical camo of the American navy, and you can see the various weathering effects there.
    The technique used is "Marble" on a black background and with two shades of gray, Sky Gray and Dark Sea Gray.
    After having carried out the perfect preparation of the surfaces with all that goes with it, with this technique you must balance the final color with various passages and fill every single space created with the Marble by blending the two shades of gray being very careful not to make mistakes with excesses of color, etc., on pain of having to do all the work again.
    In the end 2 hands of super opaque transparent Alclad 2.
    In particular, it is worth noting the finishing of the handmade engravings that was performed with specific oil colors for professional modeling.
    The end result is exactly what I wanted.
    Later we will enter into the heart of the painting with other very interesting details.
    Stay tuned.
    Worklogs on:
    https://community.thermaltake.com/index.php?/topic/89023-italy-yuri-gabrielli/
    https://www.nexthardware.com/forum/...ake-casemod-invitational-season-2-2019-a.html
    https://forums.bit-tech.net/index.p...ke-casemod-invitational-season-2-2019.366554/
    https://www.overclock.net/forum/180...ake-casemod-invitational-season-2-2019-a.html
    Dot_Kappa and Cheapskate like this.
  4. Y.G Casemod
    8 Feb 2017
    New sponsor package !!![​IMG]
    Also arrived the monstrous Pacific Core P5 DP-5 Plus RGB distro plate complete with D5 pump together with WaterRam RGB (liquid cooled kit) with 32 GB of 3200 MhZ !!!
    The distro is simply inhuman !!!![​IMG][​IMG][​IMG]
    Stay tuned.
    Worklogs on:
  5. Y.G Casemod
    8 Feb 2017
    Step 2 update.[​IMG]
    Painting of the rear closing panel.
    In these photos the various phases of the work.
    In detail we will be looking the weathering oil effect on the screw holes.
    The central logo will of course be backlit.
    Stay tuned.
    Worklogs on:
  6. Y.G Casemod
    8 Feb 2017
    Painting the supporting pistons of the case.
    In the photos all the processing phase.
    In the last photo the rubber support spacers under the 2 custom support bases (feet) of the case.
    Stay tuned.
    Worklogs on:
    Cheapskate likes this.
  7. Y.G Casemod
    8 Feb 2017
    Machine gun chassis and ammo box painting.
    In detail we can see the weathering.
    Also these parts will have backlighting and obviously the photos also refer to the mirror parts.
    In the assembly phase we will see other particular details.
    Stay tuned.
    Worklogs on:
  8. Y.G Casemod
    8 Feb 2017
    Final assembly of the monstrous Thermaltake Pacific CL 480 radiator in push / pull configuration with 120 mm Thermaltake Riing Trio fans, with the relative front side conveyors and the rear dynamic conveyor.
    In the photos we can see the details such as the cable management of the fans and the fittings in the lower part of the radiator to empty the system when maintenance is needed.
    Stay tuned.
    Worklogs on
  9. Y.G Casemod
    8 Feb 2017
    Painting and assembly of the 2 Vulkan T2 heavy machine guns.
    Painting and final assembly of the central body cover at the base of the case.
    In the photos all the processing steps.
    In detail, the very complex painting of all machine gun parts which was certainly not a walk and in particular the chrome rods with gunpowder effect and heat wear.
    Stay tuned.
    Worklogs on:
  10. Y.G Casemod
    8 Feb 2017
    In these photos we will see the final assembly of the machine guns.
    In detail one of the 2 open machine guns where you can see the wiring of the ARGB LEDs in the expansion chamber (simulation).
    In the machine body (simulation) an aluminum u-shaped section was positioned as a led port for backlighting.
    Stay tuned.
    Worklogs on:
  11. Y.G Casemod
    8 Feb 2017
    Caliber 50 bullets tapes (simulation)
    In these photos we will see the finished ammunition tape mounted on the machine guns along with the whole process of painting of the bullets and the hand finishing with metallic pigment of the tapes.
    Very complicated job that took a very long time
    Stay tuned.
    Worklogs on:
  12. Cheapskate
    13 May 2007
    I always enjoy your paint work. :D
    (I still want to see you do a polished clear plexi rig, though.)
    Y.G Casemod likes this.
  13. Y.G Casemod
    8 Feb 2017
    As soon as the opportunity presents itself, it will be done.:D;)
  14. Y.G Casemod
    8 Feb 2017
    PSU cover and left and right side deflectors.
    In these photos we will see the definitive assembly of the cover for the psu with upper plate in polished plexy to display the illumination of the upper logo of the Thermaltake PF1 ARGB.
    Obviously the cover will be backlit in the upper front part and also where there is the main logo, the skull with the sickle.
    We will also see the 4 right and left deflectors finished with airbrushing, engravings and weathering.
    Stay tuned.
    Worklogs on:
  15. Y.G Casemod
    8 Feb 2017
    Step 2 update.:cool:
    Work is progressing and the conclusion is approaching.
    In these photos we will see the complete assembly of the ASRock X570 Steel Legend motherboard with the Ryzen 5 3400 G, the Thermaltake W4 Plus water block, the WaterRams, the NVME PCI-E Plextor M9PE RGB SSD and the tubing.
    We will also see custom sleeving with a few clicks of the editing procedure (the cables of the video card we will see in the next post).
    In particular, the Thermaltake Pacific TF1 liquid flow and temperature sensor.
    Stay tuned.
    Worklogs on:
  16. Y.G Casemod
    8 Feb 2017
    Step 2 last update.[​IMG][​IMG]
    Last update regarding step 2.
    Soon another 2 videos of the second step.
    We are almost at the end of the work.
    In these photos we will see the beautiful Zotac RTX 2080 AMP with the custom RGB backplate customized in theme with the mod.
    Stay tuned.
    Worklogs on:
  17. Y.G Casemod
    8 Feb 2017
    Welcome back guys.
    Movie time.[​IMG][​IMG]
    Video worklog step 2 part 1.
    As promised a few days ago after the 2 videos of the step 1, here is also the first of the 2 of step 2, where we will see all phases of construction and painting of the custom parts of the mod.
    The second is also very short.
    Stay tuned
    Worklogs on:
  18. Y.G Casemod
    8 Feb 2017
    Video worklog step 2 part 2.
    Here is also the second video of step 2.
    The mod is officially over and I refer you to the photos and the final video that will be released within December 20th last day and deadlines for the modders in competition to finish the works and all the posts for the contest as per regulation.
    The actual deadline of the contest is set for December 23rd, while the voting will be officially launched on December 21st with a video presentation by Thermaltake Technology Inc.
    Stay tuned.
    Worklogs on
  19. Y.G Casemod
    8 Feb 2017
    Welcome back guys. [​IMG][​IMG]
    End of works.
    And here we are at the end of the works.
    Here is the final video in 4 K , the complete photobook in Hi Res and the technical datasheet of this extreme mod.
    What to say, a very demanding adventure given the great importance of this competition and the very high level of the contenders.
    Even from a strictly technical / practical point of view as regards the realization of this extremely complicated and difficult mod in all its many details, it has been very very demanding.
    Now the final verdict of the jury is expected.
    A very special thank to Thermaltake Technology Inc. and to all the sponsors of this great event for having supported me and given this great opportunity.
    Special thanks to Francesco Morgantini (Kernan) for the realization of the extraordinary final video and for the equally extraordinary photos that he performed.
    Below the link to his Youtube channel:
    https://www.youtube.com/channel/UC4NxRIlCBRI-jDPwpyyZJaQ
    Make yourself comfortable and have a good vision. [​IMG][​IMG]
    Stay tuned.
    Worklogs on:
    Thanks to all for following me. https://www.facebook.com/Y.GabrielliCasemod/
  20. Cristianodanna mod
    Cristianodanna mod Member
    16 Dec 2016
    Awesome work buddy
