Scratch Build – In Progress Project Stealthlow - Completed - preview of project next
Discussion in 'Project Logs' started by Waynio, 30 Nov 2010.
  1. The boy 4rm oz
    10 Apr 2008
    The attention to detail on those fans is amazing Wayne.
  2. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    I am so amazed by this worklog that there is nothing left to say except from this : :jawdrop:
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    :D Cheers Nutman, Shouldn't be unbalanced I hope :D, all same size & placed directly in the middle & that's mostly why I put the copper ones down first with it being heavier so the weight should be distributed nicely I'm more worried about them staying in place :D they have been curing over night but they popped off easily so I just cleaned them up & stuck them on with a epoxy resin so currently waiting for that to set :).
    :D Cheers Jase :thumb:.
    Thanks Alex :) honestly the ssd cover looks sweet in it's place & should look even sweeter when I put the mirror floor back in :D.
    Flipped the case on it's back & stuck the eject button & optical tray in place :) something that needs to be done while it's in the case so it aligns properly, should have got that part done last night really if I want this done by the end of today, I won't be able to do anything on the case until the tray & eject eject button have set & since it's 4pm now I think it's gonna be a late night for me & I'll be quite amazed if I do get this finished today :D.
  4. djzic
    djzic Bokehlicious!
    8 Nov 2010
    GO GO GO :D
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    :D Cheers mate I found 1 of the fans corner tabs broke so I got some epoxy resin on it & put a weight on it, should fix it :).
    Ejecting working correctly :) had a tiny bit more filing to be done.
    Nutman likes this.
  6. bulldogjeff
    2 Mar 2010
    That is looking so dam good Wayne...surely you must be close to finishing it now.
  7. Kurze
    Kurze New Member
    18 Aug 2011
    This is looking absolutely astounding. Those fan mods alone are fantastic, can't wait to see the finished article. Though judging by the length of this project you probably can't wait to see it finished either!
  8. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Wayne that looks amazing!
  9. KidMod-Southpaw
    28 Sep 2010
    Really. What's left to say Wayne? Even the very first update was totally amazing to me, it's at heart attack level now.
  10. Razer2007
    18 Jul 2010
    So what gonna be on the hardware modding list?
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    Thanks Jeff :thumb: it is very very close to finished I'm still aiming to have it all done today or the early hours tomorrow :D, the most tricky bit left which isn't tricky is working out where I want the extra cable holders & then drilling & tapping & placing helicoils in them.
    :D Cheers Razer :thumb:.
    :hehe: Cheers mate :).
    I haven't really thought about modding any hardware other than the cover for the ssd & the psu cables but warranty is still intact on both :D, said laters to the warranty on the fans though :D, modded hardware fetches a bad price when it comes to upgrading so is something I rely on heavily to soften the blow of cost for new tech :D.
  12. stonedsurd
    11 Mar 2009
    I want to make babies with that thing.
  13. Waynio
    Waynio Relaxing
    20 Aug 2009
    :lol:
    I found again the acrylic adhesive is ONLY for acrylic :hehe::duh: so had to re-stick the alu discs on the backs of the fans again.
    I marked & drilled, tapped & added helicoils for the copper wire holders & the the joints where the extention is I will make a bar to act as a clamp to hold the connector to the mobo panel.
    Currently waiting for the epoxy resin to set well but I'm still determined to get this done tonight :lol:.
  14. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    You madman!
    Here, have some rep. :thumb:
  15. Attila
    Attila still thinking....
    22 Feb 2008
    Awesome Wayne. :thumb: The drive cover looks great, and those three photos? Very tasty.
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    :hehe: Cheers Nutman :thumb:.
    :D Thank you Attila :).
    Last fabrication update I think :D depends on how the sata data cables are if they need a clamp piece adding to keep them tidy or not.
    So I added all the required mounting holes to the mobo tray to support the cable holders.
    I also decided to make a cable clamp holder also, I added the mounting holes for this before making the part & took the cable to be clamped & took measurements off it with the digital callipers & got to it on sketchup to design & print the needed piece complete with cut/bend lines & excess length so it could be trimmed down & rounded, couldn't be bothered setting up my basic bending brake & just did a quick setup with plywood & the vice & manual pressing which is easily doable when material isn't very wide.
    Held the piece where I wanted the piece to be & marked where the mounting holes are & then drilled the holes in the new piece, needed an accurate drilling with me not being able to clamp this down so the drill press came in handy as it sometimes does :).
    All done for this piece & all the mounting holes & that's all for the fabrication of this project, now it's just the power/hdd activity switch wiring & a molex cable & installing the lighting :).
    So might not have completed the project yet thanks to me using the wrong adhesive for quite a few parts & having to re-stick them with epoxy resin but all the challenging stuff & slightly challenging stuff is done I'd say :D. Hmmm actually I have a mass of cabling to pretty up :lol::duh: & it has to be done with windows being on both sides :lol: it's the sata data cables I'm unsure about looking tidy but if they are a nightmare I could make a couple of clamps like I did for the 24 pin extension.
  17. LooseNeutral
    LooseNeutral New Member
    13 May 2010
    outstanding :D you're getting crazy with the Hell saw I see. :p (btw love the pict of Marty lol) I'm sure you'll come up with something interesting for you wiring as well. This has really turned into a masterpiece my friend.
  18. Korvus
    Korvus May contain traces of sanity.
    14 Apr 2011
    Looking more and more amazing as this progresses :D. And very shiny :eek:
  19. Nutman
    21 Oct 2008
    When will this one go into production? ;)
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    :D Yea that scroll saw is such an awesome cutting tool :D thank you Loose :).
    For the wire tidying I'm currently only planning on the ? clips & the clamp bit I made so depends on how messy it all is from the sata data cables if I make something else, I could make pretty simple tasty casing for it all which removes as 1 piece for access to the cables but with it being nice sleeving I'd need to add some windows for the casing :lol: & I think I'm crazy enough to do that now I've seen it in my mind :D this could extend the log for another week or 2, you guys with your expecting something more & then me thinking something more :wallbash::lol::D the finish line just got pulled further into the distance (if I do go for it ;)) :lol: if I don't go for it I could be installing hardware today ;), decisions :waah::lol:.
    :D Thanks Tech_Jakl :).
    If I had the money to form a little factory right after completing this :lol::D.
    Done the power swtich hdd activity cable & right this moment making the molex cable which is almost done but I do still need some good strong double sided tape, the tape of the gawds I have doesn't seem to be good at holding stuff upside down so need something stronger I think.
