Case Mod - In Progress Project: SteamTurbine PC
Discussion in 'Project Logs' started by Gur_man, 21 Oct 2010.
  1. Mach
    Mach What's a Dremel?
    30 Jul 2008
    Very nice work Gur_man! Love the matchstick photo, really shows the scale.
  2. Nexxo
    23 Oct 2001
  3. ToB1
    ToB1 What's a Dremel?
    18 May 2010
    Looking good so far!
  4. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    Love it! Great work there. To me it's a mix of Steampunk meets Bioshock :D SUB'D :rock:
  5. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    pure win!!!!!
  6. Gur_man
    Gur_man What's a Dremel?
    12 Dec 2009
    Thanks guys! :)
    No, may be it looks like a mix of Steampunk and Bioshock but I never played this game. :)
  7. Gur_man
    12 Dec 2009
    Continuation:Have made a blowhole from some aluminium cover.
    The center was then cut out and the paint cleaned off
    After cleaning I have painted it's back side.
    Then made the blowhole fixators and put everything together:
    Still hot. :D
    Afterwards, I have varnished it. (Four layers)
    :dremel:
    Kilmoor likes this.
  8. LooseNeutral
    13 May 2010
    FREAK'n Awesome! :D Copper + work is beautiful!
  9. Von Lazuli
    Von Lazuli I get by fine with a jig-saw.
    23 Oct 2008
    Did you copper plate those screws? Or are they actually just brass screws to begin with?
  10. Gur_man
    12 Dec 2009
    These are just brass screw-bolts. I polished them with a drill.
    LooseNeutral, thanks! :)
  11. Gur_man
    12 Dec 2009
    Now about the reservoir;
    As I said, aluminium will not have contact with water.
    these two pipes were soldered together
    (Air out valve)
    Have sealed all with the sealant and epoxy glue.
    Then I found the water thermometer and set it into the reservoir. :D
    Have made the lattice and varnished it.
    The reservoir was painted and varnished two.
    :dremel:
  12. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    thats to cool for school...
  13. WolfandAngel
    WolfandAngel Got fins?
    2 Dec 2008
    love it, kind of looks like those old lamps in basements.
    wolfie
  14. Mat-O
    Mat-O What's a Dremel?
    14 Nov 2010
    What an awesome build! I look forward to seeing the rest of it!
  15. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    That's really a nice looking reservoir, and the blowhole is hot. Mod on.
  16. GCOFIELDD
    GCOFIELDD Minimodder
    10 Oct 2010
    Holy crap man, I really like the work you are doing!
  17. wahoomcdaniel
    wahoomcdaniel What's a Dremel?
    14 Nov 2003
    Absolutely awesome! Your build is getting better with each new update. I'm really enjoying your work.
  18. lobster_johnson
    lobster_johnson Fear the Claw of Justice!
    30 Sep 2008
    This is a really fun build so far. Especially looking at where the case started!
    I really like the leather trim on the radiator. Reminds me of a couch my parents had in the 80's. :D
    _____________
    -Lobster
  19. Cheapskate
    13 May 2007
  20. LooseNeutral
    13 May 2010
    Now your freaking me out! :jawdrop: + :rock: + :clap: + :hip:
