Case Mod - In Progress Project: SteamTurbine PC
Discussion in 'Project Logs' started by Gur_man, 21 Oct 2010.
  1. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    WOOOOOOW!!! You´re a genious!! Great design and fine craftmanship... This is one of a few steampunk projects that I accutally find really interesting. Most of the steam mods out there are just gearwheels clymsy glued onto a painted chassis. This one rocks!!! Looove the dial!
  2. Sarakon
    Sarakon The German
    11 Feb 2011
    Very very nice :D The attention to detail is Awesome!!
  3. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Very cool idea with the resin :thumb:
    Keep it up
  4. GLA-58
    GLA-58 What's a Dremel?
    1 Sep 2011
    :clap: this dial thangamaging is absolute friggin' awesome :clap:
  5. Gur_man
    Gur_man What's a Dremel?
    12 Dec 2009
    Thanks to everybody for your warm comments! It even gives me more inspiration to carry on with my project! :)
  6. Gur_man
    12 Dec 2009
    Now I want to show a little bit the work with a front panel.
    The button Start will be situated in the centre of the decorative lattice.
    As you know that chrome is not acceptable in steampunk I decided to clean it off.
    After cleaning I covered it with 6 layers of vanish and cut out the frame of lattice.
    Then I made the main part of the front panel.
    Then I did sanding, drilling, sawing, and connected everything together.
    The work with a front panel is to be continued...
    Here is one of the main part of this mod - THE TURBINE!
    As the blue backlight and low fan speed didn't satisfied me I desided to replace the blades onto different fan and make new backlight.
    The replacement turned out well and everything works!
    The backlight;
    That's how the TURBINE looks like with a blowhole.
    Hopefully to see you soon! :dremel:
  7. AK71
    AK71 What's a Dremel?
    29 Jul 2011
    Very nice so far! I love steampunk and this is showing a lot of original ideas. I also can't remember how long ago I saw a motherboard like in the early pictures, slot mount CPU and ISA slots!!
  8. NoobNeb
    NoobNeb Enthusiastic Lurker
    14 Nov 2011
    This a super duper fantastic amazing mind-blowing mod :jawdrop:
  9. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    Holy **** that looks awesome! :jawdrop:
  10. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    It looks really good... The turbine and button panel looks perfect. I don´t know what I think about those organic plates(copperplates?) but that´s just my taste. Keep on punkin'!
  11. Xye
    Xye What's a Dremel?
    21 Nov 2010
    I'm intrigued by the indicator does the needle actually move when the HDD is active?
  12. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    hdd led pinout on MB send aprox. 3-3.5v (AFAIK) when hdd active so replacing led with simple analog voltmeter (5-10v max) are easiest way adding some "tech" style :) and getting "old" (from 60's) voltmeter is direct way to steampunk or retrofuturistic mod ;)
  13. Korvus
    Korvus May contain traces of sanity.
    14 Apr 2011
    I'm liking this. Very steampunk. Nice alternative to the "crisp clean" look too. :D Keep it up!
  14. Knighthammer
    Knighthammer What's a Dremel?
    18 Feb 2011
    Subb'n to this build for sure! Keep up the outstanding work.
  15. KidMod-Southpaw
    28 Sep 2010
    LOVE STEAMPUNK.
    I want this case! Love it!
  16. bulldogjeff
    2 Mar 2010
    This just looks so good.
  17. Waynio
    Waynio Relaxing
    20 Aug 2009
    Soooo tasty :D:rock:.
  18. PR1ME
    PR1ME More ideas than talent or money.
    5 Dec 2010
    AWESOME stuff in here. Sub'd for sure!
  19. MrBean
    MrBean Minimodder
    21 Apr 2004
    Beautiful work, old-style modding just can't be beaten.
    Creativity at it's best.
    Kiitos hyvin paljon, you're an inspiration.
    I see your case is from Valkeakoski- do you live there? But, anyway, coming from an Industrial background, more specifically a 6x 630MW Power Station, I am really enjoying this :)
  20. Gur_man
    12 Dec 2009
    Thank you to everybody for the uplifting comments!
    MrBean, I don't live in Finland. I simply found the case in the garage and the print of Valkeakoski was on the frontpanel.
    Xye, yes, the needle will move then the HDD is active.
