Case Mod - In Progress Project: SteamTurbine PC
Discussion in 'Project Logs' started by Gur_man, 21 Oct 2010.
  1. Gur_man
    Gur_man What's a Dremel?
    12 Dec 2009
    A bit of update here
    The reset button:
    (Without description this time)
    Polishing and varnishing will be later.
  2. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    WOW! this is fantastic work! :D + :clap: + :rock:
    I didn't know if i just missed it, what does the inner dial do/show? (the small one)
  3. Gur_man
    12 Dec 2009
    kelmannen, thanks mate! I have not decided yet, so far, the two dials work together.
  4. subby
    subby Me...just like you...only better
    5 May 2009
    Just had to jump in to say that your build is sensational :rock:
    If I could, I'd nominate it and you, for mod of the month and mod of the year. Brilliant use of materials and all built yourself too. You take modding to a new level. Well done! :clap:
  5. Gur_man
    12 Dec 2009
    subby, Thank you! :blush: :)
  6. Gur_man
    12 Dec 2009
    Some hardware for this project here.
    My assistant;
    :D
  7. Gur_man
    12 Dec 2009
    The POWER LED;
    In one of awesome project I saw a good idea to use the brass pipe nut and PIR sensor.
    I made a triple PWRLED with sound activation, and it will glow at half brightness and pulse with the bass.
    This is a very simple scheme which has two parts: a microphone amplifier and three transistor keys.
    Finally, I painted all the wooden parts with wood stain, and then applied four layers of marine varnish.
    :dremel:
    Waynio likes this.
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    Pet pictures in project logs don't get any better than that. :D
    Very nice work mate, keep it up. :rock: rep + stars if I haven't already :D
  9. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    I knew it, brass balls. You may continue now :)
  10. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Mmm... looking good!
  11. spigs_rex
    spigs_rex Minimodder
    1 Oct 2010
    wow that is fantastic!! the dial looks brill,
  12. jhanlon303
    7 Sep 2006
  13. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    Vägev :jawdrop:
  14. dream1
    26 Feb 2011
    Well i must say this is very good looking stuff over there nice work :D
  15. Gur_man
    12 Dec 2009
    Furball Zen, :D
    quizz_kid, spigs_rex, jhanlon303, dream1, thank you.:)
    Thank you very much! :)
  16. Gur_man
    12 Dec 2009
    Some of my soldering works;
    These are old photos. One day I found a piece of copper and decided to make another water-block.
    "Copper barbeque"
    This "barbequed" piece of copper was made flat with a help of two wooden planks and few hits with sledgehammer.
    Then I cleaned it with a bench grinder, cut it and sanded again.
    Then I drilled the base and made ​​the needles from 4mm wire.
    Then the needles were tinned and pressed into the base with a hammer.
    Afterwards I put it on a gas cooker.
    After soldering I cleaned it up.
    I also tried to make the cover but this time I failed. May be next time I will make a new one.
    I also made the filler neck, through which I will add water to the system.
    Until the next post. :dremel:
    Waynio likes this.
  17. k4p84
    k4p84 What's a Dremel?
    20 Aug 2008
    Wow, very nice work here. Those buttons a few pages back are great.
    Keep it up and lots more pictures plz :)
  18. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Nice. Good job. :)
  19. Waynio
    Waynio Relaxing
    20 Aug 2009
    Very tasty stuff :):dremel::clap:
    Beautiful transformation of a piece of scrap copper. rep :)
  20. Gur_man
    12 Dec 2009
    Waynio, Pranja, k4p84, thanks.:)
    Continuation:
    I put a new thread onto all tapered fittings, and after that two water-blocks were assembled and tested under the pressure of 5 bar.
    (Sorry for the picture quality.)
    Then I cut out the plate from 3,5mm duralium in the shape of a gear; painted it, decorated with special effects and vanished it.
    When I completed the assembly of water-blocks I decided to test the water-cooling system, using the old hardware as the new one is in another case.
    For the moment it's not the final stage of the project. All pipes and wires will be fixed and hidden.
    For now I will be working on the front panel and other parts of the computer.
    Sarakon and Jaybles like this.
