Project Steelbox (Status: Completed)
Discussion in 'Project Logs' started by alvin_goh, 19 Jun 2004.
  1. alvin_goh
    alvin_goh What's a Dremel?
    2 Nov 2003
    Ello, this project involves integrating and running a complete computer system into a custom made box.
    I want to clarify that the box was not built by me, i do not posess any l337 welding skills at all :)
    1st out, the overall look of the box. Pretty ghetto looking.
    Theres a keylock and latch on the door
    Door Open
    The Stand
    Mobo Plate
    The innards:
    40GB WD HDD
    Gigabyte Matx Mobo:
    1U Low Profile Copper HSF on Athlon XP 2200+
    Kingston Value Ram
    HEC 250W True Power PSU(no pic yet)
    Finalized layout would look something like this
    If all goes well, my design and changes will be mass produced and put into usage in approximately 150 vessels around da world.. :)
    Ok started working on it at 1030AM. Worked on the removable mobo tray first. This is what i had to do to the tray
    Clamped an old mobo tray onto it, you can see my respirator in the pic :)
    After roughly 20 mins, we have this
    Motherboard risers
    Mounted onto the tray
    Moving on to the blowhole, which was a super biatch to cut.
    Note that the material used was 1.5mm Stainless Steel.
    Initially i used my holesaw on the 1st blowhole, but after 10 minutes of drilling, realized my holesaw had become botak already~ damn... so i had to do it the manual way, with some good ol' dremelling action.
    After 2 hrs.... yeap.. about 1 hr for each blowhole..... used 4 reinforced discs.. i finally got it done, drilled the fanholes and attached the fan
    Final step involved assembling the entire case and shoving everything into the box.
    A look inside~ damn messy~! no time to clear up the cables as my client was waiting at the front
  2. nicke
    nicke What's a Dremel?
    17 Jun 2004
    nice dude :thumb:
    keep up the great job :rock: :rock:
  3. R@Mo
    R@Mo What's a Dremel?
    14 May 2004
    I'll definately be making my own case for my next project. That is just too cool. :cooldude:
  4. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    Very nice :)
  5. alvin_goh
    2 Nov 2003
    thanks for all the positive comments~ really appreciate it dudes~
  6. toss
    toss What's a Dremel?
    6 Jun 2004
    **** thats nice dude gw cant wait to see more of your mods
  7. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    cool work dude
