Scratch Build – In Progress Project: Sting
Discussion in 'Project Logs' started by Frenkie, 20 Aug 2008.
  1. Frenkie
    Frenkie Lets mod the world!
    3 Jul 2006
    A caseconstruction based on a mini-itx mobo.
    This time I went for a small case-construction. Especially after I made the BFG
    this time I wanted more contrast in my mod collection. Small mini-itx hardware is
    much easier to build in larger boxes, boxes or suitcases, but a
    entirely new custom case like this I've never seen.(yet)
    The hardware.
    This time I have a VIA EPIA ML5000EA motherboard, 17 x 17 cm.
    Everything is there and, video, 6 channel audio, 100 mbit lan and a passive cooled
    533 MHz CPU.
    Also, I have a slot-in DVD player, it comes with an adaptor for the mobo.
    Then the HDD. First, I had a 40 GB 2.5 " laptop hard drive with an adaptor ....
    ... but I've found something much more fun.
    A SSD of a simple CF card.
    A 2Gb CF card, and the adapter comes (where else) from Hong Kong.
    Together with its passively cooled CPU and SSD he is 100% silent.
    By comparison, a picture with a standard 3.5 "HDD, a 2.5" HDD and the
    new SSD.
    Oh yes, and for comparison, this was a few years ago the 10 Megabyte Winchester
    disk ....
    SketchUp.
    My design is based on the general shape of a Scorpion.
    Judging from the minimum sizes of the hardware (mobo, powersupply and slot-in
    DVD player) I started playing with SketchUp.
    I even have a photo taken of the motherboard and all hardware components and
    in SketchUp used as texture. Can I recommend to everyone, looks much more
    realistic.
    A body ...
    a tail ...
    and two arms with slicers/dicers.
    I have long sought materials for the case, and I've found something unique.
    You know a lot of PCs are built from old motherboards, well, I found
    industrial circuitboards that have not yet been finished.
    Beautiful dark green circuit boards, completely flat and clean.
    An additional bonus was found only afterwards, when you are slightly behind / under apparently let the print in some places the root printbanen.
    A very nice effect, I think.
    As I used it with my R2-D2, I used UV responsive gel pens again.
    Now my green pens bought them for this mod to be deployed, but my first
    experimental did not gave me the effect what I thought of it.
    The Case.
    As a basis, I have taken an aluminum plate of 1.5 mm thick.
    The measurements taken from SketchUp and drawn.
    Converted to the minimum height of the backplate.
    Ontopic, see my latest toy, a Ferm figuresaw I got from the flea market (cost 12 euros).
    And a new sander of Rexxon.
    Finishing is ofcourse still needed with needle files for finishing touch.
    The hole cut for the backplate.
    And then the sawn boards to the desired sizes.
    Even a quick mock-up with adhesive tape.
    And now I show you how it looks with light behind it.
    For the assembly of printed circuit to the aluminum chassis I used
    brackets of the same aluminum and popnagels.(rivets?)
    For the tail, I got some perforated aluminum strip.
    Like it so far?
  2. Gott-Maschine
    Gott-Maschine I overheated my dremel and it died.
    16 Aug 2008
    Looking good, I like it a lot. Neat idea, using the circuit boards for the case.
  3. k4p84
    k4p84 What's a Dremel?
    20 Aug 2008
    I like the look of this, with light shining through it it looks really good.
    ED
  4. .Fatality.
    .Fatality. What's a Dremel?
    10 Jul 2008
    owerkill!
  5. wbdog206
    wbdog206 not me
    15 Jan 2007
    that looks pretty good using the circuit boards like that.
  6. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    I likey:) those circuitboards really do look awesome:p
  7. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    love it! get some good lighting in there mate!
    You could even hide the power button on one of the PCB's by using a PCB mount button.
  8. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    love it! if it turns out like your design it will be one awesome mod :thumb:
    josh
  9. Frenkie
    3 Jul 2006
    ooooh, great idea dude! credits 2 U ! :)
  10. Cheapskate
    13 May 2007
    Neat use of pcb boards. The look is awesome. I'd make the power switch the stinger on the tail.
  11. Frenkie
    3 Jul 2006
    I have something special planned for that :) You're gonna love that even more :)
    The standard wires from the pico power supply are way too long.
    Because the powersupply is right beneath the mobo, a forest of wires is stucking out above it, and we dont want that now, do we?
    With some creative cutting and new connectors that piece is now tailored.
    The IDE cable that comes with the mobo is also standard way too long.
    This looks much better already.
    So it looks a little better already.
    Some connectors for the powerLED, HD-LED, reset and power switch, got them from old PCs, very handy to have laying around.
    The tail-backbone, I gave it some small nudges, in a logaritmic form.
    With some tape, I tried to imagine if my idea is going the right way.
    It sort-off has to resemble scales of a snake/fish. like. ish. :lol:
    Please note: this is only one side, the tail had three sides.
    The plates for one side of the tail
    And for both sides.
  12. Rozzy
    Rozzy I'll get there :P
    1 May 2008
    looks like this is going to be quite a work of art :) good luck
  13. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    I already know how it continues, lol ;) Good to see this one here to Frenk :)
  14. AFX
    AFX "Bling" Silver Mountain 2
    19 Sep 2006
    Sweet case!
  15. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    Very cool concept! Liking it a lot so far.
  16. cheezeit
    cheezeit What's a Dremel?
    29 Aug 2007
    Wow, that is some creative use of pcbs. Would love to see how this turns out :)
  17. JBLPL
    JBLPL What's a Dremel?
    5 Mar 2008
    *Subscribed*!!!
  18. Frenkie
    3 Jul 2006
    Thanx guys, much appriciated.
    Got a batch of defect computer hardware from Computer Service Maastricht, I guess recycling is a good thing, right?
    Disassembled the harddrives.
    To give the case a bit more depth, I cut a large hole in the top panel.
    And an overlapping panel that is just a bit bigger.
    Some harddisk parts form little feet for that panel.
    And glued the large panel together on the toppanel.
    And now I have a bith more depth and detail.
    With a light behind it, it is still good looking IMO.
    In the meanwhile, I'm slowly getting the tail parts together, but forming the tail with the loose tiles is a very difficult and slow process, frustrating and tedious. :(
    :grr:
  19. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    Great work, but i dont like the pcb-style. Its very original, and very nice worked out, but this style is just not my style.
  20. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    very very cool mod
