Case Mod - In Progress Project Superman - Case (29.07.07) 99% Done !
Discussion in 'Project Logs' started by Dj Ovin, 22 Apr 2007.
  1. THEkorean
    THEkorean 42
    10 Jun 2005
    one problem with your logo, where the hell is superman in it? hahahaha, other than that, cool mod
  2. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    well, you see him in the plexi :D
    kidding. have to redo the logo, again.
    EDIT: Logo up, think?
  3. Dj Ovin
    7 Nov 2005
    SIde Panel & Plexi for Pwr/Rst
    Update - 15.05.07
    Well, got no update when promised, but here I am again, with some shots for you! Got the side panel done, and the plexi for Power/Reset buttons! Made two and sanded and recut many times, never got happy :p But now, I will say that its quite good! You can decide.
    Sanded and ready for gluing
    This
    + This
    + This
    = This! :D Glued, just have to harden for some hours.
    Window under pressure
    Plexi for the buttons placed on a piece of wood so it will lay still.
    The case
    I have absolutely NO idea of this place. Need to think a little more.
    Was thinking of placing a sheet of plexi here, what you think? Just thought it would look cool. And it wount be plexi on the hdd-rack.
    Front with Power/Reset button mounted with the plexi under. Looking good?
    To more shots
    At last, one more of the side panel
    Thats that! Gone for the weekend, coming back with something awesome :D
    Comment and discuss below.
    Regards,
    Øyvind
  4. Dj Ovin
    7 Nov 2005
  5. Mr. Oizo
    Mr. Oizo That yellow furry animal-thingy
    18 Mar 2007
    Hmm, I really like your mod. But as the guys on diskusjon.no said, I also dont really like the plastic (?) piece around the buttons. But for the rest: COOL!
  6. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    ah but I am guessing the plexi around the button will glow, in which case, cool.
  7. Dj Ovin
    7 Nov 2005
    Its plexi Mr. Oizo, and yes Mother-, it will glow, the Power/Hdd LEDs will take care of that :) I think it will be cool, so it wil be there ;)
  8. KlavKalashj
    KlavKalashj What's a Dremel?
    7 Sep 2006
    About your gf, I know a norweigan girl called martha that got a boyfriend whos name is öyvind:p but with norweigan "ö";)
    OT: Really nice, your windows pwns! Will you do my case too?:p
  9. Dj Ovin
    7 Nov 2005
    well, not me im afraid. but quite cool thou!
    If you take care of the shipping we can fix that ;) (PM if you ment it seriously)
  10. Dj Ovin
    7 Nov 2005
    Hi again,
    No work the last few days, been busy. But we tested the UV light in the case last night, we had to see how the holes was doing. We dont know if we like it or not, but we thought of covering it from the back with black alu. Dont know how i will get that done, the holes is almost too near the logo.
    What do you think? I will take a shot of it tonight, then you can see how it is.
  11. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    i hope you you dont ever want to take that plexi off the sidepanel! Hysol is very good stuff. we use it on my school's formula SAE team and it holds anything to anything. i used it to glue an alu plate to our carbon undertray for our battery to have a place to be. just a little bit and it stands up to the rigors of weekly track beatings :rock:
    back from that tangent...
    i like the plexi button panel, it looks very professional. it would be even better if you made it the hdd status light as well :thumb:
  12. Dj Ovin
    7 Nov 2005
    I noticed that, it looks like its gonna hold for a while ..
    But what do you think about how it will look with plexi behind the vent holes?
    And thanks, I thought about that, but i dont know yet. I can just make another one if I decide to make it bigger.
  13. Dj Ovin
    7 Nov 2005
    Side Panel With UV
    Update - 23.05.07
    Some pics to show the light at the vent holes.
    First one with blitz
    Two without
    What you think? Should i do something about it or should i let it go? If i should to something, what?!
    Regards,
    Øyvind
  14. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    I would say - kill the holes! But then again.... isn't that where the side fan for the gpu is supposed to be mounted? Maybe you need to fill the top right hand side with some filer or something just to haave a small gap between the holes and the actual superman logo. You gonna have to paint it afterwards though.
  15. Dj Ovin
    7 Nov 2005
    Yes, its there the fan get air. But nothing to worry about there, its no big deal if i dont use it.
    If i remove the pleixi behind the holes, and then mount a small piece of alu behind it and fill it with a kind of filler, i will mask the entire side of the case exept the place where in filling and repainting.
    But do you think it will look ok with the finish? I mean, its not the same finish on the filler as it is on the alu from Lian Li.. Would that be a problem or will it be a to small area to notice any difference?
  16. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    I saw some mods on this site where people can get the same Lian Li brushed alu effect on their cases just by sanding it correctly. How i dont know. I dont even know what they use as filler - bondo i think. Search around on the forum and see if you cant find a project log where someone did the same and see if you can do that.
  17. Dj Ovin
    7 Nov 2005
    Hmm , I can see if I find something useful. But if not i will just sand it up and down, and hope that its good enough. But i also have to find the exact color.
    We will see about this thing, i think i will try to make something on the top panel first.
    Maybe some work will be done this weekend!
    Stay Tuned.
  18. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    I got a brushed effect just with sanding paper (180, 320 and 600 grit).
    I've seen people use steel brushes as well, but most use only sanding papers.
  19. dacust
    dacust What's a Dremel?
    10 Mar 2007
    What I've seen people do is use a coarse grit on a block with a straight edge to get that effect.
  20. Dj Ovin
    7 Nov 2005
    Thanks for answers, i will see what i can do about that, but later. I will do it later, am doing the top panel now, have cut out the hole and the plexi for the logo. I will try some engraving later when time. Update just around the corner!
