Case Mod - In Progress Project: Supernova 9/4/2012 Finished.
Discussion in 'Project Logs' started by xD3aDPooLx, 6 Aug 2012.
  1. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
    It only feels like a few days ago that I finished Project Attero. Enough about that though, Lets get everyone caught up on this one.
    With the success of the last project at the Gigabyte ESports lan event that took place here in So Cal in June, I have been able to do this project for a few companies for a special event. I will revel that event in some time, but you all can take guess's though. I was looking to doing something completely different from what we have seen and to expand what I am able to do. The orginal plan was to go with an Orange and White theme, but I scarped that plan today. I want the theme to remain easy enough for most people to do with normal tools but still stand out. This was also the plan for the main sponsor too. Use a simple yet effective case and make a beastly looking rig with it. So with out any more delay here are some of the items I will be using
    • Bitfenix Outlaw case
    • Intel i5 2500k
    • Evga z68 SLI Micro ATX mobo
    • Zotac GTX 570
    • Curical Ballstix Ram 2133 8gb
    • NZXT Hale90 750w PSU
    • NZXT Sentry Mesh Fan Controllers
    • NZXT FZ120mm Fans Non LED
    • Koolance 240 - 20 fpi and 360 -30 fpi cooper rads
    • Koolance 370si cpu block
    • Koolance Compression Fittings
    • Koolance Big Boy 80mmx240 Reservoir
    • Koolance PMP 450 Pump with the PPCS adapter
    • Koolance 570 GPU Block
    • Big City Sleeve - Black and White
    • SSD to be named later
    List of things to do...
    • Cut out a place in the roof for a 360 rad and grill
    • Get a custom 360 rad grill
    • Custom cut window
    • Order Mayhems Aurora Supernova
    • Possibly paint a few items
    • Cut the mobo plate and remove the HD cages
    • Build it
    Without further ado, here are some pics of what has came in so far.
    The Bitfenix Outlaw case
    The template I had for the 360 rads.. I drew it up in chalk as a rough sketch
    More work will be done in a few days.. Thanks for Viewing.
  2. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
  3. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
    Well I love the day off, so I can work on this project. Here is some of the work Today.
    Here is the top cut out for the 360 rad. It will all be covered by a nice Rad Grill
    Here is the case with the mobo plate cut and without the HD cages and drive bays
    After taking out the rivets that hold this between the sides of the drive bays, it needs to be modified to allow the 240 rad and fan up front
    The other side of the Drive bays
    All finished on this one
    This is it all put back together
    Checking the clearance.
    This is the proposed loop setup. Anyone see anything wrong or a way to improve it.
    I made a psu cover for a test fit. I placed the pump where I think It will look the best.
  4. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
    I have done a few minor things so far over the past few days...
    I made a cover for the drive bays
    A test fitting with the sentry mesh's from NZXT
    With the rad temperately in place
    I have a few things to do and fix. I got to make sure i got every line nice and straight. I am going to re cut the mobo plate to better suit my needs. I am working on a custom rad grill and psu cover. I need to cut the side panel for the window and install the equipment. I should flush the rads soon though, LOL. Can forget that. Until next time.
  5. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
  6. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    Those fan controllers just go with that case soo well ! , Like the switcheroo youve done with the mobo aswell
  7. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
    Been a little bit busy with work and the heat here is southern california.... at one point 120f... YIKES, it turns the garage into a sauna. Heres a few things that I was able to get going.
    After flushing the rads, and letting them dry. I started in on putting them together.
    The rad and fans sitting inside its home. I had to change out one of the Koolance fittings, to a 90 to work correctly. I will say this, these Koolance fittings are the best out on the market. It is really easy to put them on since they have a flat spot design for a wrench. I HIGHLY recommend them.
    Put the front fans on. The front is shaping up nicely.
    Since a did some cutting on the mobo plate and top plate, and cleaning up the lines, I sanded them down to get them ready for paint. I also took the front panel mesh out to paint it.
    Here is the mesh installed back into the front panel. Also my little buddy showed up to help out.
    This little punk told me to sleeve the pump wires and wire up my vandal switch for this build and I listened.
    Then he went off playing around with the res and top panel.
    I am awaiting the grill and psu cover to show up. Plus a few more special items.
  8. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
    Wow things are going nice right now.... 2 New Sponsors have stepped up....
    Blade Works
    FannBlade is hooking me up with some awesome case feet. I cant wait to put them on this rig.
    Computer Modding Supplies
    Mike is donating some awesome U-channel for this build.
    I want to give them a HUGE Thank you for helping out with this build. Man This project keeps getting better.
  9. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
    A small quick update..
    So I painted the nobs to the fan controllers. Plus I made some modifications to the plate for the fan controller. They got shortened ALOT..
    Installed the vandal switch where I wanted it... I got to repaint the top plate after a really good sand down.
    I mounted the rad and res , just to make sure everything was looking good. I ran extra tubing I had to make sure that the clearance was right.
    A picture with the fans and rad in place up top.
  10. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    What have been seen, cant be unseen:p
  11. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
    Welcome the newest sponsor
  12. J-Lyons
    J-Lyons What's a Dremel?
    7 Jul 2012
    Looking good mate
  13. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
    Update, I get the psu and rad grill tomorrow, I am excited about that. The case feet should be here either tomorrow or monday.
    Other then that here is a few pics of things coming along.
    Installed the 2500k on the mobo. Along with the mounting bracket for the cpu block
    The new Ram I picked up for this build...
    Said ram installed with cpu block
    The 570 waiting to get dissembled. Come to find out, I was sent a Non-reference card. So I cant put the gpu block on it, I am getting it exchanged though. :D (Thanks you Zotac and Juliette)
    The block is ready to be put on, but it will have to wait.
  14. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
    Well back at it..
    I had to shorten the fan controller cables. I didnt want a huge mess for the cables.
    The PSU came in today... OMG its so pretty
    The rad grill...
    I got to say these case feet are freaking awesome. FannBlade did a killer job with them
    The feet installed
    PSU cover installed into its home.
    The Rad Grill, rad and res all in place....
    Some of the cable management going on.. If your wondering why there is one hook up left open. well you have to wait and what thats for.. ;)
  15. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
    A small update
    I am still waiting on the replacement video card and the coolant to get here. But I still got some work done.
    Lettering all lite up
    The new window
    All most complete
  16. SilveR_172
    24 Nov 2011
    WOW Thats SEXY AS ! ****Love the handy mandy work ! =)
    Well done be proud of it and lets see some benchies !
  17. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    all you need now is a modkit for the pump:thumb:
  18. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
    Well what a day... This morning my house was broken into while we were away.
    Every bit of electronics was stolen, Including this build. I was almost done, but it will never see the light of day again.
    Sorry to all who wanted to see it finished.
  19. xD3aDPooLx
    xD3aDPooLx Modder
    11 Jul 2012
    Supernova has been found and is in my hands.... now I need a 570 to finish her off.
  20. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    thats to bad! but good that you got her back!
    really hope you got everything(all your other electronics) back!
