Project: SX1 - Resumed :)
Discussion in 'Project Logs' started by sc4mpi, 18 May 2006.
  1. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    Hello again , im back in the modding feel and this is going to be quite of a manic project :clap:
    Iv Racked out the old coolermaster s4000 sx1 (extended version) and its time to put pen to paper and work out some plans.
    the basic's behind it will be to create a viable gaming machine. combined with the abilty to run as a server for my cisco , network+,ccna etc. The machine is going to be watercooled as per my other mods, most likey with 2 loops (be it 1/2" or 3/8") allowing the added function of running passive the other fact is i want to be able to keep the rack mount function whilst having top mounted rad and rez's.
    specs at the moment will consist of..
    fx-57
    Dfi expert
    Sapphire X1900xtx
    Bfg Ageia ppu
    2gb g.skill hz
    creative x-fi
    pcp 510
    2x 74gig raptors
    200gig seagate
    2x 250 wd caviars (one for server 2k3 the other for unix or linux)
    Watercooling
    2xddc ultra
    eddy-ek fcx 1800
    danger den tdx
    danger den maze 4 gpu
    alphacool chippy
    bip 120.2
    pa 120.2
    aquero
    dual fass-o-matics
    So onto the start.
    The case :)
    havnt got a lot of time today. modding it will commence tommorw :clap:
    All comments welcome (good or bad ;) )
    Sc4mpi out :thumb:
  2. jrs77
    jrs77 Modder
    17 Feb 2006
    Well, this is really a huge case you got there.
    Should be no problem to get everything installed properly ;)
  3. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Nice case. Looking forward to your mod..
  4. frodo
    frodo What's a Dremel?
    1 Nov 2003
    w00t! i wanted that case off you... but now i got the pc07 and chiller i guess i dont need it :p lol
    it looks rather spiffy! and big!
  5. fatty
    fatty Minimodder
    12 Jul 2004
    Case is huuuuuuuuuge you need another chiller in it :worried:
  6. sc4mpi
    16 Jan 2005
    first design for the mount for the pumps.
  7. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    TBH i don't think you can fit a chiller inside that sausage :hehe:
  8. frodo
    1 Nov 2003
    yup... youd have to make a case underneath for it...., but then it cant be used as a rackmount :(
  9. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    nice case!
    btw, you could crop those images to loose all the white space...
  10. sc4mpi
    16 Jan 2005
    inital design for the top inlay plate that will hold the 2 fass and radiator :clap: (thz morgan old buddy - MDK)
    and a idea what the gills might look like
  11. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    That is some fine work come on more modding :D
    hmm someone should get a bit of pimping for that design there :p
    Morgan.
  12. sc4mpi
    16 Jan 2005
    dualy edited : :clap:
  13. sc4mpi
    16 Jan 2005
    got around to sorting out and fitting the bip2 :)
  14. Arkuden
    Arkuden mow?
    9 Jul 2004
    OOooo thats a nice case. Should be a nice roomy area to work in.
  15. customh
    customh conflagration.
    22 Oct 2005
    aaaaand subscribed, i expect something sweet buddy.
  16. Guest-23315
    Guest-23315 Guest
    i hope your gonna do the frount panel like J_Pepper did with his....
  17. sc4mpi
    16 Jan 2005
    loops layouts :)
  18. Guest-23315
    Guest-23315 Guest
    whats the use of the MAze 4 in the rig?
  19. Dustin
    Dustin What's a Dremel?
    22 Apr 2006
    Is that case considered to be a limo or its just me?Where did you found it?
    Looking foraward for the mod,you gotta love Black Hazard too
  20. Valo
    Valo Minimodder
    11 Aug 2004
    i think maze 4 is used to cool ageia ppu:)
