Are you sure about the dual DDC ultra pumps? I've got some bad experience with the original DDC.. I'd take one or two MCP655's instead. IMHO.. Very nice case btw Would love to have one of those myself, but it looks like that's never going to happen as they are impossible to find. Looking forward to see this turn out
iv already got one of them. the other is on order .what bad experience have you had with them ? out of intrest. as for the MCP655 aka d5 the outlets are in the wrong place there vertical i need them horizontal like the ddc
I've had two Delphi DDC with the known startup bug. If I turn them on (give power), they wouldn't start pumping. I had to take a screwdriver or something similar to hit them with in order to get them working. I've now switched to an AquaComputer Aquastream (modified Eheim 1046). If you don't have the same problem I think the pumps will be fine. Good luck
Ive got a Danger Den DDC (pretty much identical to all the others described) running with 1/2" out lets, using the top inlet point on a plexi-top, and it runns perfectally all day.
got some more parts today. so i mounted the pa120.2 and started some tube routing pa 120.2 im also adding the chipset into the cpu loop. but other than that its coming along
Love the case, nice mod too . So looks like you have one of the very first watercooled physics cards.
YOu need better pipe seperaters those cable ties don't do it http://www.bsr-aerotek.com/store/index.php?osCsid=23eeda26f6075c2e48274bc10c8735b3&cPath=251 something like that would be cool, if u wait a bit im making an order for some titanium parts so can add a few in as min order is £50 got about £100s worth of titanium fixings to buy. Morgan.
good find morg, those things look incredible! case is looking real good, i want to see all the res's and the rad uptop
The only place that I know of that still sells the SX1 (other than ebay) is here. Nice work as usual mate, look foreward to seeing it finished.
I want this case aswell.The only bad thing about it is that there are only 3 5,25" slots and NO 3,5 ones.Also it would be a bit more taller so it can stand really massive(not a limo) and a black paint,but if it was like that this was going to be the perfect case. Are you going to make a new face plate or leave it like that?With a black smoked plexi you can do very good job. Also if there is a place below the mobo the rad would sit there better imo,just like you Black hazard 2 mod.And you can cover the place where its hanged now with black plexi and let the tubing and cables run through holes in it.Its a hard work doing whole self-made pexi front panels but the result is stunning.
The case i wanted... I've the shorter version, i got mine on e-bay.. Was listed as the SX-1 but when i got it in the post it wasnt to be... Could really have done with the extra space.....
sorry the lack up of updates in the past couple of days iv been ill with a flu bug anyway i got the lod and top radiator mounted Test fit (noticed by there only being one fan the 4mm gap at the front is to allow clearance between the front res and the aquero , i also need to get a another silver aquacomputer grill maby. )# Just fits ppu with maze4 fcx 1900 There is 6 x 5,25" or 3x 5,25" and 5x 3,12" I got 5 hds in here so there is some decent space. and the bottem rack comes fan cooled as standad
I mean there are only 3x 5,25 external bays.And i need around 5 and 1x 3,5. That black grill doesnt stand very good there imo.If you cover the grill with hand and leave the fass-o-matics it looks really really cool.Maybe its just the black grill. Really freakin' nice I beg you do something with the front panel. I cant wait
well i dint like the placing of the res's with the grill covering the second so i remounted them this morning and moved the aquero down to the bottem slot. as for the grill it was the only one i had lying about. im going to get the silver aquacomputer version. The remounted fass's (the one on the right is full of water and in use in the pic)
Looking good, dont really like the heads on these(below) something with a flush finish would look much much better imo
I thought that as well... would look much better if you used say.. countersunk hex screws or something
