Case Mod - Complete ⭐ Project Synthesis (Corsair Carbide Air 540 X Mod)
Discussion in 'Project Logs' started by Y.G Casemod, 16 May 2017.
  1. Y.G Casemod
    Y.G Casemod Extreme modder
    8 Feb 2017
    Another step.
    In these photos we will see the assembly of the Aquacomputer High Flow and Primochill Vortex Flow Meters.
    The flowmeters will be mounted on a specially built support and will go to the top part of the case side psu.
    We will also see the details of the setting of the gpu loop connections (always in the case side of the case) and the positioning of the EK's Res combo in the bay from 5.25
    We will see the positioning of the bleed faucets immediately after the passage fittings and the fill-fill for filling the res mentioned above.
    Stay tuned.
  2. Y.G Casemod
    8 Feb 2017
    A bit of sleeving meanwhile ...
    Leading the owners of Leadex Superflower is a nightmare.
    I'm not going to show you all the cables that I slewed because it would be too long, (inhuman work.XD) but each cable has been slewed because it's all out of sight.
    I also put the right poweradjust panel in the middle to make the idea of the job.
    Stay tuned.
  3. Y.G Casemod
    8 Feb 2017
    Next with the jobs.
    In these photos we will see the 240-track rad mount sequence with it's relative fans and it's final positioning in the case.
    In detail, you can see the mounting of the pipes and fittings for connection to the wall passage fittings.
    Finally in this step we will also see the mounting of the fan in exaust.
    Stay tuned.
  4. Y.G Casemod
    8 Feb 2017
  5. Y.G Casemod
    8 Feb 2017
    Let's go through the photos (step 6, last)
    In this sequence we will see:
    The psu cover, 5.25 bay bay cover, sli bridge cover, 2 ssd covers. All the pieces in question are over.
    Also made the second Dragon of the MSI metal logo, which will be placed on the modified bulkhead and windowed on the psu side (then we will see where).
    Stay tuned.
  6. Y.G Casemod
    8 Feb 2017
    Continue with the I / O panel mounting.
    The following push buttons are mounted on the panel:
    On off pc, reset, TB Vegas light switch change,white led lighting switch,uv led lighting switch.
    If both are activated, the lighting keys activate both lighting, which also includes green and white LEDs for tangential lighting to the pan in the 5.25 bay, including the atom depicted on the panel,
    Which can be switched on for more color combinations (to see the effect of referring to the final video).
    As we will see in the pictures I also mounted a led door inside the panel where a green LED will be put in order to have visual confirmation of the SSD's operation. This led is at the center of atomic (nucleus) also backlit.
  7. Y.G Casemod
    8 Feb 2017
    Wiring and closing of the controller, and complete mounting of the vga ready to be liquidated.
    And do you remember the second dragon?
    Stay tuned.
  8. Y.G Casemod
    8 Feb 2017
    Ok we continue.
    In these photos we will see:
    Final assembly of the 360's rad grid on the front, with the metal dragon of the MSI logo here also in beautiful view.
    Final installation and wiring of led for back case lighting.
    Small anticipation of what will be the view in the case side psu.
    Some details of the exterior of the case (exaust fan with grille, external support for the cylindrical res combo, detail of a fan on the front).
    Small anticipation of how it is about to come out.
    Stay tuned.
  9. Y.G Casemod
    8 Feb 2017
    Final assembly steps:
    External grills.
    Mount the cover / grill on the front completely redesigned and re-made from 0.
    Mounting the cover / grill on top also this completely redesigned and re-made of healthy plant.
    NB. In the back wall of the covers I mounted a honeycomb net that in addition to improving the aesthetics in my opinion, in the front also serves as a protection from moving fans.
    We will also see the pictures in detail of the mounted parts.
    We are almost at the end.
    Stay Tuned.
    Here's the step 6 video.
  10. Y.G Casemod
    8 Feb 2017
    Ok here we are at the end.
    Here are the last photos of the worklog.
    By installing the beautiful Corsair Dominator Platinum ram with led modification to video cards mounting, including the installation of the PSU cover and finally completing and filling the 2 loops.
    Soon the final photos and the final video I made for this mod.
    Stay tuned.
  11. Y.G Casemod
    8 Feb 2017
    And here are the final photos of the complete Synthesis.
    If you like to take a look I also put the link to the final video below.
    Whatever it was, it was an uncompromising adventure.
    I hope the mod liked you and that the worklog was of your own liking.
    I still thank you for your interest and for following me.
    NB. But this worklog has not just come to an end, I still have some video clips to show you .....
    Meanwhile we look at these photos and the video.
    Make yourself comfortable and have fun, and do not forget ... "Stay ever tuned"
    Talk to you soon.
    And the next mod .....
  12. Y.G Casemod
    8 Feb 2017
  13. Y.G Casemod
    8 Feb 2017
    As promised here is the last thing I wanted to show you about this mod.
    The overclocking potential of this system.
    The tests were made last month with a warm torrential (32 C ° environment) ....
    The processor is 5 GHZ and cooled with only 240 working hours.
    Card scores speak alone, despite the tests being done shortly after their release and with non-optimized drivers.
    Finally, the scores screens on Heaven 4.0 with the optimized OC.
    First of all, I leave you here below the link to the video during the OC's wholesale phase.
    What about ... a real monster!
    At the next mod guys.XD
    Stay tuned.
  14. AleksandarK
    AleksandarK What's a Dremel?
    11 Apr 2017
    Excited to see that one.
    This mod turned out great. Keep going.
  15. Y.G Casemod
    8 Feb 2017
    THX man.:cool:
    AleksandarK likes this.
  16. Y.G Casemod
    8 Feb 2017
  17. Y.G Casemod
    8 Feb 2017
    Let's go back on this mod.
    The owner asked me for a headphones stand mouse mouse cable tensioner in theme with the mod.
    That's what I did.
    Stay ever tuned.
  18. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    At first this just looked like another mod banged out on a some ones dining room table.... but wow was i wrong! Totally blown away by the end result.. you sir could be my new source for inspiration :)
    You know ive been making headphone stands for ages now.... and not one of them look as good as yours :dremel::clap::rock:
    Y.G Casemod likes this.
  19. Y.G Casemod
    8 Feb 2017
    THX.:rock:
  20. Y.G Casemod
    8 Feb 2017
    Synthesis complete gaming setup.
