This is my project based on a Core P5 case Mod with a ASRock Taichi theme. In this mod iam going to extend the case to mount dual liquid cooling system. Intel i9 9900K ASRock Z390 Taichi Ultimate 3 x Seagate Firecuda 510 1TB Nvme M.2 ssd 32GB Thermaltake Toughram 3600MHz Thermaltake 1200W Toughpower PF1 ARGB psu Thermaltake Dual LCS Sponsored by
Time to extend the case and cut out a ACP panel for the front of the case Added an old section from my P7 side panel cutting the ACP by hand with a sharp edge knife against the case not a bad fit drilled some pilot holes and used Whats a dremel DSM20 saw to cut the sections out for fans and radiator
Working on vinyl stickers not a bad colour match now to sort the rear panel Lots of light coats, light sand and paint again
Test fitting the fans and rear radiator before painting front cover, mounting the psu and pump / rez combo to rear of case. Size comparison to Core P5
Try to do it, the mod will look much more striking. Here's an idea, I made this for the first generation Asrock Taichi: start at 1:12
Very nice love the front panel for now be stationary cogs, due to me been in 2021 Thermaltake casemod invitational season 1 case arrived today so need to concentrate on that mod.
Time to fill the dual loops with Thermaltake P1000 white coolant then fit the side and rear panels ready for final photos this afternoon
