Project: Technics, check it out
Discussion in 'Project Logs' started by Gnar., 14 Feb 2004.
  1. Gnar.
    Gnar. What's a Dremel?
    9 Feb 2004
    For this project I am going to making a pc inside this old speaker case, im only just beginning but my ideas for it are looking good already, so heres a couple pics for you!!!! thanks for lookin! ill keep you updated
  2. Gnar.
    9 Feb 2004
    well i cut the backboard down to the size of the back, i will still have to fix up those two broken spots on the bottom but it should clean up fine with some wood glue and a clamp, heres the pics of the pegboard!
  3. schroom
    schroom What's a Dremel?
    11 Feb 2004
    looks good dude, nice idea... i personally could see a nice flap opening dvd drive or similar in the space of the main large diameter speaker; perhaps lcds or control panels in the smaller speakers.. if you can see what i mean :)
  4. Gnar.
    9 Feb 2004
    yeah i understand what you mean, i was actually thinkin about just leaving the big one fora window and probly putting fans in the other holes, im going to either not have any cd drive or just going to have to make it come out the back or a side, thanks im open to any more ideas everyone, im working on the hdd mounting right now
  5. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    when i did this mod i mounted everything to a piece of perspex by fitting motherboard mounting collars into it. drill a hole the same diameter as the core of the thread on them, and then screw them in slowly. Its quite discrete and a firm mount. i think the stuff i used was around 8-12mm thick.
    try getting hold of a slow load cd/dvd drive, that could be better to work with.
  6. jamicon
    jamicon What's a Dremel?
    26 Nov 2001
    Interesting idea! I don't think I have seen anyone put a PC in a speaker before!
    maybe mount the CD-ROM centred on the large speaker hole, and mount the grill to it (of if it is a slot load cut a small slot in the grill). That way you had a CD-ROM without changing the outside frame. Alternatively, you could have it come out the side or back :D
  7. Gnar.
    9 Feb 2004
    hmmm i like it man, this is what i've done with the hard drives now..
  8. Gnar.
    9 Feb 2004
    and heres what i did with the back where the motherboard will be down below:
  9. Providence
    Providence What's a Dremel?
    23 Jan 2004
    This looks like a good idea. Don't forget about your cooling. You could use a fan there in one of the smaller, empty holes.
    Two intakes near the bottom and one exhaust at the top facing out and one facing back (so the air splits, some out the front, some out the back of the speaker) would be a good working design. After all, heat rises.
  10. Gnar.
    9 Feb 2004
    thats the plan
  11. Zot Rgul8ed
    Zot Rgul8ed What's a Dremel?
    14 Feb 2004
    Cool
    Just put one big fan in the hole for the main, overclock it, and your good to go.
  12. Gnar.
    9 Feb 2004
    hahahah scott..... i wonder what a 12 inch fan would look like? lol, it would sound fantastic too :hehe:
    right now im working on a bracket to hold up a cd drive inthere and have it come out the 12 inch window at the top, its almost done, then i will have to fix the cd drive to it somehow.. ill figure something out pics up soon
  13. dirtbiker
    dirtbiker What's a Dremel?
    24 Dec 2003
    Inspiring! I've got a speaker a bit like that up in the loft... :dremel:
    Intrested to see how this one turns out, looks good so far ;)
  14. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    Lookin awesome already. Like others have said before me, I can't wait to see what happens next. Mod on, man. :dremel:
  15. Gnar.
    9 Feb 2004
    thanks guys, im kinda stuck here, i cant figure out a way to get the standoffs to stay in the bottom so i can put the mobo in place, any ideas?
  16. Xen0phobiak
    8 Aug 2002
    perspex
  17. Gnar.
    9 Feb 2004
    hmm i dont have any but i might be able to find something that will work... lets look around..
  18. Gnar.
    9 Feb 2004
    FINALYYYYYYY i found somethin, this has been pissing me off too lol, and i was sittinhere at my computer and noticed this little thin plastic that was used for a football cover for some autographed ball, and check it!
    the threads that stick out the back will rest in holes that will be drilled behind them
    and i will screw this whole thing down to the bottom :) lookin good for the mobo now
  19. coorz
    coorz Miffed
    25 Apr 2003
    Ah thought you was gonna build a PC into a Technics SL12xx turntable!
    Anything Technics is good, subscribed!
  20. Gnar.
    9 Feb 2004
    haha thanks ya!!!!!
