Do you mean the wires in the tubes?? All the other wires that you c laying around in the case wil be covered GTZ
UPDATE TIME I'm allmost there...... Did a lot of wiring ( c pic below ) And with wiring comes wire managment. I used the tubes of the pieces of rounded cable I cut off. My ram cooling I bought at the computer fair for €3 And my grafa cooling Couldn't resist a first assembly en test... Only need to mod the cd rom and finished Let me know what you think GTZZZZZZ
THX I'm very happy with the shine on my wood ( c last picture ) I'm going to get my new grafa today, a radeon 9550. Nothing special I know,but my budget limits me to that for the moment. I'll try to make some "not blury" pics of the case. GTZZ
Nice mod indeed. btw did u use teflon sheets, or some white plastic for those flames? They are realy white.
Did the final assembly today.. Only one little prob, the heatsink of my grafa is in the way. It blocks my 120mm fan that's mounted on my cover. The fan with the f***** you grill on it is also under the large 120mm fan. Swat, i think it still looks damn sweet GRTZZ
UPDATE TIME Case is as good as finished, a few details that still need to be done... But as you all know, details make it even nicer. Enough horsetalk, here are the pics My dual screen setup (2 x 19 inch) with the matrix screensaver No, it isn'tpink, well maybe it is, but the colors change every 5 seconds. They are called RGB effect leds.Bought them at Conrad GTZZZZZZ
It would be sweet to have a laser cut grill on top that continues the flame tips into the grill...so the white flames dont just stop at the fan hole I like it though. Computer ricing, lol, all he needs is NAWWWWWWWWWS!!!!1
What size tubing did you use for the 4 wire molex's. Going to do a mod like that cept probaly wont have plugs into PSU like that. Oh yea like all the lights bet it looks even better in real life but im guessin those switchs are 2 turn all them off cause that would suck to have to sleep with that thing on around you.
