Case Mod - In Progress Project: Terminator
Discussion in 'Project Logs' started by Frenkie, 4 Mar 2009.
  1. Frenkie
    Frenkie Lets mod the world!
    3 Jul 2006
    At first I thought I woud have a problem fastening the damper to the case, because of its shape.
    But after I used my 1337 drawing skillz... :p
    ...I made two neat little brackets, that did just the job. Screwed to the case with one laagbolkopinbus-screw. (trans ?)
    I also filled the two giant holes on the side of the skull with some polystyreen.
    And with some modelbuilding parts...
    Playing with the design ( offcourse the picture of the real skull beneath it)
    Spraypainting.
    And now it looks like this.
    Maybe I will work on those innerparts with some black paint.
    Boddaker likes this.
  2. Frenkie
    3 Jul 2006
    Well, After some second-thoughts and much deliberation, I have decided to re-do the entire skull. I stripped the foil off and I will try to smooth out the skull as much as I can. Then I wil coat it with the 'chrome' spraypaint. I tried it out on the Machine-mod skull, and that turned out very good ( better then the foil ). :sigh:
  3. MIGUI
    MIGUI What's a Dremel?
    27 Feb 2009
    Good job. :thumb:
  4. Frenkie
    3 Jul 2006
    Never mind, I dropped the skull........ :( :( :(
  5. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    :duh::duh::duh::duh::duh::duh::jawdrop::jawdrop: :jawdrop::jawdrop::jawdrop::waah::waah::waah: :waah::waah::waah:
    No way man :(
    What are your plans now? A completely new skull?
  6. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Superglue to the rescue? It could represent a reprogrammed terminator. They usually get smashed to pieces and then reassembled by the Resistance.
  7. Frenkie
    3 Jul 2006
    No, thanx. I am getting a brand new one. Just starting over, and try to not make the same mistakes as before. :wallbash:
  8. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    Aww no! it was going so good too! :wallbash:
    Ah well, i suppose the next one will be better right?
  9. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    practise makes perfect :p
    bad luck tho mate.
  10. Frenkie
    3 Jul 2006
    Thanx everybody for your support. I hopped over to a medieval store in Belgium, and got me a slightly different Markus Mayer skull. This one allready has "evil" eyes, but unfortunatly, the teeth are all wrong. That will take me the most time, I guess.
  11. Frenkie
    3 Jul 2006
    I have two options, a set of false teeth/caps, ór airbrushing a set of chompers on it :)
    Status so far;
  12. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    Looking good so far!
    What material is this skull made of?
  13. Javerh
    5 Sep 2006
    I'd suggest going with the caps. Airbrushing would easily make the teeth look silly.
  14. DonT-FeaR
    23 Jul 2008
    looks much better.. yeah caps for sure
  15. Frenkie
    3 Jul 2006
    They call it " polystone" but thats just BS. its plastic. :)
    My friend Kevin got me a nice set of demonstration dentures.
    Slicing and dicing.
    Cut a piece out of the skull.
    Next I will fit it in, and finish the skull.
    This is the left arm, this one grabs the front of the case.
    And the right side, which holds the gun with the laserled.
    Now I have to come up with two elbowpieces that attach to the case.
    BTW, did you see this one : Transforminators !
  16. Angleus
    Angleus What's a Dremel?
    28 Nov 2007
    Haha that was brilliant
    Oh yeah, sweet project too! :thumb:
  17. bagman
    bagman Minimodder
    18 Apr 2009
    :D:Dlove the smiling skull
  18. DonT-FeaR
    23 Jul 2008
    looking good!
  19. Bad_cancer
    7 Apr 2009
    you know what, don't put the teeth in, leave it smiling like that
    lol!
    jk. waiting patiently here
  20. thydzik
    thydzik What's a Dremel?
    19 May 2004
    good decision, didn't like the fake foil look.
