Case Mod - In Progress Project: Terminator
Discussion in 'Project Logs' started by Frenkie, 4 Mar 2009.
  1. bagman
    bagman Minimodder
    18 Apr 2009
    really like the mod what you should do is put a remot control car under it or something so it moves around that would be even more awesome
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Awesome job! I've gotta tell Frank Lee @ Antec about this, they will love it :thumb:
  3. Frenkie
    Frenkie Lets mod the world!
    3 Jul 2006
    Hey thats great, thanx man, youre the best.
    Perhaps I was not clear enough when I posted the last set of pictures. The reason was to give you a update on the progress, nothing else. The mod is not finished yet !
    I've been working on moving the skull to the centre AND give it a neck. This is what I made so far, also; its only an update.
    This is the core of roll of wire, made from real thin metal.
    Divided into rings.
    Wrapped around a aluminium tube, it ooks like this.
    I gave the rings two nudges to create a flat front end. The drawings on it are just something I'm working on still.
    My first AutoCAD drawing! ( started a coarse, had 3 lessons so far. )
    Two strips of aluminium profile, cut out an angled piece.
    Knocked out the holes.
    And put it together in a cross-support.
    Cut the aluminium tube.
    And made it to fit over the cross-suport.
    The rings and the skull come on top of that.
    Got a bunch of stainless steel wires, tubes and chrome shower-hoses here, which Im going to play with now :)
  4. ringo
    ringo What's a Dremel?
    14 Jun 2008
    Good job, that looks very cool.
  5. tyrandan
    tyrandan Pink Lemonade.
    2 Mar 2009
    Two thumbs up! :thumb: :thumb:
  6. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
  7. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    Looking amazing, but you should paint the teath aswell =)
    And ofcourse use the airbrush to make it look older.
  8. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    Do you mean to age the teeth or make them silver? as i recall the terminators have white teeth that look like human teeth.
  9. TonyL
    TonyL modding on welfare
    23 Dec 2008
  10. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Fantastic work so far Frenkie! (as always!)
    And it's gonna only get better, as you get that AutoCAD training! Look out Bit-Tech!
    I'll be back! (can't believe I'm the first one to say that!)
  11. Reverse
    25 Sep 2008
    Just a bit silver, but mostly aged indeed.
  12. Frenkie
    3 Jul 2006
    I tilted the skull quite a bit forward, then fastened it to the neck.
    I used the cables and chrome tubes to dress up the neck and also to cover the wire that comes from the
    eye-LEDs.
    He looks a lot more angry now, doesnt he ?
    Due to personal circumstances I was unable to do much more. The last thing I did was to take the mod as it
    was with me to the T.i.M.e.S. lanparty here in the Netherlands.
    The casemod compo jury thought it was good enough for first place and that made me feel a bit better.
    I hope that 2010 will be a better year for everybody. ( :grr: crisis suxx :sigh: )
  13. Bad_cancer
    7 Apr 2009
    I like the way that skull is going! That looks good and i'm gad you got the first place, you earned it! :D
