Project: TestPC
Discussion in 'Project Logs' started by mattthegamer463, 31 Mar 2007.
  1. mattthegamer463
    26 Nov 2004
    I didn't make those components, I just borrowed them from the Sketchup Components Collection so don't give me credit for those. All I made was the frame of the case and put those in place to make the design more understandable.
    What was nice too was that all those components were perfectly scaled for me already, so I could base the size of the model around the components the real-world build will hold.
  2. eegg
    eegg What's a Dremel?
    29 Aug 2006
    it would be nice if you would add a build in screen like a ps one or a small 15 inch lcd
  3. mattthegamer463
    26 Nov 2004
  4. MonkeyNutZ
    MonkeyNutZ Crysis Fiend
    5 Jun 2007
    You could add a rail for the edges of the cards to sit on (don't bother with screw holes it'd just be for some support.)
  5. fungry
    fungry What's a Dremel?
    14 May 2006
    Nice. As MonkeyNutZ said, I agree that you should add in a rail so that the cards don't slant in anyway as your picture has shown.
    Also, is the motherboard simply placed on the wood or are you also using standoff points so that it doesn't contact the wood?
  6. mattthegamer463
    26 Nov 2004
    Im working on a card support, the angle aluminum that I was planning on using doesn't fit there, so I need to find some sort of metal bar I can use to screw the cards into. I think its best to screw them in because pushing in connectors can still cause them to loosen as I've learned with normal PC cases. The board is on a neoprene foam mat, as is the bottom deck, to prevent things from sliding around.
  7. Brett89
    Brett89 Minimodder
    15 Dec 2005
    a thin aluminum rod or something?
