Case Mod - In Progress Project "THAURUS" Finish
Discussion in 'Project Logs' started by sangyzan, 22 May 2015.
  1. sangyzan
    sangyzan What's a Dremel?
    17 Aug 2014
    Hello everyone, little update.
    Unfortunately the front glass of the original houses inwin 503 is too narrow for the new project so I decided to create one tailored Plexiglas then that'll sink smoky.
    I also created the parts Plexiglas side windows higher and started to cut the metal mesh to be applied to the sides of the side plates and higher
    Stay Tuned :eek:kok:
  2. Gas_designs
    Gas_designs Minimodder
    29 Sep 2014
    Eccoci qui...
    Seguo :dremel: :dremel: :clap: :clap:
  3. sangyzan
    17 Aug 2014
    :thumb: :thumb:
  4. CircularCore
    CircularCore What's a Dremel?
    6 Feb 2015
    Ciao caro , seguo anch'io :)
  5. sangyzan
    17 Aug 2014
    Ciao carissimo grazie mille ;-)
  6. Deblow
    Deblow Minimodder
    12 Dec 2013
    design on the top looks great!
    fast worker
  7. sangyzan
    17 Aug 2014
    Thanks mate :D
  8. sangyzan
    17 Aug 2014
    Hello guys
    and here is a new arrival to the project. Thank you very much the company JE LI INDUSTRIAL CO. , LTD for supporting the project Thaurus with this fantastic extension PCI-E 3.0 Black Edition by 300 mm Type A
    Cables rising pci-e, allow an alternative solution to the classic position of the vga (connected directly to the motherboard) inside the case without affecting the performance of this last. The company in question produces different types of extensions for every need and are of excellent construction
    Thank you very much again JE LI INDUSTRIAL CO. , LTD
    for more information visit the following link: LI JE INDUSTRIAL CO. , LTD
    See you soon
  9. Sanjaya
    Sanjaya Minimodder
    4 Sep 2013
    Nice build, was this there at computex?
  10. sangyzan
    17 Aug 2014
    Thank you very much , your mod is also very beautiful and special :thumb:
    no, I did not participate unfortunately computex
  11. Sanjaya
    Sanjaya Minimodder
    4 Sep 2013
    Thank You very much. :) I saw your PCI extension(maybe a similar one), might be on FB then. :) good luck. can't wait to see the final build :)
  12. The Colonel
    The Colonel What's a Dremel?
    18 Jul 2014
    I think that your project is much better than many who participated to computex!
    Project "THAURUS" is A-W-E-S-O-M-E ;)
  13. Arcis Modz
    Arcis Modz What's a Dremel?
    31 May 2015
    dang.. that riser.. i need one. :D :)
    btw.. nice build bro.. looking forward for more. :D
  14. sangyzan
    17 Aug 2014
    Thank you so much, yes, i shared it on fb community....and good luck you too
    thanks brother ... you're too good
    Thank you very much ;-)
  15. sangyzan
    17 Aug 2014
    Hello guys .... new update ..... I made some new grommet hole, where I built the supports will then attacked the tanks and gave a first coat of paint the entire case .... I hope you like it
    Stay Tuned!!
  16. sangyzan
    17 Aug 2014
    Hello guys ... new update .... I drilled the midplate the psu to accommodate the pump, I gave a second coat of paint to all members of the house and I also painted the grates.
    Then I mounted the grate panels using hot glue ...... what do you think the result? To you the comments ..
    Ps. paint gratings and midplate is dark gray metallised (London smoke), it's not clear from the photos Why does there was little light and those red dice are temporary.
    Stay Tuned!! :thumb:
  17. sangyzan
    17 Aug 2014
  18. Falqoon
    Falqoon Minimodder
    13 May 2013
    I really like the project, keep going, you're doing a good job!
  19. sangyzan
    17 Aug 2014
    Thank you very much :thumb:
  20. bulldogjeff
    2 Mar 2010
    This thing looks brilliant.. May as well be a scratch build.
