Project: The Blue Monster (Update 10 April)
Discussion in 'Project Logs' started by Ultimate Gamer, 10 Nov 2006.
Rad inside or outside? your call
  1. Inside on the bottom
    72 vote(s)
    85.7%
  2. outside on the side pannel
    12 vote(s)
    14.3%
  1. Ultimate Gamer
    Ultimate Gamer What's a Dremel?
    3 Nov 2006
    getting psu on the 27th???????????? this sucks
  2. Ultimate Gamer
    3 Nov 2006
    ive had some time to think and think and think and think ......
    so today i may go to hardware store and get a new piece of accrillic for the window i just want to know what you think of it inside the case so put your votes in at the top i like it either way and if i put a new sheet on the side with no fans it will overal be quiter witch i would like to go asleep easylie because i can fall alsleep with this comp now lol 2 many 80mm fans
    so tell me if you like
    comments welcome
    thanks
  3. accro
    accro What's a Dremel?
    21 Aug 2005
    haha, Burton \o/ That was all about offtopic, looks pretty good, but i would prefer more clear tubing and UV-blue dye instead of that dark blue tubing.
  4. tkh
    tkh Minimodder
    1 Mar 2006
    Are there holes in the bottom of that case? If not theres not going to be such a good airflow over that Rad.
  5. Ultimate Gamer
    3 Nov 2006
    its not even mounted yet lol i will put holes in
    ya i snowboard so i have this little hankerchif from burton i hope i have a big season here :D
  6. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    me liks the rad placement, keep it there!!!! one mroe thing, u should put higher feet on case and make the areocool fans push instaid of pull.
  7. Ultimate Gamer
    3 Nov 2006
    they are pushing out but one side of one of the fans broke so i dont want it vissibale
  8. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    umm just to let you know those fans wont work well with that type of radiator, those fans cant produce enough static pressure also the CFM output on them is pretty low so you wont be getting good temps because of that, you would want to look for a 120x120x38, a good fan that would work for this and is nice and quiet but are about 21.00us each is SilenX
    http://www.frozencpu.com/products/4...iXtrema_Pro_Fan_IXP-76-18.html?tl=g33c165s358
  9. Ultimate Gamer
    3 Nov 2006
    well i have heard reviews about these fans that they go slow and dont blow much air but they do and a little interal voltage change did the trick there quite yet moving a bunch of air
  10. Ultimate Gamer
    3 Nov 2006
    Update November 21st
    Ok so ive been thinking of it
    ive started a poll asked friends
    and alot more so heres what im going to do
    i am going ot go to my hardware store tommorow :) buy a new piece of 1/4th inch plexi cut it with my dads jig
    then using this template
    i am going to cut the bottom pannel out, with um hole saw then jig then dremel then file and sandpaper lol
    i hope all this works out
    Edit: Everything is marked and ready to be cut i am going to cut it tommorow morning WOOT lol
  11. THEkorean
    THEkorean 42
    10 Jun 2005
    id say inside bottom, and put either the rad or the fans outside of the case and give the case some bad @$$ case feet for ground clearance, maybe some rolling furniture casters ever
  12. Ultimate Gamer
    3 Nov 2006
    lol well alot of people have been complaining that i havent been doing alot of modding,
    so the other day i had my friend spend the night we stayed up till 5:00AM so for about 3 hours from 1:00 to about 4:00 i was busy modding and he was gaming on my rig lol i was sleeving/ moddin :dremel: had to be quite or parents would have waked so i did it in my closent the place in my room whitch is furthest from my parents room, we also snuck downstairs to play a little ps2
    so here is what i sleeved
    2 Sata connectors (ones i am going to be using dua)
    all the power leaders for the Cold cathodes
    all the wires coming from the cold cathodes
    and the wire from the pump
    pics:
    hope you like :D
    comments welcome
    thanks
    i need ideas for feet i was thinking of buing thin acrillic when i get my new pannel and layer it like this
    ________
    _______
    ______
    _____
    ____
    ___
    __
    _
    and glue them together and mabey put a led in it
  13. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    I just had to say that this reminded me of buying my first computer - with an Intel 80386 16MHz processor, an 80MB hard drive, a 2 whole MB of RAM, and the very first generation of Sound Blaster. It cost $3700 Canadian and was a pretty AWESOME system at the time. Have fun man :thumb:
  14. THEkorean
    THEkorean 42
    10 Jun 2005
    hmmm sleeing looks OK for a beginer, but ive got sugestions, mabe get some heatshrinks, trust me they work ALOT better than zipties for keeping the sleeving on the wire, plus it looks nicer, and cost conciderably less amount. You dont have to take all those zipties off, but mabe when you get some heatshrink you can put it over the zipties to mask some of those frayed ends and joints. all you need is some heatshrink (comes in may colors) and a lighter/heat gun, i practiced with a lighter and got pretty good at it.
  15. Jipa
    5 Feb 2004
    What the heck are all the zip ties there for? Just zip (or preferrably heat shrink) the ends and that's it.
  16. Ultimate Gamer
    3 Nov 2006
    well i have a problem i have no heatshirnk.
    yes i always put zip ties on before i heatshrink but i dont have heatshrink i need to find some somwhere lol
  17. Ultimate Gamer
    3 Nov 2006
    Update November 22
    well i decided im going to mount the rad on the bottom WOOT lol
    pics
    getting preped
    starting
    getting there
    slowly moving lol
    first half done
    both done
    sanding
    finished sanding
    done pic
    done pic
    i am going to my hardware store today to get some new accrillic for the new window.
    i have alot of leftover accrillic and i am going to have that old window so i am going to make the feet cool tonnight or somthing.
    thanksgiving breaks sweet :D
    comments welcome
    Thanks :D
  18. zhangmaster12
    11 Jun 2006
    thanksgiving break = MOD!!!!!!!LOL
    oops, i didn;t look carefull thought those fans where pull lol
  19. Ultimate Gamer
    3 Nov 2006
    ok well today i went to da home depot woot lol
    i got my acrillic and and and and it i cut it so now i need to get my custom feet done :D
  20. cire9753
    cire9753 What's a Dremel?
    16 Aug 2006
    i got heatshrink at frys
    and i found it works best if you stretch a smaller size hs instead of using the smallest kind that will fit over the connector
    oh and when you cut sleeveing
    burn the edges a but on both sides and it wont fray
