Project: the **Bunker**
Discussion in 'Project Logs' started by quadmodz, 27 Aug 2005.
  1. quadmodz
    quadmodz What's a Dremel?
    9 Oct 2004
    First of all, I want to introduce my project: the**Bunker I'll started it on the specification:
    LG Flatron L1730S LCD
    Shuttle SN45G v2
    AMD Barton 2500-3200+
    2x512mb DDR pc3200 Twinmos 6-2-2-2
    Sapphire Ati Radeon 9600 Atlantis
    Seagate Barracuda 160gb 7200.7rpm
    D-Link Internal Modem 56k
    Nu-Tech CD/RW 52x32x52x
    Cooling devices:
    Themaltake Aquarius II
    Delta 80mm fan (4k rpm)
    2x Generic 80mm slim type fan transparent (2.8k rpm)
    NMB 60mm fan (2.8k rpm)
    Now for the Introduction, I started this project on May 30, 2005 9:00pm on my room just to plan and prepare the materials :D My concept is to build a bunker, don't ask me why coz I really dont know why I'm doing this project :hehe:
    Take a look on my current rig now. Im using a Geforce4 mx440 now :duh: , I dont want to use now my ATI 9600, coz I'll use it when the project was finish.
    :rock: yeahhh my rig were ripped! :hehe:
  2. quadmodz
    9 Oct 2004
    Now time to show what I've done on the past few months.
    I use acrylic for my case and as you can see there's a mesh grill for the intake fans, I use aluminum angle bar for their brace and stainless bolts and nuts :)
  3. quadmodz
    9 Oct 2004
    As you can see there's no top and front panel. I will do it last coz Im waiting for my PS One LCD. :blush:
    Mesh grill that I use.
    Aluminum Angle Bar.
  4. quadmodz
    9 Oct 2004
    What's a dremel? :hehe:
    Here's how to BEND THE ACRYLIC (PINOY STYLE) yeahh! :hehe:
    Oven Toaster :jawdrop:
    waiting to melt the acrlic
    I use it for my Reservoir maybe later I can post the finish product. :)
    Here's my HD rack.
  5. Rh1n0x
    Rh1n0x What's a Dremel?
    15 Nov 2004
    erm.. nice project. But what's up with yer avatar. Is it a band? or are you a bit 'freakish?'
    You scare me :( :eek:
  6. quadmodz
    9 Oct 2004
    Thanks. Talking about my avatar -->> :rock: a death metal fanatic :rock:
  7. tribaloverkill
    tribaloverkill Who needs sleep,... bah.
    1 Jan 2005
    Sweet project dude!!! Nice use of the oven toaster!!! Very genuine!! PINOY STYLE!!! LOL.
  8. tribaloverkill
    1 Jan 2005
    You know you can use a hair dryer to bend acrylic too.
  9. invalid
    invalid What's a Dremel?
    23 Jan 2005
    I used a normal old heat gun to bend mine.
  10. quadmodz
    9 Oct 2004
    Thanks dude! yah I use hair dryer for a very thin acrylic :D
  11. quadmodz
    9 Oct 2004
    Remember the Oven Toaster? :idea: here's what I promised...
    My reservoir
    I use Pioneer Epoxy All Purpose and Dark Green Paint. To make it as a Cammoflauge
    Here's some shots on the top of my reservoir
    My ThermalTake Aquarius II
    The Family. :D
  12. quadmodz
    9 Oct 2004
    Ok here we go.. I'll just to show off this paint that I use on my reservoir. :D
    That's it. Time to go to a mall and buy this bling bling for my watercooling :hehe:
    Box of Shuttle SN45G v2
  13. quadmodz
    9 Oct 2004
    here's the final output of my reservoir...
    I'll post some pics soon.. :)
  14. tribaloverkill
    1 Jan 2005
    Very morbid looking:) I would love to make a real theme like mod one day:)
  15. quadmodz
    9 Oct 2004
    thanks man! :) hope to work on my case tomorrow... :D
  16. quadmodz
    9 Oct 2004
    Its time to fix my rear panel and w/ my lower rear panel..
    see the line? need to cut it :)
  17. quadmodz
    9 Oct 2004
    here's my lower rear panel.. :D
    Need to sanding the edge of my mobo tray
  18. tribaloverkill
    1 Jan 2005
    Yea boy,... you file that to the line:) Yo QM,... you dont believe in acrylic cement? Also,... if you have a belt sander it works grea when you have to trim to a line:) Great job! Got you love that thick beautiful acrylic:)
  19. quadmodz
    9 Oct 2004
    Here's the acrylic that I use. Need to make a top panel for the 2x80mm fan only. just look for the pic. :D
    Cheking... :)
    I think that it was totally fit :clap:
  20. quadmodz
    9 Oct 2004
    HELLO!!! :)
    :hehe: lol
    Time to make a blowhole for the 2pcs. fan
