Project : THE KUBE
Discussion in 'Project Logs' started by sloeri, 28 Dec 2003.
  1. sloeri
    sloeri What's a Dremel?
    28 Dec 2003
    Yo all,
    i'm just started with a project named "THE KUBE".
    The designs are made in inventor.... the metalwork of the case will be made with a Laser and bend machine in our factory. It will be completely made in Aluminium.
    Please feel free to comment
    http://rallysport.ws/kube/kube1.jpg
    http://rallysport.ws/kube/kube2.jpg
    pics of the "real" metal will be posted asap....
    regards
    joeri
  2. sloeri
    28 Dec 2003
  3. sloeri
    28 Dec 2003
    BIG UPDATE
    Alot of pics you MUST see :)
    the kube being put together.... well the inner layer....
    http://rallysport.ws/kube/kube8.jpg
    http://rallysport.ws/kube/kube9.jpg
    http://rallysport.ws/kube/kube10.jpg
    inner layer complete
    http://rallysport.ws/kube/kube12.jpg
    Have a look on the inside....
    http://rallysport.ws/kube/kube13.jpg
    Please have a look at this front side view.... ( the parts in it are just to have a look if the holes where the correct size... a floppy i did not have in spare
    http://rallysport.ws/kube/kube14.jpg
    http://rallysport.ws/kube/kube15.jpg
    A view of the kube as it will look like.... not everything is been screwed and tightend off coarse, but for you peeps to have a glance of the finished look
    http://rallysport.ws/kube/kube16.jpg
    A topside view....
    http://rallysport.ws/kube/kube18.jpg
    2 pics to show what i meant with the double encasing and the special space for the UV lights :)
    http://rallysport.ws/kube/kube19.jpg
    http://rallysport.ws/kube/kube20.jpg
    Note : This is NOT the finished thing yet.... not nearly even, the inside needs to be painted in blue Uv reactive paint... everything needs to be thouroughly cleaned, etc etc .... please feel free to comment or give your opinion....
    i have just put it together to give all of you a glance of how it will look.... but with all the visual goodies that still need to be added the finished thing will look 500% nicer....
    i'm now at the stage of a 15% finished thingy....
    greetz
    joeri
  4. NexteR
    NexteR What's a Dremel?
    6 Nov 2003
    cooooool, that looks nice man.....
  5. bsodmike
    bsodmike Banned
    11 Oct 2002
    :rolleyes: :rolleyes: :rolleyes: :rolleyes:
    Would it be too much to ask for the images to be resized and maybe embedded :p ?
  6. ajack
    ajack rox
    17 Apr 2003
    Agreed with Bsodmike - embedded images are preferable
  7. sloeri
    28 Dec 2003
    here you go :)
  8. ajack
    ajack rox
    17 Apr 2003
    Like it a lot - did you cut the design into the top of the case yourself?
  9. naelq
    naelq What's a Dremel?
    14 Oct 2003
    woooooooooooooooooooooooooooooooooooooooow! :jawdrop: :clap:
  10. sloeri
    28 Dec 2003
    the top of the case is indeed cutted by myself... but with the help of a high powered laser machine :D :dremel:
  11. STellY
    STellY What's a Dremel?
    24 Aug 2003
    wow, im subscribed already..... especially if its nowhere near complete :)
    i love your whole double-layer cube design! ive never seen it done before and it will make some of the sweetest lighting effects!! it really looks AWESOME
    keep up the great work
  12. sloeri
    28 Dec 2003
    just for the info :p
    I'm going to put UV Lights into the "double side" in the front... this will give some sort of a backlight effect wich should be beautifful... also on the top side i will place a blue or Uv neon to light the inside up aswell as a lighted fan wich will be located at the center of the top side (you can see that the holes for the screws are already been made) all wires... (well most of them) will be invisible since i will let them go through the double side off coarse since that was the purpose of the double side....
    the innerside of the kube will be painted in Uv reactive blue, outside stays in the alu.... (but it needs to be cleaned off coarse... lots of fingermarks at the moment :D )
    The drives (DVD writer, and the fanguards, plus floppy drive) also need to be modded.... but i don't have a clue yet what i will do with them :dremel:
    The Power and reset button need to be drilled out ( i did not foreseen these holes since i did not had the buttons at that moment.... as a matter of fact i still don't have them... but i would like to fit a master switch alike from an airplane or something... you know the kind of switch with a red lit on it... i think it would give the whole thing some more punch :clap: i would place it on the right side next to the drives...
    hope you like it peeps :D
    greetz
    joeri
  13. borumas
    borumas What's a Dremel?
    22 Sep 2003
    He, he, like I said in the other forum, great job! :thumb:
  14. sloeri
    28 Dec 2003
    yup indeed :) great to see ya here :naughty:
    greetz
    joeri
  15. Wicked Li'l Bender
    Wicked Li'l Bender What's a Dremel?
    9 Nov 2003
    getting my daily recomended allowance of Alu.
    Have you thought about anodizing the thing and then having it dyed uv reactive blue? then you just need to boil it to seal the finish... would be a heck of a lot more durable than spray... and then there are the bragging rights...
  16. sloeri
    28 Dec 2003
    Re: getting my daily recomended allowance of Alu.
    having it anodized is an option indeed :) only thing is that i need to find someone who is able to do it in my region :) but i think i will... i have a lot of mates in the industry who can help :D :hip: :naughty:
    but what the heck do you mean with "the bragging rights" ????? :confused: is that some brittish language twist ? :duh:
    greetz
    joeri
    :thumb:
  17. MrTroy
    MrTroy What's a Dremel?
    15 Dec 2003
    what are your plans with the cdroms?
    im wondering what a good way to incorporate them more into the case
    similarly i want to have a plexi front, and want to incorporate the drives a little more...
  18. borumas
    22 Sep 2003
    Thanks, I have a project posted here as well, check it out if you get a chance. I think anodizing that cube would be very nice as well.
  19. pranks7er
    pranks7er mange tout
    25 Dec 2002
    likeing that top of case!!!!!
  20. Ravid Flux
    Ravid Flux What's a Dremel?
    2 Aug 2003
    fix your pix bro... :sigh: I want to see what all this ranting and raving is about.
