Scratch Build – Complete ⭐ Project - The Next Level - Winner MOTY 2012 -
Discussion in 'Project Logs' started by Paslis, 4 Jan 2012.
  1. Paslis
    Paslis Minimodder
    13 Jun 2011
    Hi Everyone,
    Its time for another project.My idea/design to build a desk inside a frame with a glass top and without feet ive done 2 times.
    Version 1.
    Version 2.
    I dont want to make a third version so now its time for a new design.This time i go for an ergonomic design.So this is the kickoff for my new project The Next Level.
    The idea is to build a design desk that can be adjust in height so everyone can sit at it by simply push a button to move it up or down.My designs always change when im building so here a drawning how its gonna look.
    The desk will be watercooled and the hardware is not decided yett.More about this later.
    I already bought the lifting column and this is how it looks.
    The specs.
    • Thrust: up to 2500 N per DL2
    • Speed: up to 20 mm/s with CBD4
    • Installation dimensions can be seen in the
    ordering example
    • Stroke length 300 mm, 350 mm, 500 mm ± 4 mm
    • Colour: Natural anodized aluminium profiles and
    black painted end plates or electro-galvanised
    3 mm end plates
    • Low noise level
    • Compact and mounting friendly design
    • Built-in limit switches (not adjustable)
    • Dimension column: 147 x 194 mm
    • Dimension 8 mm end plates: 160 x 244 x 8 mm
    • Dimension 3 mm end plates: flush with the
    profiles
    • Each column is fitted with a 740 mm ± 60 mm
    straight black cable with an 8-pole AMP plug or
    100 mm mini-fit cable
    • Dynamic bending moment (at 100% stroke
    length):
    My+/Mx+ = 250 Nm and My-/Mx- = 200 Nm
    And a little movie how it works.
    http://www.youtube.com/watch?v=61hPwaFKs1E
    Sponsored by:
    My head is full of new ideas so more to come. :D
  2. Monsieur R.
    Monsieur R. In cornichons I trust.
    1 Dec 2011
    "Why moving when your computer can move for you." :D
    Awesome concept ! I hope it will turn as good as Flipmod did. Good luck :thumb:
  3. l3p
    l3p www.^.nl
    1 Nov 2010
    Will certainly follow it!
    I love this "kid-proof" desk :)
    yassarikhan786 likes this.
  4. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks mate and you will see.:D
    Thanks Peter but i hope you dont fall in love with this one like you did with my first desk because i dont want to be the reason you cant sleep again. :D
  5. Cheapskate
    13 May 2007
    I can see your future already: Adjust table, adjust chair to table, adjust monitor, adjust table again.:lol:
    It should be a cool project. Your other builds were fun.
  6. l3p
    l3p www.^.nl
    1 Nov 2010
    Who knows, but doubt there will be anything to improve :thumb:
  7. Paslis
    Paslis Minimodder
    13 Jun 2011
    There is always something to improve thats why i made a second desk of my first design and maby whit this one also.Who knows. :D
  8. l3p
    l3p www.^.nl
    1 Nov 2010
    Goodluck with it! Want to see you as a MOTY nominee next year!
  9. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks Cheapskate and yes maby my next project will be a chair. :D
    Thanks and who knows. :D
  10. bond0071993
    bond0071993 What's a Dremel?
    9 Jul 2011
    Great build:jawdrop: but wouldn't be better monitors to stay on the desk:idea:
  11. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks and no you gonna see later on what i came up with. :D
  12. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 1 - 21-01-2012 -
    Finally its time for an update.The past 2 weeks some things happend.I got my first sponsors for this project and i changed the design.
    Cooler Master sponsored me a silent pro hybrid 1050W and its fully modulair.
    http://www.coolermaster.nl/
    Some pictures of the psu.
    Thanks Cooler Master and specially Marco.
    Also the company i bought the lifting column from has decided to sponsor my project with a second column.
    http://www.linak.com/
    Here a picture wiht both lifting columns.
    Thanks Linak and specially Adwin.
    Because i was afraid of instability i changed my design.This is the final design.
    This week i cut the desk and the side pieces with the lasercutter and i made a little movie.
    http://www.youtube.com/watch?v=BJEjW9se0xk
    Below are the pictures of the pieces i cut.I used 3mm aluminium.
    Today i bend the piece with a co-worker ( the guy on the picture ).
    Then i spot welded the piece together.
    The next thing to do is to spotweld these 2 pieces in the desk and then finsh the welding.
    This was it for today.
  13. Waynio
    Waynio Relaxing
    20 Aug 2009
    Love your ideas & work Paslis :rock: & I did wonder who did the uber desk first, now I know :D.
    I call this kind of quality of PC in a desk an uber desk :rock::lol:.
  14. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Cool project mate.
  15. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thank you very much Waynio. :D
    Thanks mate.
    Phyonics, yassarikhan786 and Waynio like this.
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    Forgot to add 5 stars & rep :D.
  17. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks for the stars and rep mate. :D
  18. bugbear974
    bugbear974 What's a Dremel?
    31 Jul 2011
    Desk desk desk only desk every where it's contagious! but really good too^^
  19. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks mate and i love to design them maby after this one im making a compleet different project but for now im having an ball. :D
  20. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    The work (again) is so clean!
    I am loving it already !
