Scratch Build – Complete ⭐ Project - The Next Level - Winner MOTY 2012 -
Discussion in 'Project Logs' started by Paslis, 4 Jan 2012.
  1. Phyonics
    Phyonics What's a Dremel?
    4 Oct 2011
    lol :thumb:
    I prefer option 1 too :)
  2. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
  3. whyte
    whyte What's a Dremel?
    27 Mar 2012
    Since the "fins" on the reservoirs are all even, option 1 matches better.
  4. Paslis
    Paslis Minimodder
    13 Jun 2011
    To be honest i didnt know what OCD means so i had to look it up and it gave me 4 options.Oxford Classical Dictionary,Ordo Carmelitarum Discalceatorum,Operational Concept Description or Obsessive-compulsive disorder so i guess its the last one. :D
    I have to agree style 1 does it for me. :D
    Thanks Waynio and im happy for you that you have the tweaked version of OCD. :lol: :D
    Thanks guys and indeed option 1 matches better. :D
  5. Redd13
    Redd13 What's a Dremel?
    28 Jul 2011
    Oak = awesome
    Nice work.. watching with anticaipation
  6. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    Well you don't have to worry about rusting! That is a great welding job on that little box. Stainless Steel is really tough to work with. Great work, I like the design.
  7. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks Redd13.
    Thanks Cleveland216.
  8. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    This is purely awsomeness !
  9. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks a lot KoSoVaR^. :D
  10. matiss
    matiss Minimodder
    24 Jun 2010
    Thats so effing sweet and hot...i wanna hump it...and if its only that you dont want it afterwards and hand it over :D
  11. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks and you wont get a chance to hump it. :D
  12. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Subbed - remind me to read the entire worklog later, mmmmkay?
  13. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 22.
    Last saturday i finisht the last cover.I could make a new one but i choose to fix the old one.
    First i cutt the cover to the right lenght.
    Then i cutt a piece of 2mm aluminium.
    Spotwelded the piece on the cover.
    Because the cover is 800 mm long its not wise to weld it in 1 time because you end up with a banana.So i welded the cover with small steps.
    Some sanding and the cover is done.
    Test fitt.
    To get acces to the aquaero i had to cutt out a piece from the backplate.
    Thats finisht to.A few days back i have received my fittings and im not using tube but im gonna use stainless steel 10mm pipe.
    The fittings.
    The pipe.
    I also did a leak test and its all good. :D.
    So soon i can get started with the cooling and i also have my hardware compleet now.I will make pictures from the hardware soon.
    More to come.
    Thanks to my sponsors :
  14. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    ... speechless! the hard pipes is going to be fantastic! :D is about ~2 months since i last visited the project and wow! just keeps getting better! :)
  15. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Nice work coming together great. Wondering would you consider doing a tutorial on using hard pipe what fittings work best how to connect them to pipes etc I am and sure others are interested in using hard pipe for mods :dremel:
  16. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks kelmannen and yes things have changed after 2 months. :D
    Thanks bluc and yes if i can find some time i will give it a go.I wish a day had 48 hours that would be great. :D
  17. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Wonderfull work man!
    Are you ready for Campus party? :D
  18. Ace_finland
    Ace_finland Minimodder
    11 Aug 2012
    just.... WOW
  19. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks p0Pe and well the frame is ready just have to clean the desk and put new fluid in it.So yes i will be ready soon. :D
  20. alain-s
    alain-s Minimodder
    12 Jan 2011
    Very nice Pascal cant wait to see the loop in de your desk. :D
