Scratch Build – Complete ⭐ Project - The Next Level - Winner MOTY 2012 -
Discussion in 'Project Logs' started by Paslis, 4 Jan 2012.
  1. Asouter
    Asouter --------
    18 Jan 2012
    Damn I wish I had access to a workshop like that .... err well maybe not it'd be wasted on me , great skills mate
  2. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks myrizzle and i made 3 in total so i have 2 left maby you are interested in 1. :D
    Thanks AnG3L. :D
    Thanks waynio. :D
    Thanks mate but 7 is enough for me. :D
    Hehe my tought Cheapskate. :D
    Thanks mate. :D
    Thanks craig and that depends on how it looks when all stuff is build in.Its mounted whit screws so i always have a chance to fill the corners. :D
    Thanks Selfmindles. :)
  3. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks Asouter. :)
  4. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 7 - 11 March 2012
    Last week i received a very nice package from Noiseblocker with the multiframe casefans for my desk.Noiseblocker sponsord me with a huge discount.
    The package with the multiframe casefans.
    Thank you very much Noiseblocker and specially Andreas.
    This weekend i made the bracket for the column to mount my lcd panels.First i collected all the materials i needed and cutt,drilled and welded them.
    All parts are finisht.
    Now its time to putt them together and mount the bracket onto the column.
    Now thats finisht i can mount the panels and this is how it looks.
    I also made a short movie of the panels in action.I was suprised how smooth they move.The column makes no noise and it lifts the panels roch solid.
    http://www.youtube.com/watch?v=m0XynjDsLlU&feature=g-upl&context=G29c5dd2AUAAAAAAAAAA
    This was it for today and more to come. :D
    Waynio likes this.
  5. Cheapskate
    13 May 2007
    :lol:Someone want's a hug. Slick work.
  6. peteski
    peteski long live the pc
    8 Jun 2011
    you make it sound so easy lol . looking good mate love them two screens :rock: :rock: :rock:
  7. Asouter
    Asouter --------
    18 Jan 2012
    Very smooth, loved the vid. Does the column have a lower limit ? Those panels would look even better if they went low enough to hide behind the desk. The visual impact of them appearing from the back would be stunning. Love the engineering on your build:rock:
  8. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    And HOW did i miss this!?!?!?!? Fantastic work mate! Have done a little tig welding, sell the machines so need to know what im selling... :) Have also worked as field mechanic so there i used a lot of arc welding in steel but not much tig, that's is to bad because i wan't that knowledge now and need it to build alu stuff :p
    At my work we just call those rivets (the threaded ones) pop-nut :p that might be becuse in swedish the common name for a rivet is pop-nit (nit=rivet) and then pop-nut comes very handy even tho it's english :p
    do you still have some leftover pci bracket?
  9. myrizzle
    myrizzle What's a Dremel?
    23 Nov 2011
    They call them pop-nut in Denmark too :)
  10. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    :D I see you mounted a back plate cover, very clean.
    Slick adjustable arms and the new column mounting looks so much nicer. Good work mate. :)
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    Superfine work Paslis & that monitor setup is pure cheesecake :D & then the super smooth motion of the lift, man :jawdrop: this really is a dream rig dude. :clap:
    Really fitting name for the project. :rock: rep
  12. Paslis
    Paslis Minimodder
    13 Jun 2011
    Didnt see it that way but your right it needs a hug. :D Thanks Cheapskate. :D
    Thanks peteski and it was allot of work. :D
    Thanks Asouter and i can lower the bracket but the dimensions of the desk are to small to lett the panels hide.
    Thanks mate and good to hear you did some welding also.Thanks for the swedish lesson and i have 2 pci bracket leftovers. :D
    Nice to know. :)
    Thanks craig and your right about the new column mounting it looks indeed better. :D
    Thanks Waynio.I am very happy with the end result and im still impressed with the motion of the lift.The panels didnt move at all. :D
  13. Korvus
    Korvus May contain traces of sanity.
    14 Apr 2011
    Very neatly done, very impressive :D
  14. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Amazing work as always there Paslis!!
  15. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks mate. :D
    Thanks quizz-kid. :D
  16. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 8 17 March 2012.
    Today i started with the foot for the desk.Im gonna use a frame with plastic feet and 2 mount plates for mounting the columns.On top of the frame there will be a cover.
    First i cutt the pieces im using for the frame.
    Then i drilled the holes for the M8 rivet nuts and put them in.
    These are the plastic feet im gonna use.
    Then i drilled the holes in the mounting plates for the columns.The holes are 12,5mm and thats the hole i need for a M10 stainless steel welding nut.
    Welded the nuts.
    All parts are finisht so now its time to put all the pieces together.
    Then i mounted the plastic feet and the frame is finisht.
    KoSoVaR^ and peteski like this.
  17. Waynio
    Waynio Relaxing
    20 Aug 2009
    That is an awesome pile of progress, :jawdrop: think my motivation is really high now to get back onto doing mine. :D:rock:
  18. peteski
    8 Jun 2011
    i did wounder what the hols were for and now i know great work +rep to you
    KoSoVaR^ likes this.
  19. kelmannen
    5 Feb 2011
    he's workbench is a jig-table, usually used to reproduce stuff very exactly, but somtimes also used as a mountingtable for welder (as in this case) :p Downside is that they are VERY expensive... '-_-
    I guess he also have a couple of extensions to "build" things in 3D?
  20. Paslis
    Paslis Minimodder
    13 Jun 2011
    Yeah i know it was a good day.:D Go for it mate. :D
    Thanks peteski. :D kelmannen's explanation is right so i dont have to tell anything more. :D
    Your right kelmannen and i also have some extensions. :D
