Scratch Build – Complete ⭐ Project - The Next Level - Winner MOTY 2012 -
Discussion in 'Project Logs' started by Paslis, 4 Jan 2012.
  1. Shurika
    Shurika Minimodder
    9 Mar 2012
    epic project!!! 5 stars & subed! One question: I have not used Noiseblocker fans ever, are they realy very quiet?
    sorry for my English
  2. myrizzle
    myrizzle What's a Dremel?
    23 Nov 2011
    Noiseblocker are the best fans out there, IMO atleast. And iv'e tried alot :) But theyre also pretty expensive..
  3. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks Shurika. :D Well you have them in different speeds with different dBA.I think they are really silent.
    Indeed myrizzle. :D
  4. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 9. 25-3-2012
    Yesterday i find out i was totaly of with a measurement of the desk foot.Luckely it was simple to fix.Today i went back to the shop to work on the desk because i really wanted to test de columns.
    First i drilled the holes for the columns into the desk body and the holes for the column covers.
    Now its time to put it all together.First i mounted the feet for the desk foot.
    Then it was time to mount the columns.
    After that i mounted the body on to the columns.
    Then i mounted the frame for the panels etc to the desk body.
    Time to put the wires in place.
    Time for testing and here is a small movie of the test.
    http://www.youtube.com/watch?v=BH9GDNVrnQ0&context=C4b84163ADvjVQa1PpcFNzeGYfOzfyguZ1ppuglTZqiyO8loyjo1k=
    This was it for today and more to come.
    Thanks to my sponsors :
  5. voigts
    voigts What's a Dremel?
    26 Apr 2006
    Your desk/mod is looking sweet. I do wonder though on a practical level how much you will actually use the ability to raise and lower the desk. It seems to me that you would tend to find a comfortable height and stick with that.
  6. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Altogether now that looks sweeeeeeet. Great proportions too. :)
  7. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Party trick maybe :lol: I´ve been wondering the same. Not that there have to be a practical reason for everything... Up and down might be good against repetitive strain injurys though :lol:
  8. Cheapskate
    13 May 2007
    I'm guessing there will be preset settings for the Wife & various munchkins.
  9. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    I would guess it's main use will be to switch from sitting to standing position. I got this feature at work and my back loves it after several hours curled up on a chair.
    And Paslis, this is a truly amazing project. Your metal work is truly amazing, Im pretty shure everyone here on this forum wish they could have your skill and acess to that workshop aswell.
    Im really looking forward to see this one finished, but make shure it will take a long time because I want to have time to enjoy all the awesomeness.
  10. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks voigts and my wife and 2 kids will use the desk also so i guess it will move more then i expect.
    Thanks craig. :D
    Makes me think. :lol:
    Makes me thinking again.I think i can use this desk for allot of things. :lol:
    Your right about that Gnu.Here is a short movie with the same column and were you can use it for.
    http://www.youtube.com/watch?v=61hPwaFKs1E
    Thanks for the compliment and this project is long from finisht. :D
  11. peteski
    peteski long live the pc
    8 Jun 2011
    looking good mate keep up the good work :rock: :rock: :rock:
  12. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Damn you and your welding skills! :p
    Oh, and the design is not half bad either! :thumb:
  13. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    I think you should massproduce theese ones at the factory ^^!
    It looks great!
  14. Karrek
    Karrek Minimodder
    7 Jun 2011
    I can definitely see the sitting and standing configurations. Also lowering it for children would be useful. Also, if you had a large monitor, it could become like an adjustable entertainment center - i.e. raise it for viewing from a nearby couch or bed.
    Looks like a lot of fun - and thanks for the video...the visual is very helpful!
  15. voigts
    26 Apr 2006
    I hadn't thought of the convenience of being able to adjust it for your wife and kids. Hmm, then again, it may not be a good thing if it is so convenient as you may have to take a number to get to use your own desk!
  16. thegyufi
    thegyufi What's a Dremel?
    21 Mar 2011
    lol +1 voigts, I think you must use a pasword to control the acces
    Amazing work by the way, I which I could use the same tools :D
  17. Trevor28
    Trevor28 Where is the cow?
    17 Feb 2012
    This is fantastic. I look forward to seeing the finished build.
    JBond and PingPong like this.
  18. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks mate. :D
    Thanks mate and no sanding this time. :D
    Thanks for your compliment mate. :D
    Thanks Karrek and your right it has multiple use. :D
    Well they hardly use my current desk so i think they will use this one not much more.
    Thanks thegyufi and there are desks now that can be programmed.You walk towards the desk and sit down and typ your name and the settings will adjust like you have enterd them. :D
    Thanks Trevor.
  19. Waynio
    Waynio Relaxing
    20 Aug 2009
  20. bulldogjeff
    2 Mar 2010
    This thing is just crazy...Love it, can't wait to see it all finished.:clap::clap:
