Project: ~~tHe tUbE~~ *updated 03~25~06*
Discussion in 'Project Logs' started by -=tHaRgOr=-, 3 Feb 2005.
  1. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    German: danke werd mal suchen gehen. sitze im ausland aber wir haben bauhaus hier. hoffe das sortiment ist so wie in deutschland : German
    keep it up and us updated :D
  2. -=tHaRgOr=-
    -=tHaRgOr=- What's a Dremel?
    21 Jan 2005
    help
    Hi modders
    I need your help...I looking for this PSU
    its an ULTRA 500W X-Connect Power Supply. But I think its only to order in USA or Canada. I cannot find any seller in Germany or Europe.
    I found some retailer and this supply cost between $90-120, thats not the problem, but the shipping cost are too much..sometime about $40-60....thats to expensive.
    Have someone of you any idea where to buy in europe? In Germany or UK?
    Thx for your help..thargor :confused: :confused:
  3. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    i didn't find any uk sites that sold that psu, when i was looking for it. I hjad to buy from the US. bought it from www.frozencpu.com. I am very pleased with it btw. it is quite quiet, but I can definately hear it when I run the fans on my WC on low speed.
  4. DigitalX
    DigitalX What's a Dremel?
    26 May 2004
  5. -=tHaRgOr=-
    21 Jan 2005
    THX
    @acid & digitalx
    thanx for your help....I see I have to order it in USA..damm... :wallbash:
    hehe ok...next week I will do more work on this mod....cu
    Thargor
  6. DigitalX
    26 May 2004
    Remember that there is different model for europe and usa, the voltage in europe is 230V?(in FINLAND it's 230V :yawn: ) and usa 110V? Of course there is the magic :duh: red switch for 230V>110V but not for every model(I don't know about this model).
  7. Ford Freak
    Ford Freak What's a Dremel?
    12 Feb 2005
    I have the non-uv version of that power supply. It is dual voltage so all you'll need is an adapter or new cord if you order it from the US.
  8. stu_69
    stu_69 What's a Dremel?
    11 Mar 2004
    This is a great mod made mate, keep up the good work. :thumb:
  9. -=tHaRgOr=-
    21 Jan 2005
    hi or good morning :duh:
    thx for your information..hm I thnk I have to ask for it..thats right!!
    cu th and gn8 :thumb:
  10. -=tHaRgOr=-
    21 Jan 2005
    hi
    sorry for the delay..but I have still some technical problems with my case mode. I have to order some material thats only use in kitchens, like that:
    Its an door elevator fitting. I use this one to lift up my MB chasis form the insde of the barrel up to the outside. I hope it will work :idea: so thats my "little"porblem and thats why I get so slowly forward with my case. :waah: .
    I hope end the end of the week I will post enough pictures to show how it will work...I hope so it will....
    so long..take care...thargor
  11. keir
    keir S p i t F i r e
    5 Oct 2003
  12. -=tHaRgOr=-
    21 Jan 2005
    going forward....
    Hi
    after few days without any posting I start the weekend now with many pictures.
    I told you that I had some technical problems...so you will see now why:
    here some parts I will need:
    2 holes insinde for the screws:
    Boreholes lower for M5 countersunk screws:
    so this is the easiest part :thumb:
  13. -=tHaRgOr=-
    21 Jan 2005
    ...next part....
    so
    2 pieces plastic cutt and bored
    bolted
    Drawer excerpt running in ball bearings bolted with the Motherboardchasis
    after that...fix all parts togehter...
  14. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
    i would recomend not getting the Xconnect PSU, but get the OCZ modstream, is much better :D
  15. -=tHaRgOr=-
    21 Jan 2005
    ...part three...
    at first 3 boreholes in the bottom of the barrel....
    bottom side up
    3 boreholes M10
    bolted
    all parts fix togehter...
    lift up :idea:
    more pictures the next days....to have you a look inside..
    cu Thargor :thumb:
  16. derbaum
    derbaum What's a Dremel?
    11 Apr 2004
    where did you got that gascylinderwhatever kind of thing from? i plan a tubic project 2 and need it therefor
    btw .. hier sind genug deutsche. die verstecken sich aber hinter schlechter englischer grammatik ;-)
  17. -=tHaRgOr=-
    21 Jan 2005
    hi
    thanx for your comment..but I don´t like all these unsed cables inside....so I look for a modular PSU like the UltraXConnect. :idea:
    cu thargor :dremel:
  18. -=tHaRgOr=-
    21 Jan 2005
    hmm...ok I write in german:
    [german]der Gasdruckzylinder ist von einem Küchenhersteller/bauer. Der sitzt an einem Türliftbeschlag für Mircrowellenschranktüren.. sieh auch obigen post!!!![/german]
    the gas pressure cylinder is from kitchen manufacturer. That sits at a door elevator fitting for Mircrowavedoors.. sees also above post !!!!
    thx Thargor
  19. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Nice, nice. Keep up the good work. :)
    By the way: Awesome ideas over there.
    [Language=German]Yep, seh' ich auch so. Keiner kann hier englisch, am wenigsten die Amis. :D[/Language]
  20. jopers1986
    7 Jan 2005
