Case Mod - In Progress Project Thief -Completed 11-2014 -2 CPUs,8 GPUs,4 Loops,6 Pumps,50 Fans,2TB SSD
Discussion in 'Project Logs' started by stren, 20 Dec 2011.
  1. stren
    stren What's a Dremel?
    9 Dec 2011
    Hehe np :)
    Will do!
    Chip arrived, motherboard and ram blocks don't come until tomorrow though.
    SSD is actually for my wife's rig. I don't have an ssd on my gaming rig yet. I only use it for games so I wouldn't see that much benefit from a boot drive. I use my workstation for web browsing etc as it's on all the time. I'd need a 512gb drive or so to cover my games, so I'm waiting for prices to come down more
    Batch on the 3930K is 3152B448, we'll see how it clocks soon :)
  2. peteski
    peteski long live the pc
    8 Jun 2011
    i have that same ssd the differenc in boot time's are unreal compared to a normal drive :rock: :rock: :rock:
  3. stren
    9 Dec 2011
    Yeah I think it should make a huge difference for her.
    Some blocks came in :)
    Nickel plexi because I want to run some red dye (on special occasions only for all you dye haters out there)
    Finished cleaning the TIM off the south bridge only to find a piece of tin foil with more TIM underneath. Weird.
    Pretty easy to install when the block is in two parts, the single piece blocks are much harder:
    VRM area:
    Full board:
    and one more:
    That's all for now
  4. peteski
    8 Jun 2011
    again that board is so sweet it make's my asrock look cheap :rock: :rock: :rock:
  5. stren
    9 Dec 2011
    Thanks peteski - the asrock board itself looks sweet though, they've really improved their designs :)
    With ram blocks now, the fittings aren't the final ones, just more for planning. I'm working with Monsoon free to see if something special will make the tube routing super clean ;)
    the ram blocks remind me of battersea power station:
    Now adding in the gpu makes it look ugly and busy :( The copper and green pcb really don't match. I called a nickel plating company to get a quote on plating both copper GPU blocks and it was $175 for both! So that's not going to happen. I may switch to the other acetal/copper block and paint the edge of the copper silver. I have another idea for the PCB ;)
    Much better with the gpu off again
  6. stren
    9 Dec 2011
    No comments? Come on bit-tech!
    Soo like I mentioned before I really didn't like the green/copper look clashing with the black/red R4E theme:
    So I started to paint the GPU with liquid tape - first coat:
    So here's how it looks now after two coats on both sides:
    You can see some of the texture here, liquid tape is hard to work with - either annoyingly thick, or very thin and see through:
    From this angle the texture isn't as bad:
    However it would look a lot better with a backplate, I'm thinking something like this, smoked acrylic with an etch and a couple of LEDs to light it from the side:
    What do you guys think? Feel free to photoshop up your own suggestions :)
  7. peteski
    8 Jun 2011
    i like it looks better than the liquid tape. what is that stuff anyway and is it safe :rock: :rock: :rock:
  8. xXSebaSXx
    xXSebaSXx Minimodder
    21 Aug 2010
    Liquid tape is safe; it is used for insulating electronic components. Think of it as a more flexible from of the black electrical tape you would normally buy in rolls. :D We use it quite often in the world of sub-zero benching for protection against condensation.
    And I agree; a back plate would look 100 times better.
  9. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    love this project!
    Q. Linux workstation, and the mention of 20 hour CAD sessions... what app do you use? Ares, VariCAD or Catia V6?
    Love to know, i switched to ubuntu a year ago for a native enviroment to run inkscape and gimp in but still require my windows box for solidworks which really ruins my productivity
  10. avolla
    avolla Mini Water Modder
    26 May 2010
    Love what you've done with this so far. I'm envious of your setup. The gpu waterblock does look out of place but it's not bad enough to really worry about. Can't wait to see how this build progresses.
    BTW Can you get a straight on shot from overhead of the board? would love to see how the inlets line up.
  11. stren
    9 Dec 2011
    Thanks - I do chip design, so the layout part of circuit design is similar to CAD, but only really 2D so very different to most traditional CAD tools.
    Here you go:
    Indeed - I got the idea from you subzero guys ;)
    The temporary parts came in to see if I could get some clean routing for the motherboard/ram/gpu loop:
    However it didn't quite work as expected- I couldn't get the 40mm extensions to work with the 5 way rotary snake, however a SLI connector did fit.
    Now I'm not sure whether to:
    - get two more sli connectors (I need this one)
    - use two compression fittings instead
    - get two of the bitspower crystal sli links to match better
    I should probably go with the cheapest as I'm hoping monsoon free's new design will solve the problem for me.
  12. peteski
    8 Jun 2011
    man that looks tight good work mate :rock: :rock: :rock:
  13. avolla
    26 May 2010
    Thanks for the pic. It looks amazing. I'm sorry if i missed it but what are your plans for the cpu? Keep up the great work.
  14. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    <3 the build!!!
    execpt only one GPU?! with that mobo i was expecting atleast a couple more ;)
    but otherwise an amazing build !! keep up the good work!
  15. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    Been following this for a while now, that looks watercooling looks amazing man, especially that last picture! Love the fitting from VRM to RAM block :D
    On your question on the backplate, I would suggest you try to make one! It would look alot better. Couldn't you just get a backplate from EK btw?
  16. stren
    9 Dec 2011
    The cpu will be on it's own loop with dual d5 strongs @ 24V and a mora 3 pro 140.9 radiator ;)
    Haha actually the full build has 5 gpu's. The half that I'm currently working on will have 2 8800gt's (workstation), the other half has 4 gtx480's (space heater/gaming)
    Thanks dude - glad someone likes that fitting - most seem to hate it - let me know what you think of the alternative tubing option below. It looks like I'll have to make the backplate myself, EK doesn't have any on there store, and I can't find any on ebay, so I'll have to do something ;)
    Alternative tubing option - gets busy when you add lines for the cpu loop:
  17. microsoftPerson
    microsoftPerson What's a Dremel?
    27 Dec 2010
    Are you going to try any other pipe colors? I really like the way this looks but I almost think clear or a tinted clear would look better because you could see more of the board through the tubes?
    Sorry - just my $.02.
    Thanks for sharing your project with us, clearly lots of hard work involved.
  18. The Alfred
    The Alfred What's a Dremel?
    25 Nov 2011
    I think with water cooling the less pipes the better, it'd look so awesome with just fittings!
  19. Bladesingerz
    30 Nov 2011
    I liked the other tubing layout better, maybe use some acryl piping? Some straight lines will make this look amazing.
    On the previeus picture you used some SLI connector going from the VRM to RAM block? If you continue somewhere allong those lines it would so badass!
    What GPU is that btw? That doesn't look like a GTX480?
  20. stren
    9 Dec 2011
    I wanted the red to provide a pop of color, with the case colors I didn't want people to think I was going another monochrome murderbox copy type thing.
    Yeah I agree - just hard to get the right fittings to work. The extender would have been sweet but the rotaries were just too stiff in the wrong places.
    The GPU is an 8800GT. This 3930K + rampage iv extreme combo is for the workstation side - the gaming side is a rampage iii extreme + 990x + 3x GTX 480
