Here is full item list for Project:Thor - Asus M2N32-SLi Deluxe Athlon 64 3800 Dual Core 2.0GHz L2 cache AM2 940 pin Western Digital WD740GD 74GB Raptor Point Of View 7950 GX2 512bit 1024MB PCI-E Creative SoundBlaster X-Fi Xtreme Music Hiper 580W Type-R Modular PSU - Black Lian Li PC-7 SE Plus Black Midi Tower Full Aquacomputer Kit of - Aquastream v3.5 Ehiem 1046 EMI Shielded Case for Aquastream / 1046 FMJ Aquabox 5"1/4 Water Reservoir Cuplex XT Block Athon64 Ramplex Block AquagraFX 7950GX2 Block Aquacomputer Evo 240 Radiator Aquacomputer aquaero v4 USB Green Aquero Multiswitch Aquacomputer Flow Sensor and small bits (wires, lights etc) and as a little present for starting Uni - Canon Powershot S3is 6.0 Mp Camera 12x Opical Zoom Question 1 - Can anyone recommend any DDR2 (1024 or higher), I am not going to overclock (too much ) so extremely overlockable memory need not apply Question 2 - With a Cuplex XT, Ramplex and GPU Block, will one 1046 Ehiem pump be enough?
Good job answering none of the OP's questions... Maybe some people just prefer AMD. If you aren't going to overclock, any RAM rated at the desired speed will do. Kingston, Corsair, Geil,... all have good value series... About the pump, I have no idea about that...
ideas If you go for the Innovatek 12V 1046 you will have more than enough power. I needed to add that they overclock the pump to over 130 gph. And I myself need answers on RAM help for mild to no overclock. but at least 2Gb so http://forums.bit-tech.net/showthread.php?t=117164 if you want to help me out as well. BTW I prefer AMD more power to you. I am waiting for the X2 5000+ AM2 to drop to $280 still at $750 online. Well good luck.
only if the power is in the heat form, not in the performance form, bah.... go for it!!!! if you like AMD buy an AMD. a X2 5000+ AM2 at $280 is a good price Point Of View 7950 GX2 512bit 1024MB PCI-E + AquagraFX 7950GX2 Block? nice , did not know that they made blocks for the 7950 GX2. i hope it rips the Aluminium of your Lian Li
One Aqua-Stream will be more then enough mine goes through the following: 1 x Cuplex Pro 1 x Twinplex 1 x 5" aquabox 1 x 3" aquabox 1 x Asus VRM cooler 1 x EVO 240 2 x AquagraFX Blocks 1 x Dual Aquadrive 1 x Flowmeter And doesn't even break a sweat One suggestion would be to switch the EVO 240 the the XT 240 rad as the XT has better proformance
When will the UK Prices for the AM2 fall as I can see that AMD X2's have already fallen in price? On ebuyer - An AM2 3800+ X2 is £199 inc VAT but a 4600+ X2 is £159? The Memory I hae chosen - A-data Vistesta DDR2-800 Extreme Edition £155.10 inc VAT (2x1GB) www.memory-configurator.co.uk CustomPC Magazine rated them quite high and are a good price for 2GB @hydro_electric_655 - Hope it helps!!! @Nitrix - Thanks I will be gathering the parts when I start at Uni and I should have everything by Christmas (Hopefully earlier) Over and Out OldY
Due to the increasing costs of going to university , I decided to go with a Core 2 duo shuttle as this saves on space as well. So its going to be: Core 2 duo 6300 Shuttle mobo Radeon XT1900XT 1gb Muskin Memory (From a friend) Samsung Spinpoint 300gb and no watercooling but I hope to do so next year I start getting parts when I start Uni!!!
