Scratch Build – In Progress Project "Tikki Aquarium" - [update 040707: piranha madness]
Discussion in 'Project Logs' started by thechoozen, 31 May 2007.
  1. thechoozen
    thechoozen Active Member
    9 May 2006
    this is what we have done today..... :dremel:
    first we covered the cables inside the head
    then we begin to build the base part, where the aquarium later should stand on and the hardware will be mounted in....
    we also tested if it is solid enough.... :D :D
    and we begin to make a plexiglas mounting plate for the DVD Drive which will hang under the Top Plate of the Basepart.....
  2. TNash
    TNash New Member
    12 Mar 2007
    interesting....
    awesome job on the airbrushing! I wish I had your skills.
  3. thechoozen
    9 May 2006
    today we finished the mounting plate for the dvd drive....
    as next we modified our mainbase that it can flip up on one side...that way we will always have an easy access to the hdd....
    then we made some small plexi mounting plates for the water reservoir. It will be mounted on the backside of the mainboard tray so that it can flip up with the mainboard when accessing the HDD.
    at least we tested if our construct would fit inside the our socket
  4. thechoozen
    9 May 2006
    this is the pci bracket which we gonna use for the backside.....just some sanding and polishing and it´s done....
    then we got 2 drawer excerpts which will be placed under the mainboardtray so that it can be easy moved inside and outside of the case
    as you can see, one side already fits perfect for our needs but the other side is a little bit too long...so we will get some other excerpts tomorrow and try which combination will be the best
  5. Supra55
    Supra55 New Member
    10 Oct 2006
    Nice bracket :hip:
  6. knuck
    knuck Hate your face
    25 Jan 2002
    im not sure where you're going with this, but i know i want to see the rest !
    It's very intriguing !
    GJ
  7. thechoozen
    9 May 2006
    today we got excerpts in the right dimensions so that we could build the mechanical part which we need to slide the hardware inside and outside of the case....
  8. thechoozen
    9 May 2006
    today we built the chassis for the hardware...we used bendable wood to make the outer wall and fixed it with a lot of screws and nails on our base construct with the hardware in it.....
    then we made a big hole in it where the hardware can slide through....but up to now its just a raw hole which will be brought into the right shape in the next days
    we also made the mounting points for our radiator which will be placed beside the mainboard.....
    i think later we will polish all aluminium stripes so that they look like chrome, but we will decide that later when the basepart airbrush is ready so that we can see the contrast first....
  9. gimmix
    gimmix New Member
    17 Dec 2006
    looking promising so far!
    can't wait to see it finished and all polished ;)
  10. thechoozen
    9 May 2006
    after a lot of polishing the pci bracket is now ready and already connected with the mainboard tray...
    then we already draw some of the details on the lower tube part which will be 3d shaped liked the head...
  11. dacust
    dacust What's a Dremel?
    10 Mar 2007
    Wow. That PCI bracket is awesome. If it had been thinner material I would have thought it was great, but the thicker stuff makes it so much better.
  12. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    This is really great. I like the wood detail!!! Can't wait to see more.
    Pfaffen
    _____________________________________________________________
    :clap: Case Mod: World Map - Complete
  13. MikeK
    MikeK Member
    6 Feb 2005
    Looks really funny and nice.
    Great work and good luck in the future!
  14. thechoozen
    9 May 2006
    hardware chassis
    thank you all!!!
    in the last 2 days we spent a lot of time building the hardware chassis and putting details on it.... i think you´ll now get a better impression what it will look like when its finished...
    beside that we made a small fan cover for the Northbridge Fan on the Mainboard....
    and we also made a small video of some parts of the building process....you can find it on youtube or here
  15. thechoozen
    9 May 2006
    today just a small update...
    we spent our time to bring some more details on the Lower Part...
    i think tomorrow we will begin to build the back door which will be curved like the rest of the case.....therefore we already begin to build a base construction on which we can nail the bendable wood but i will show you some more pictures tomorrow when it´s done....
  16. thechoozen
    9 May 2006
    in the last 2 days we spent our time building the back door for the lower part where the hardware will be integrated.....
    beside that we build a mounting hole for our aquarium on top of the lower part....and tested if everything fits
    as next we will put some details on the back door and start the sanding process so that we can soon start to airbrush the lower part....
  17. Tuppen^^
    Tuppen^^ New Member
    11 May 2007
    This looks great :D
    I love that air-brushing of yours *I want to learn to airbrush too* :p
  18. thechoozen
    9 May 2006
    thanks!
    in the last couple of days my internet connection was f***k up so i couldn´t post any updates....now that everything works again i have forgotten to take the sd card with the biggest part of the picture´s with me so i can only show you the mounted water reservoir and a first picture the paintjob on the lower part....
  19. thechoozen
    9 May 2006
    today we had a big family celebration (my grandma´s 70. Birthday...) so i can only show you some shots we take this morning during the next airbrush steps...
  20. pedrofilho
    pedrofilho New Member
    4 Apr 2007
    Nice work, keep going.
    Pedro Torres.
