Project: Timmee's gaming tower
Discussion in 'Project Logs' started by Timmee, 3 Oct 2005.
  1. Timmee
    Timmee Member
    12 Feb 2005
    First off, I'd like to say, as a first time modder, I was really nervous about cutting up a computer case, but the worklogs here and at [H]ardOCP have inspired me to take a chance. I've decided to mod my silver Lian Li PC-70, so that I can watercool my system. I'm looking primarily for silence, but since I want my case to look good as well, paint is in this case's future.
    My current system specs are:
    A64 3200+ socket 939
    Asus A8V Deluxe mobo
    1Gig corsair memory
    ATI X700 Pro AGP 256meg
    Liteon DVD-Rom/CD burner (currently stealthed in my Lian Li PC-60)
    wireless Linksys 802.11G card
    200Gig Maxtor SATA drive
    Fortron 530W psu
    stock cooling for the cpu, video card, and case
    What I have to add:
    Danger Den TDX waterblock (nozzle 4)
    weapon-- heatercore and shroud
    Laing DDC pump (may do 90* mod on this)
    3/8" Tygon
    T line and Danger Den fillport
    AquaComputer radiator grill
    Also, I hope to add a GPU block to my X700Pro (I'm currently considering the Maze4)
    Now, on to the pics:
    Masked and ready to cut
    Holes drilled for the jigsaw, and cutting started
    All cut, just needs some filing
    Oops, not so fast! Jigsaw blade got stuck in the work, and bent one of the middle mounting ears (fixed by gently bending it back, but the AC grill covers it anyways)
    Paint will probably be some sort of blue, but it's not definite. If you have any feedback or suggestions, they'd be appreciated. Discussion thread is: http://forums.bit-tech.net/showthread.php?t=99326
  2. Timmee
    Timmee Member
    12 Feb 2005
  3. Shadowed_fury
    Shadowed_fury Active Member
    21 Nov 2003
    First mod eh? Damn good start! Keep it up!
    And, the Maze4 is a good block for GPUs ;) (though I prefer the looks of my PolarFlo :p)
  4. Timmee
    Timmee Member
    12 Feb 2005
    Small update for today. Still deciding on some things (such as paint, the possibility of a window, etc). Anyways, here's some pics to show some progress.
    The AC grill and Panaflo fans mounted to the top.
    A piece I made from 26guage steel, to hold the radiator to the shroud.
    Color testing on a scrap drive bezel (from a Skyhawk case).
    A closeup of the bezel (Dupli-Color Metalcast Blue).
    I don't like how the paint turned out, so I'll be looking at other colors the next time I go to Wal-Mart or AutoZone. I also didn't like how the 26guage piece came out, as it's very flimsy. I'm probably going to see if I can get a suitable piece water-jetted out of a thicker guage aluminum, as well as a replacement psu plate (so I can have a 120mm fan there, instead of 2 80mm fans).
    As before, if you have any comments, feel free to post them here: http://forums.bit-tech.net/showthread.php?t=99326
  5. Timmee
    Timmee Member
    12 Feb 2005
    I'll definitely try. :) The PolarFlo GPU block does look pretty nice, but if I don't end up with a window in my case, the look would be wasted. It's another block to add to the list of possibilities, though.
  6. Timmee
    Timmee Member
    12 Feb 2005
    Alright, so I've been slacking on this case. It wasn't completely my fault, as a water line burst in my apartment, necessitating a move that stressed me physically, mentally, and financially.
    One of the things I did on my break was I've decided to not put a window in my case. I'm going to try for silence, which means I'll probably add some sort of soundproofing material to the case. I also am looking into the possibility of converting the PC-70 to use 120mm fans front and back. Also, I won the auction for a Danger Den Acetal top Maze 4 gpu block, which should finish up most of the major purchasing on the WC front. Finally (for this update), I'll be attempting to incorporate a PSone LCD into the front of my case. I've got a Matrox video card that I'll be driving the LCD from, and it will be converted to VGA. I don't have many pics right now, but I do have some (the Sony camera I was using before being a casualty of the aformentioned flood, so I'm using my old Olympus).
    The Matrox video card auction
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3762&item=8715868932#ebayphotohosting
    The card after some "modding"
    A closeup of what was done (sorry for the fuzzy image, I miss my Sony)
    Paint is still up in the air. :sigh:
  7. Timmee
    Timmee Member
    12 Feb 2005
    Well, I've done some planning today for how I want to convert my case to 120mm fans. As far as the PSU plate, I'm going to see if SilverPCs can order a PC-7077 PSU plate, as (from the pictures I've seen), it's exactly what I'm looking for. I'd mentioned in an earlier post about the possibility of getting some parts water-jetted, but I don't think I'll be able to do that for this project. Instead, I'll be using my jig-saw and files to get the pieces I need made. Ordered the metal today:
    Here's the "washer" I need to make to hold the radiator to the shroud (similar to the one shown in the second post, second pic):
    Hopefully, I'll have more progress tommorow. As always, any suggestions or other comments can be posted to my discussion thread: http://forums.bit-tech.net/showthread.php?t=99326
  8. Chrizzle
    Chrizzle New Member
    6 May 2004
    Really great start. What program is that in the most recent post? Looks useful.
    P.S. Keep up the great work.
  9. Timmee
    Timmee Member
    12 Feb 2005
    Thanks for the encouragement. The program I used to draw the "washer" is Rhino3d. It's relatively easy to use, and it's free to download the evaluation version (which is fully functional), but you only get 25 saves with it. So far, I've only used 2.
  10. Timmee
    Timmee Member
    12 Feb 2005
    Well, I finally got some of the parts in I was hoping for. The Maze4 GPU block and PSOne LCD I picked up on eBay, and the 2mm (.08") aluminum came from OnlineMetals.com cut to shape. I'll be using 1 piece in the front to cover the 2 80mm fan holes (afterwards, I'll cut a 120mm fan hole), 1 piece to cover the back of the case (from the bottom of the psu plate down, and cut out for the backplane and another 120mm fan hole), and the final piece will be used to create the radiator "washer" as decribed in the post above this.
    Anyways, on to the pics.
    Picture of the metal recieved from OnlineMetals.com, already cut to approximate size:
    The Danger Den Maze4 block I recieved (soon to have an low profile acetal top and 1/2" barbs):
    The PSOne LCD (still factory sealed, but won't remain that way long):
    The aluminum piece that will cover the 80mm fan holes in the front:
    The aluminum piece that will end up on the back of the case:
    Pattern layout and cutting should be this week, hopefully with an update shortly after.
  11. Timmee
    Timmee Member
    12 Feb 2005
    Well, life got in the way, so I haven't accomplished much this week. I did however, work on my PSOne lcd. I seem to have found pretty good timings in powerstrip, however my display has a blue tinge to it. Hopefully scouring the PSOne discussion thread will reveal an answer for that.
    Hopefully, I'll have something pic-worthy today or tommorow.
  12. Timmee
    Timmee Member
    12 Feb 2005
    I really wished I could find some time to work on this project, and (rather unfortunately) my wish was granted. I slipped and fell on some black ice (injuring my left knee), and as a result I'll be out of work for at least 2 weeks.
    Anyway, on to some good news. I sorted out my PSOne LCD issues, and the display looks great. The wiring, on the other hand, is atrocious. I'll be spending some time, shortening the wires, heatshrinking the ends, and adding a connector for easy disconnects.
    I know the pic is crappy, but until I get my Sony back, it's all I've got. As always, if you have any suggestions, feel free to add them here: http://forums.bit-tech.net/showthread.php?t=99326
  13. Lemmingzappa
    Lemmingzappa New Member
    8 Nov 2004
    Nice work so far keep it up ! I love that blue colour, looks really nice.
    Im also looking forward to what you'll be doing with the LCD Mod.
    Good luck.
  14. Brett89
    Brett89 Active Member
    15 Dec 2005
    This is fast becoming one of the cases I wish I had.
  15. Timmee
    Timmee Member
    12 Feb 2005
    Thanks for the encouragement. While I'd love to make a bezel to put it in the 5/14" bays, I don't know if my fabrication skills will allow me. I'll probably end up putting it in the 3 1/2" bays instead.
    I really like the size and layout of the PC-70 (just a few things I wish were different, like 120mm fans). I picked mine up used on eBay, for $86 + shipping.
  16. Timmee
    Timmee Member
    12 Feb 2005
    Well, I (finally) have a text update today. I cut out the retaining plate for my heater core (previously referred to as the "radiator washer"), and filed the cuts as best I could. I also started fitting the fan plate to the front of the case, and will (hopefully) finish tommorow.
  17. Wolfe
    Wolfe New Member
    7 Sep 2003
    Be careful. If i remember correctly, you need to use a special primer if you want lasting paint on aluminum. I think it's an acid etch primer.
    Pretty damn good for a first timer.
  18. skeletor
    skeletor modder in the making.
    29 Nov 2005
    from what i have heard on aluminum all you have to do is sand it, cuz it comes with some sort of coating on it, where the paint could peel off after time, but if you just sand it it works fine, and always has for the tons of other little aluminum things i have done. but i could be wrong. this is just what i have experienced.
