Scratch Build – In Progress Project: TinyTux (FINISHED - 10 Jul 07 @ 03:00)
Discussion in 'Project Logs' started by Soulmage, 5 Feb 2007.
  1. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Do you have a pic you could post? or maybe a model number that i could lookup? if it works that would be awsome!
  2. BigM2006
    BigM2006 What's a Dremel?
    8 May 2006
  3. Bluefan
    Bluefan test 123
    25 Feb 2005
    Those drawings are cool!
    And indeed, the first time I saw those batteries, it reminded me of a bomb, even before you mentioned it :D
    Keep going :thumb:
  4. axscpu
    axscpu What's a Dremel?
    2 Jun 2006
    great desing looking foward to see it done... what will you be using the server for??? and why didn't you go with micro atx and dual core so you could have a fully fledged pc...just curious
  5. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Basically because I had the laptop laying around. The screen became unusable quite a while ago and its already a decent setup. Pentium M 1.3GHz, 1GB Ram and a 40gb drive. Its already running Debian (latest testing) setup for web/ftp/mail and its fast as hell for this. Also using a Micro ATX with a dual core CPU would mean spending money :blah: .
    As for a small update, I will hopfully start work on the plastic today. I am just kinda waiting to see if BigM2006 was still offering that VFD.
  6. BigM2006
    8 May 2006
    Check your messages. Its all yours!
  7. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Sweetness, I will be recieving the VFD from BigM2006 within the next couple weeks and will then resume progress on this once I can measure it and see what I will have to change in the way of layout and measurements.
  8. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    If you need help machining ANYTHING, I'm your guy.
  9. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Actually my main problem right now is trying to find a local Plastics dealer. I have a large sheet of clear acrylic which i was just going to paint the inside with gloss. Buts if I can get some other plastics with-out having to order it online, then I would rather go that way.
    Although, painting it from the inside with a gloss paint might actually look good. Will see once I start actually working on it.
    On thing I am working on right now is a different way to do the corners but not have the normal box look. I was thinking about bending, thought not to sure how well it will come out.
  10. Captain Slug
    25 Nov 2001
    If you want to do angled corners it would be easiest to use 1-inch square plastic rod as a corner framing piece then miter off one of the corners using a tablesaw.
    And my nearest plastics supplier has a good deal of variety in their scrap selection. I made a case with some awesome looking 1/8" thickness 80% tint polycarbonate sheets a while ago. http://www.captainslug.com/modding/nmp_999.jpg
  11. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    yeah i was looking at that one before. Maybe i can work somthing out with ya to get some plastics :D
  12. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Just a quick update before I go to work,
    I have received the VFD from BigM2006 :rock:
    I will be redesigning the front and redoing the dimentions of the case itself so there may be a total redesign. But I should be getting my Jig saww this weekend so hopefully I will start some plastic work then. :dremel:
    Thanks again BigM2006 !!
  13. Evenge
    Evenge Minimodder
    16 Sep 2006
    Nice idea to mod old laptop mobo. I like it!
  14. krimson
    krimson What's a Dremel?
    16 Nov 2006
    wow, this is really nice!
    maybe i do have a use for my old p200 laptop with the cracked screen.. a nice low power router box!
    though, i must say, i simply SUCK with soldering
  15. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    UPDATE 5 Mar 2007!!!
    Well as I said, got the jigsaw this weekend. Family stayed the weekend so I dodn't get a LOT done, but I made some good progress!
    First...
    This:
    And this:
    for a whole weekend (and through out last week if you count Capt Slug's Plug Bus :D ) = a messy mod rooom (Note: look at the desks) :
    Last week I spent a short amount of time getting the VFD to work in linux :
    Though i still need to figure out where from the motherboard I can pull +5v :wallbash:
    Here we have the semi completed front and back (still lots of filing :sigh: ) :
    And a size comparison:
    And last but not least, a nice Arsty Fartsy shot :D (And yes, as I said before, still have lots of filing to do :sigh: ) :
    I will be contiuing the work throughout the week and should have a nice update towards the end! :dremel: :clap:
    BTW: I think I won't be putting in the batteries, but that is still to be determined
  16. FR34K
    FR34K What's a Dremel?
    1 Feb 2007
    -subscribed-
    I love SFF mods...keep it up. :thumb:
  17. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Woah, at first I thought the front and back panels weren't even real, that they were just a rendered image. :eek:
    Looking good dude.
  18. SinxarKnights
    SinxarKnights Minimodder
    21 Jan 2007
    That is gonna look great. I thought you had given up on this but I'm glad you didn't. Did you ever get the new version of your drawings done?
  19. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    I did but I will let the pics of of the case coming to gether show you how I changed it. You can already see how the front and back has changed (Front mostly). And the sides have changed as well. I have some ideas that will hopefully turn out to work very well! :cooldude: :dremel:
  20. theurgy
    theurgy What's a Dremel?
    8 Oct 2004
    Really like the way those cuts in that acrylic turned out.
    Oh BTW.. here's a good tip... after you're done sanding those grooves smooth... get a Q-tip and some acetone and give it a good wipe.. it'll make the plastic nice and smooth.
