Project :- Titanium 4 U | update 22-03-05 CARRYING HANDLE & HDD Mounted !!!!
Discussion in 'Project Logs' started by j.rhy@n, 10 Feb 2005.
  1. TurboFlush
    TurboFlush What's a Dremel?
    27 Mar 2005
    The case is awesome, I was suprised at what you have done with it. However the handle needs to be changed (in my opinion). If to utilize the same arangment. maybe using three of those cables instead of one. this would make the handle widder (more comfrtable), and look better. The anchors are a good idea but look kinda funny.
    hmm, another idea, do you have anymore of that diamond metal? place a plate of it just under the handle. :dremel:
    later,
    TF
  2. j.rhy@n
    j.rhy@n What's a Dremel?
    10 Feb 2005
    Hi..
    Thx for comments...
    Handle seems to be top subject at the moment, the wire was the thickest there was. Im unsure if 3 strands of wire would look good but I shall see if I can find some thicker.
    I do have some Alloy sheeting left what did you mean by placing under handle ?
  3. j.rhy@n
    10 Feb 2005
    tonight I had a Brain Storm...
    The other day I flashed the bios after installing new operating system becuase the current bios doesnt show the new sempron info.. So tonight out of curiosity I decided to revert back to the original bios version and guess what ...Yep you guessed it the buzzing stopped. So it would seem that it is infact a codec problem with in the updated bios that was causing the buzzing noise and not my amp..The updated bios was a giant leep from the original so now I've upgraded 2 steps up missing out the latest, now all is fine and my speakers are working fine.. :rock:
  4. TurboFlush
    27 Mar 2005
    Just cut yah a rectangle to sit under the handle. you will have to remove the handle temporarily to do this and drill holes in the new plate where the handle goes thru (mounts to the case).
    hope that somewhow helps the visualization. lol I am not to good at puuting my thoughts to words.
    TF :clap:
  5. j.rhy@n
    10 Feb 2005
    Oh... I see .... Kind of a diamond shape on the top... Handle mounts showing through.. I will give it some thought..
    ***PC back on the testing station..
  6. TurboFlush
    27 Mar 2005
    I think I still confused you. whenever I get home I will upload an image and post it. I guess you cant upload images to this forum.
    later,
    TF
  7. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    no but you can always upload a pic through Photobucket
  8. TurboFlush
    27 Mar 2005
    mehh, I will just do it when I get home.
    that would just be another account to maintain. :waah:
  9. J_Webmaster
    J_Webmaster What's a Dremel?
    18 Mar 2005
    Handle
    The mod is SUPER!! The case looks great and you've done a wonderful job with the box!!!
    I just can't get over the eyesore :waah: of that handle on top.... I mean, use some metal and get creative :dremel: ......
    Using those cable fasteners just looks completely off.....
    Need to change that thing...... :wallbash:
    I think what TurboFlush was getting at was:
  10. TurboFlush
    27 Mar 2005
    Well umm, yah that is exactly what I was talking about. I was getting to that, just kinda busy. see I got this roomate, and I have to run to the grocery store all the time and get milk and other stuff, because we go thru it that fast. but he is afraid to go over there (to many people or something).
    But yah, thanks J. good to find such help in these forums. :thumb:
    Later, yall I gota get back to work :waah:
    TF
  11. j.rhy@n
    10 Feb 2005
    Just to keep u in the news...
    Im waiting on a custom made amp (Sealed) and I think it will be done in about 2 weeks.
    Ive ordered a new UV Lamp and I shall replace it with the blue one so as to give more light to my cabling..
    Im not done with the out side of the case so any ideas let me know, Im trying to find thicker cable so as to make the handle look better....
    Once all the above is done I shall post final pictures...
  12. BBurger
    BBurger What's a Dremel?
    7 Apr 2005
    For the handle - maybe go w/ two cables, and run them both thru a piece of the same clear tubing you're using inside the case?
    Should both look more substantial & be more comfortable to actually use.
    Awesome case - those server cases are huge, it looks like you could nearly put a complete second MoBo & stuff in there! :D
  13. ginx
    ginx What's a Dremel?
    1 Sep 2004
    Pretty nice work here. Not at all my style, so I can't say I like it personally, but I do have to admit that your work is good. It does look pretty clean though. :D
  14. j.rhy@n
    10 Feb 2005
    n1 , I didint think to put plastic tubing over 2 x cables... I shall do it later...
    thx
  15. J_Webmaster
    18 Mar 2005
    Handle.....
    So your not even going to think about changing the handle..... Maybe making one out of the diamond plated chrome or something....... :jawdrop: :jawdrop: :jawdrop:
  16. bootupbuddha
    bootupbuddha grunge modder
    3 Feb 2004
    great looking case..... sorry, but I dont like the handle....
  17. j.rhy@n
    10 Feb 2005
    If you read my post above , the answer to the handle is yes I will improve it.
    Im going to use 2 strands of cable and then place plastic tubing over to give it a better feel..
    I will do it later and post results...
  18. j.rhy@n
    10 Feb 2005
    Thx, its not complete yet but not far off...
    I know , a lot of people say the same thing :sigh: I really like it but tonight I will improve it and I hope It will look much better....
