Project :- Titanium 4 U | update 22-03-05 CARRYING HANDLE & HDD Mounted !!!!
Discussion in 'Project Logs' started by j.rhy@n, 10 Feb 2005.
  1. j.rhy@n
    j.rhy@n What's a Dremel?
    10 Feb 2005
    Thx , ignore the paint chips :wallbash: I will be giving this a final coat of paint along with lacker at the very very end...
    I ordered UV paint today so I guess the etch will have to wait , Ive re etched the window and it looks much much more detailed...
    Still little things to do such as :-
    Feet
    Fit Transformer socket to rear (Plastic one)
    Clean up and fit the wiring for the speakers
    UV Paint on the etch
    More sleeving
    So Im not done yet.... :dremel:
  2. j.rhy@n
    10 Feb 2005
    HDD under the lighting really does catch it ... I also plugged in the speakers just to make sure they still work... :D I think I will ditch the 100mm blue light and purchase a second UV light instead. Lots of UV cables inside and they arnt getting lit up as much as I would like...
  3. j.rhy@n
    10 Feb 2005
    just to keep u updates and to whom might have an answer..
    Been testing the hardware (Installing operating system etc etc ) at start all was good but now I get this anoying slight buzzing noise coming from speakers. Im not sure if my Speaker Mod was succesfull or its something minor. output from rear socket is fine with head phones but using speaker Mod connected to front pannel pins on the main board its giving me this buzzing sound (very slight), any ideas ? :wallbash:
    **** update , Ive switched from the Front Audio Pannel and re wired on to the rear jack and its the same... So it seems a Audio / Amp problem :waah:
  4. j.rhy@n
    10 Feb 2005
    it would seem that the buzzing noise is infact from a kaput amp :duh: the amp doesnt like the PC environment, so I have to figure out how to over come this by purchasing something different or scrapping the amp in the PC and use one exernally instead.... Ideas ?
    ***** Ok
    Im going to fix a jack or similar to the rear and have the Amp mounted in a custom made box, this way I will have no interfearence inside pc... Im thinking of using my gold edition hl2 box for the Amp but I have to buy a new one becuase this one always buzzing......
  5. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    nice work man!!!
  6. j.rhy@n
    10 Feb 2005
    thx just a shame my amp thing didnt work out... At the moment Im giving it a final coat off paint prior to a couple of layers of lacker. Im also fitting some metal plates on the out side to give it a little more style :dremel: pictures to follow...As to the sounds they will have to wait ...
    I dont want to go and buy another amp and it does the same , so I shall leave it for a wile. Ive removed the amp and speakers from the PC and ordered some nice blow hole covers for the time being...My UV paint has arrived so again when Ive fitted the covers (Hope fully tonight) u can see the etch under UV....
    :thumb:
  7. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    Just got to point out a typo :thumb: so what is so bad with the uv paint to make it a pain
  8. J_Webmaster
    J_Webmaster What's a Dremel?
    18 Mar 2005
    Boot Screen
    Once you get her up and running..... :naughty:
    I don't know what OS you will be running, but... for XP.. here ya go....
    Biohazard
    Boot Screen
    Green 3D Biohazard
    Boot Screen
    Brown Bio Hazard
    Boot Screen
    Blue 3D Biohazard
    Boot Screen
    Just thought I'd help out....
    Mod ON!!!!! :rock:
  9. j.rhy@n
    10 Feb 2005
    LOL such humour... Man Im tired, I ment PAINT :D
  10. CaseyBlackburn
    27 Jul 2004
    hate to break it to you your post is all fu*ked up you screwed up the image tags somehow and the pictures(the acutal url) dont work
  11. J_Webmaster
    18 Mar 2005
    If you would give someone a d@mn minute :sigh: ... just got the new server up and running.....
    I have edited to fix the problem.... :wallbash:
  12. CaseyBlackburn
    27 Jul 2004
    Just because you are unprepared you are wasting our precious minutes that are preoccupied doing other things (in my case reading bit-tech) nah man i am just kidding i was just pointing out the obvious earlier
  13. j.rhy@n
    10 Feb 2005
    well those Images will go with Lazer Cut grills when they arrive.....
    Here
    Shame Im running windows 2000 on the Titanium case :sigh:
    I have to watch my typing from now on, seems as though Im being monitored.. :D
    Tonight I fitted some nice looking Alloy sheeting , its not complete yet (Needs polishing) but it looks very nice and adds a nice touch to the case..My camera is in the car so I cant be botherd to go get it to take some pictures..But tommorow morning first thing I shall show it ya...Untill then
    Spater
  14. CaseyBlackburn
    27 Jul 2004
    Well needs to be capitalizedd Images shouldn't be capitalized Im should be I'm
    LOl its funny i notice everybodys mistakes but i am like the most horriblest at gramer spelling capitalization and typing att the rate i think
  15. j.rhy@n
    10 Feb 2005
    Back Pannel fitted...
    Ok , small update... For now I have removed all components to do with the speaker system untill I can come up with a suitable Amp...
    In the mean time Im making things look nice.. First off I loaded up the operating system just to confirm all ok..
    I fitted an Alloy back pannel...protects the rear from scratches and adds to my theme...
    I applied velcro first so as to position it , I then screwed it down....Needs a good polish...
  16. CaseyBlackburn
    27 Jul 2004
    looks real nice i just dont like that the alloy is not sitting very flat against the side because of the trim or is that just in the pics?
  17. crimandevil
    crimandevil What's a Dremel?
    30 Jun 2004
    Nice except the handle which looks really ghetto IMO.
  18. j.rhy@n
    10 Feb 2005
    It sits near flush but the rubber moulding makes it stick out a little but not a lot...
    As to the handle, I like it and its different..
  19. leviathan18
    leviathan18 What's a Dremel?
    17 Mar 2005
    wow mate very nice job.... and is just a case that was going to go to the garbage....
    really nice result.
  20. barit
    barit What's a Dremel?
    15 Mar 2005
    Looks TIP TOP!
    The colouring is great and the handle is very original - perhaps a thicker braid of wire would make it look more at home with the side panel?
    I love the flick switches, they make a case seem so much more than just a housing for parts and it is when a case becomes an additional function to the system or a whole new sub-system of entertainment that you have really done a good modding job.
