Case Mod - In Progress Project: TJ 180
Discussion in 'Project Logs' started by WiK1d, 24 Dec 2006.
  1. WiK1d
    WiK1d What's a Dremel?
    16 May 2006
    I used a dremel and jigsaw...the panel was a b**** to cut. And I didn't like it. So i'm just gonna have it lasercut rather now...
  2. WiK1d
    16 May 2006
    Did a quick 10 min lapping job on my CPU Waterblock. Need some finer paper to make it shine lots :D
    Gonna do my Maze 4 aswell.. :D
  3. Jipa
    5 Feb 2004
    The carbon film looks pretty nice! I think I could use it somewhere :)
  4. Evenge
    Evenge Minimodder
    16 Sep 2006
    Looks nice! CF is always cool...
    Keep up the good work!
  5. WiK1d
    16 May 2006
    Okay so it's 4.45AM and it UPDATE TIME!!
    I redid the front panel cause I hated the screw up's I made. Now it is perfect :D
    I tore of the the old vinyl and cut a new piece.
    Waited a few hours. And voila. It's done :D (The white stripes aren't screw ups...just so you guys know ;) )
    *I'm soft capped and stuggling to upload big files, Sorry*
    High Res Pic 2
    Looky. It reflects :D
  6. WiK1d
    16 May 2006
    So today I decided I'm gonna do my DVD RW and Fan Control.
    Here she is. Completed.
    And the DVD RW.
    And both
    So now I have a question. Should I leave the DVD RW as is or should I carbon the black part aswell?
  7. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Carbon the black tray cover thing also, but where's the button for the DVD drive?
  8. JAxen
    JAxen What's a Dremel?
    18 Nov 2005
    It vould have looked better if it was straight.. Still hawt though..
  9. WiK1d
    16 May 2006
    If you look in the bottom right corner there's a little bump. That's where she's hiding :D
    Thanks. The Fan Controller is a bit skew. But the DVD is straight though :D
  10. kylelnsn
    kylelnsn What's a Dremel?
    19 Dec 2006
    that is mint very slick, very nice tho, well done, good idea to cover everthing in carbonfiber tape! do the rest of your cd drive becuse it looks a little wierd. Nice job tho, well done
  11. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Just to put this out there, i also have a P180(B) and i have put in a window, and if you do it right, it doesn't not affect the silent properties of the case. Basically, cut out your window, and then cut JUST the plastic and inside metal about an inch larger than the window itself. cut your plexi to the exact size of the internal cut, and epoxy (or double sided tape will work i guess) the plexi in there. you can also seal the inside if you like, but in my case it was not needed.
    </end thread hijack>
    This is looking very good, showing all those who said that a p180 couldn't be modded were wrong.
  12. WiK1d
    16 May 2006
    That is a very very good Idea :D I am so gonna try this :D
    Thanks a LOT for that!!
  13. WiK1d
    16 May 2006
    So today I rewired and sleeved one of my fans. What a mission that was. So many times that I had to rewire and resolder and cut and trim...sheeeze...
    Here's the victim.
    Off with the stock wires
    New ones on. Heatshrinked for protection
    On they are. Sleeved and Shrinked
    Next Step. Getting the RCA jack on. (Now that was a pain in the rear end)
    Some Isolation (Which I didn't use due to the fact that I had to rewire the thing about 7 times)
    The Finished Product
    Not entirely happy with the heatshrink
  14. kylelnsn
    19 Dec 2006
    Nice once again Nice, love the carbon look and the cable on that fan is great! Man i gotta try that with a rca cable fantastic look it gives, nice job keep up the good work!
  15. WiK1d
    16 May 2006
    Well that I borrowed from my friend who borrowed it from Orac3. They used 3.5mm jacks though. I prefer the RCA's.
    Thanks a lot dude. Maybe I should do the other cable aswell quick...hmmmm
    *looks at burnt finger*
  16. exo²
    exo² What's a Dremel?
    22 Dec 2006
    i love the carbon
  17. WiK1d
    16 May 2006
    Cool :D Update Time. Here is a photo of the fan in a working condition :D Jump started from a crappy PSU :D
    Today I went out and bought myself an Action Figure...errr...Soldering Buddy.
    And here the cable is on and isolated. Man I love Macro
    Just so you guys can see what my heatshrinking tool is :p
    These little spots get so darn hot :D
    So here follows the Placement of the plugs :D
    Overview of the case
    The two fans next to each other :D
    The newest one's end came out better :D
  18. WiK1d
    16 May 2006
    Here's my trusty Hiper 525W which I will be using.
    I'll have 3 or 4 shower hoses coming through here that will house the ATX and 1 Molex and the 12V 4 Pin. I'm gonna put an Alu panel in the bottom to hide the holes.
    Here will be 4 shower hoses, 3 for the ATX and one for the 12V
    Here is my plan for the shower hose. Please excuse the crappy photochop. The hose is gonna at the far side so that it won't interrupt airflow. :D
    PCI-E Power is also gonna be in showerhose
    If there is any other way getting these (soon to be lengthened) wires to the upper drive bay unseen please let me know
    And a general overview of the case. Please let me know of any suggestions.
  19. marauder16
    marauder16 What's a Dremel?
    30 Sep 2006
    nice idea with the shower housing, wonder how that will look, when will we see some WCing action around here? :D
    and btw. I love those carbon vinyls, nice work :thumb:
  20. cire9753
    cire9753 What's a Dremel?
    16 Aug 2006
    this is turning out great
    its inspiring me
    i might use some of this stuff in my next mod
    and give you credit of course :rock:
