Scratch Build – In Progress Project "TJ-UFO" Itx Wc case
Discussion in 'Project Logs' started by Kone, 2 Jul 2011.
  1. Fonne
    Fonne What's a Dremel?
    9 Oct 2010
    Amazing build - Pure porn :D
    What kind of tube/fitting size do you use ? - And what are the load temp on your GPU and CPU ?
  2. Kone
    Kone What's a Dremel?
    2 Jul 2011
    tube/fitting size 3/8 - 5/8",
    it is very torridity here, ambient temperature over 30C, senson at the case front.
    the photo "RAD IN" temperature close the ambient,
    all fans run at approximately 800 Rpm, and the DDC3.25 run at 10.2v. :)
  3. Fonne
    9 Oct 2010
    Not bad :thumb:
    How big is the total dimensions ? - Deserve more views :jawdrop:
  4. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Can't believe i missed this one, top job!
  5. Kone
    2 Jul 2011
    this is old project, thank you :D
