Case Mod - In Progress Project: Tj07 Black & White
Discussion in 'Project Logs' started by ColdzeroTeam, 12 Jul 2011.
  1. ColdzeroTeam
    ColdzeroTeam What's a Dremel?
    9 Dec 2010
    Hi guys,
    I'm starting a new case for myself. i had it gathering dust so i thought... "why not mod this puppy?"
    it started out with something simple, and after a lot of thought i was able to come up with some ideas to make this mod a little better, and this is mostly all you guys fault :p because you raise the bar so high, that after that a simpler mod simply wont do...
    but enough talk, and lets begin...
    Sponsored by:
    Hardware:
    Rampage 3 Black Edition
    Intel 990x
    12GB (3x4GB) G.Skill 2000mhz CL8
    3x Nvidia Gtx 470
    SilverStone Strider Plus 1000w
    Corsair F120 SSD
    Cooling:
    2x Thermochill TA120.4
    2x Laing 10w
    1x Koolance RP402x2
    12x Noiseblocker XL2
    Aquaero for fan Controll
    All psu cables will be custom made and will feature the "no heat-shrink" sleeving touch :p
    this case was originally meant for the Snow White Project, but problems with the powder coating (excessive paint) made me scrap the case, and paint a new one. Until i decided that i could use this case for me, since it was free anyway :p
    at first i thought of using a 480 and 360 Thermochill TA radiators as well as a Laing E10 pump...
    but then i thought... "uhm... maybe a little overkill, no??" :p
    then i dropped that idea and decided to use two 480 rads at the bottom, which meant moving the psu to the 5.25" bay compartment. (don't mind the 800D at the back :p)
    Since everything is going to be watercooled I won't be needing the top mesh
    The new (narrower) vertical bars i was planing on using to allow for a 120mm on the back
    Lian-li Aluminium Wheels. IMHO they look like they were made for this case. they go so well with the cases round corners on the front
    Needed to add a plexi spacer for clearance
    5.25" that were cut for the hot-swap system that won't be used any more...
    And the parade of parts going to waste continues... this time is the midplate
    And the backplate
    To do list:
    - Midplate
    - 5.25" bays
    - Mb tray
    - Side panels (the ones painted don't fit the case, therefore -> trashed)
    - Front pannel
    basically all the interior is going to be made from scratch... :rock:
  2. ColdzeroTeam
    9 Dec 2010
    Cpu waterblock chosen was Aquacomputer Kryos XT
    I decided create a new cover...
    And after a few tries... success!!!
    will do something similar on the vga blocks. Aquacomputer AquagraFX nickel for the GTX470.
  3. ColdzeroTeam
    9 Dec 2010
    while i try to finish the cpu waterblock, why don't i show you what i've done with the vga waterblocks :p
    And the weapons of choice were... Aquacomputer AquagraFX GTX470 Nickel.
    One of the reasons i prefer these blocks over other solutions, they include standoff's
    Using the single slot pci plate makes the cards look so much better and slimer :p
    And it's custom backplate time :) used a different scheme than usual.
    The more i looked at the waterblock, the less i liked the top cover (too much of the same colour) so i decided to take care of that as well...
    Almost...
    Almost there...
    Finished look :)
    Nice Acetal + Nickel Look, don't you think :p
  4. KidMod-Southpaw
    28 Sep 2010
    Very nice colours- great start!
  5. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Awesome! All that stands out now is those capacitators - polish em! :D
  6. ColdzeroTeam
    9 Dec 2010
    i'll think about it :D
  7. ColdzeroTeam
    9 Dec 2010
    I got a few more ideas for the case by looking/getting inspiration from my G.skill Trident heatspreaders as well as the TJ11.
    The idea here is to widden the case a bit (call it a wide body kit, if you like :p)
    To do that i thought of interleaving white and black plexi screwed to the chassi of the case on the side "ribs" that were used to fix the side panels, layer over layer until i got the with i wanted
    Started the process of cutting the plexi, marking, drilling and finally threading all around the case...
    First Layer is complete
    Don't mind the screws. Those are temporary :)
  8. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    Ooh You got very big pump where did you get it ??? Nice build :) keep it going :)
  9. ColdzeroTeam
    9 Dec 2010
    i got it from laing.de directly
  10. Shazbom
    Shazbom What's a Dremel?
    18 Jan 2009
    yo ColdzeroTeam keep it up.. can't wait to see where you going to put the psu... =)
    +i've never seen such a big pump. how much stronger is that comparing to the d5 pump?
  11. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    You have alot of really nice stuff floating about this mod. this is going somewhere very good!!
  12. ColdzeroTeam
    9 Dec 2010
    Tks :)
    This pump can do 4500L/H and 4.5meters of pressure. It also has a knob to controll it from 1-7. and Consumes 62w. 230v
    it's generally used for circulating water in house heating systems :p
    tks :)
  13. paz45
    paz45 What's a Dremel?
    12 Nov 2010
    Nice will be watching
    always enjoy your mods:thumb:
  14. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    dude this is awesome, nice job! *subscribed* All these project mods I'm seeing with TJ07's seriously making me want one of these instead of a Xigmatek Elysium, DAMMIT! :)
  15. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Epic awesomeness on the way!!!!!
  16. ColdzeroTeam
    9 Dec 2010
    Tks :)
    this case is still my all time favourite
    hope so my friend :p
  17. KiiYzOo
    KiiYzOo What's a Dremel?
    11 Mar 2011
    love the paint job makes it look like it's made out of white delrin :D
  18. stefan442
    stefan442 Minimodder
    14 Mar 2011
    nice white build :D so many good mods going on atm!
  19. ColdzeroTeam
    9 Dec 2010
    Here come the rest of the pieces...
    First layer in place
    Another white layer and things begin to take shape...
    Second layer, and you can begin to notice the desired effect.
    First side done :)
    Only thing missing is the side panel in black plexi.
    Reverse likes this.
  20. Razarach
    Razarach Minimodder
    28 Jan 2009
    wow. This looks beautiful ;)
