Scratch Build – In Progress Project: Totally Twisted (with homemade radiator & reservoir)
Discussion in 'Project Logs' started by Mishter_Jingles, 11 Nov 2007.
  1. luis_pedro_Sato
    luis_pedro_Sato Member
    29 Nov 2004
    Love the copper tubes.
    Great stuff in your project
  2. Mishter_Jingles
    Mishter_Jingles New Member
    28 Sep 2007
    Pine wood
  3. MrMonroe
    MrMonroe New Member
    27 Dec 2007
    I really like the look of this, and your decision to make your own rad is really admirable.
    One suggestion: stain the wood nice and dark.
  4. -Nick-
    -Nick- New Member
    23 Jan 2008
    holy **** that's pretty unique there, really cool, love the whole design of it, keep it up ;)
  5. jhanlon303
    7 Sep 2006
    A little off topic but do you know that people actually collect old CPUs? They go for like $10USD on eBay. I have seen some of the ceramic ones go for a lot more. That Box could probably finance this project.
    John
  6. Mishter_Jingles
    28 Sep 2007
    UPDATE
    UPDATE!
    Only four months since the last update, mostly because I had litle time and because the parts didn't arrive. But now the hardware finally arrived!
    AMD Phenom 9850
    MSI K9A2 Platinum
    MSI NX 8800GT
    4GBCorsair XMS2 CM2X-6400C4DHX
    Creative X-Fi XtremeGamer
    Coolermaster M620
    Lite-on LH 20-A1S
    LG L226WTQ
    Logitech G9
    And the watercooling:
    Zalman fans
    Zalman fancontroller
    swiftech mcp655 pomp
    swiftech Apogee GTX
    etc.
    The computer is working, but the cooling isn't installed, that'll change soon, very soon.
    (with beautiful antique olivetti keyboard)
    I will post updates as soon as possible.
    @jhanlon303: thx I'll take a look on ebay
  7. Mishter_Jingles
    28 Sep 2007
    UPDATE
    UPDATE
    Finally I have vacation, and now I'm capable to start doing the real work.
    First I bought a new keyboard (not that you care)
    After that I started to solder the radiator:
    One burned down house later:
    The time had come to see if everything really worked, so I put everything together:
    I put on the psu and... nothing. Aparently the psu has to be connected to the mobo, so I used an old psu which didn't need to be connected. I was very pleased because everything worked, the pump is whisperquiet and there are no leakages:
    Something blue came out of the copper radiator, I don't have a picture and I don't know what it was, but now it's gone.
    The next step is to see what temperature I can get out of it, that's probably for the next update.
  8. okapi
    okapi What's a zebra?
    4 Jan 2008
    Copper (II) salts. Most are blue. Happens when copper reacts with almost any acid.
  9. Mishter_Jingles
    28 Sep 2007
    Maybe a dumb question; but just to be sure: Can it cause damage if you put the HD vertically instead of horizontally?
  10. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    Nope, that is no problem.
  11. SupReme
    SupReme Message is over there ->
    20 Jun 2008
    Wow, love the custom radiator! Im just not sure how well it will cool. Are you going to solder any Aluminum plates or something to them? Just some coppertube won't cool that good i think.
  12. Asulc
    Asulc Member
    18 Jul 2007
    A couple of questions:confused:
    1) Why are you using a Crossfire motherboard if you are using a Nvidia card? Wouldn't it make more sense to use a P35 or P45?
    2) Why AMD? Intel is beating AMD in nearly all accounts...
    3) The memory is not installed in Dual Channel Config...
    Otherwise, the mod is looking great!:clap: I am impressed with the originality of it.:idea: Good luck!:dremel:
  13. Mishter_Jingles
    28 Sep 2007
    UPDATE
    I recently returned from vacation and started working again.
    I began with the plan making a reservoir, because I needed one. I had everything worked out in my head, but making it was a lot more difficult than I thought...
    Pictures say enough I think:
    First attempt:
    The shape wasn't exactly what I wanted, so I made a second design:
    After soldering:
    This one is better, but I still have to test it.
    @Asulc
    1)I wanted amd
    2)personal taste
    3)The memory is installed in Dual Channel Config
  14. Archtronics
    Archtronics Well-Known Member
    27 Jun 2006
    Not all Amd still beats Intel for energy efficient CPU.
  15. MixWizard
    MixWizard New Member
    16 Jan 2007
    Have to agree the Q6600 is a very energy efficient CPU ive found and it benchmarks far better then the amd phenoms
  16. Mishter_Jingles
    28 Sep 2007
    UPDATE
    Maybe you recognize this?
    It used to be the reservoir, but because I made a new better one, this one isn't needed anymore. But I don't like throwing it away so I needed to make a new purpose for it.
    First calculating and drawning(sorry for the blur):
    The old reservoir, now in pieces:
    You get an impression on how its gonna be
    Evolution
    Tadaaaa
    This will be hanging at the side of the case, soon everything will be clear...
  17. Mishter_Jingles
    28 Sep 2007
    UPDATE
    The radiator (with central tube) and the reservoir are finally done, so I had to leaktest it.
    I assembled the whole loop (accept the cpu, because there's still a lot of dirt in the tubes, and it would all get stuck in the cpu block). The pictures tell the story.
    Thus it leaked.
    Now I just have to solder and glue a bit, and the cooling part is done.
  18. karolis
    karolis Code Monkey
    10 Mar 2008
    must be quite heavy with all that copper :) sorry to hear about the leaks
  19. Mishter_Jingles
    28 Sep 2007
    Leaks are dealt with. No leaks anymore!:D
    I will weigh the copper before I insert it into the case, I estimate that there's arround 5 kg of copper used, but the pinewood is very light, so that will compensate it a little bit.
    Big update coming up...
  20. Mishter_Jingles
    28 Sep 2007
    UPDATE!
    UPDATE
    This is the update that took me the most work. What is done:
    -The case is totally varnished, the wood looks much nicer now.
    -Watercooling installed and leaktested
    - made a hold down plate for socket am2.
    -Made a big window in the radiator
    - fans installed.
    -made a hole for the reservoir and installed it
    I'm very close to the end of this project, but still a lot has to happen.
    Here are the picures, not in a particular order (because i'm lazy)
    thx for all the nice comments!
