Scratch Build – In Progress Project: Totally Twisted (with homemade radiator & reservoir)
Discussion in 'Project Logs' started by Mishter_Jingles, 11 Nov 2007.
  1. Valdisnei
    Valdisnei Can i haz a dremelz!?
    22 Sep 2007
    Wow!
    Great. looks like a wind tunnel :lol:
    Great job soldering all those pipes! :thumb:
  2. Mishter_Jingles
    Mishter_Jingles What's a Dremel?
    28 Sep 2007
    UPDATE
    UPDATE
    It has been 3 weeks since the last update, but I have a good reason for this, i've been selected to start the pilottraining in the Belgian army, therefor I have 6 weeks of camp (with this free weekend between).
    This weekend I applied the watercooling
    temperature:
    AIR (stockcooler )
    Idle: 37°C
    Full load: 65°C
    This is the coretemp, the cputemp is 8° lower.
    WATER (fans on minimum and I used the thermal paste of the stockcooler)
    Idle: 29°C
    Full load: 38°C
    Idle a difference of EIGHT degrees and under full load even TWENTYSEVEN degrees, this can even improve by adjusting the fanspeed and using good thermal paste!!!
    So I think my watercoolingproject is already a succes!
  3. Ashaman
    Ashaman M'hael
    17 Mar 2008
    Nice temps!
    Nice mod also, I've been following your work from the beginning and I most say this turned out really good!
    Will there be some pics of the whole thing done soon? Or is there still some things that needs to be done?
    I'll give you creds on your reservoar, I thought it would be impossible to do something like that when you started it, but you pulled it off! Looks brilliant though! ;)
  4. Mishter_Jingles
    28 Sep 2007
    after 3 weeks I probably have the time to finish it and to make some good photos, at the moment the case still isn't finished: the hardware isn't properly installed.
  5. jois21
    jois21 What's a Dremel?
    15 May 2008
    u r psychopath.
  6. Mishter_Jingles
    28 Sep 2007
    UPDATE
    Everyone thougt this thread was dead, BUT it's alive
    Ok it has been 6 months, since the last update, but I was really buzy with the studies and all, and I had some problems with the cpu block.
    What I've done this week:
    Holes for the mobo (rougly)
    CPU block with homemade backplate
    Now you can see the radiator properly
    Installed the PSU
    Connected the watercooling
    used this as a filter, it was really helpfull
    connected the cpu block
    some shots to have a better view of it all
    btw it is turned on on the last picture
    Im planning to work a lot this week, thus this won't be the last update this year ;)
  7. Mishter_Jingles
    28 Sep 2007
    UPDATE
    UPDATE
    There's still being worked on this mod: I placed all of the wood on the sides
    installed 2 92mm fans for cooling the mobo
    finished some things like the reservoir:
    placed some details:
    the bigger picture:
    Now I'm starting the work on the on/off switch and the front in which it will be installed
    The boy 4rm oz likes this.
  8. Cheapskate
    13 May 2007
    It's good to see you still at it.:D
    The hardware store sells rubber sheets for gaskets. You could use some of that to seal the top of your reservoir.
  9. Mark_Hardware
    Mark_Hardware What's a Dremel?
    5 Apr 2009
    Wow very interesting. Looking very nice man, keep up the good work
  10. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Cool project :D
  11. Colossous
    Colossous Minimodder
    28 May 2007
    Great concept and execution :thumb:
  12. The boy 4rm oz
    10 Apr 2008
    Now this is something special. Awesome craftsmanship mate, turned out really well. I love the custom W/C rads and res, they look great. +rep
    Just a tip though, keep an eye on the Swiftech GTX alu top, mine corroded after 2.5 months of use, I now have a Delrin top.
  13. Mishter_Jingles
    28 Sep 2007
    Exactly! I had the same thing, it corroded and I send it back, they replaced it, but the new one corroded again, I cleaned it and for now I still use it, but I hope to replace it soon.
  14. stonedsurd
    11 Mar 2009
    Stellar stuff :thumb:
    Love the woodwork especially.
  15. The boy 4rm oz
    10 Apr 2008
    Yeah I complained directly to Swiftech customer service and they offered me either another alu one or a Delrin one. I contemplated taking the alu and selling the block on Ebay but the cheaper option was the Delrin top. They sent it to me for free, didn't cost me a cent.
  16. TomD22
    TomD22 What's a Dremel?
    24 Oct 2006
    Absolutely love the design of this, especially those 'air tubes' directing the cooling (if that's what they're doing?)
    Btw re: something you wrote a couple of pages back, tricking a PSU into switching on (so you can test your pump or whatever) when it isn't connected to a motherboard is really easy. Just use a paperclip to connect two specific pins on the ATX connector (I think it's the first green and black ones from the left, but google it and you can see diagrams).
    Love the mod anyway; voted for mod of the month.
  17. Geowal19
    Geowal19 What's a Dremel?
    16 Apr 2009
    yeh i like it but tbh i thought the readiators were gona be shite but u prooved me wrong
