Case Mod - In Progress ProJeCt : ToTecHniKa by AnG3L (09 April - Totechnika's video)
Discussion in 'Project Logs' started by AnG3L, 3 Sep 2009.
  1. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Thank you my friend!!!
    I hope the duct system will be fixed soon for you to be able to move on with your project!!
    Wish you good luck with the project from the bottom of my heart!!! :)
  2. RuSGaMeR
    RuSGaMeR No Pain No Gain...
    10 Sep 2009
    Dude, how's it going? How're ur BIOS? Did u get them fixed? :) Hope u're all good :)
  3. AnG3L
    19 Mar 2009
    I am still waiting bro... :( But once I am back, the update will be huuuuuuuuuuuuge :p
    Cross your fingers guys! Sorry for the delay... :(
  4. RuSGaMeR
    10 Sep 2009
    Cool, can't wait :) and it's all good with the delay ))) I didn't even start my project log...yet :S (we're still going over stuff...BTW we've got the duct system's working again, so that's a plus, and our teacher fixed the jigsaw which was broken last year (that would help me a lottttt))
    PS
    Keep my fingers crossed :)
  5. AnG3L
    19 Mar 2009
    Thats good to hear that bro! I wish the best with your project, I ll keep an eye to you! :)
  6. MIGUI
    MIGUI What's a Dremel?
    27 Feb 2009
    Another project friend.:thumb:
    An excellent work. :D
  7. AnG3L
    19 Mar 2009
    Thank you buddy, yes I work very hard nowadays to make my dreams come true! :)
  8. riekmaharg2
    riekmaharg2 has started the PowerCore scratch build
    22 Feb 2009
    Does your motherboard not have a second BIOS chip, most of the more recent ones do nowa days?
  9. AnG3L
    19 Mar 2009
    No my friend unfortunately... :( I have to wait for the chip to come now....
  10. AnG3L
    19 Mar 2009
    I ordered my second bios chip..... Hopefully I ll have it till Friday and OMG I am going to update for a life!!!! :p BrB soon people sorry for the delay.....!
  11. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    Thats cool. take your time, we shall wait. waiting is going back into style nowadays! :p
    good luck with the board dude!
  12. AnG3L
    19 Mar 2009
    Thanks brother!!! Patience became my dear friend as you can see! LooooooooooooL :) :)
  13. AnG3L
    19 Mar 2009
    A quick question brothers! I would like to use my spare PSU as a tester. Will I damage it if I want to test one fan or something like that or I have to put a lot of things on it? PLs help! Thanks!
    perplekks45 likes this.
  14. stonedsurd
    11 Mar 2009
    I've used PSUs to test fans, cathodes etc. Never had a problem.
  15. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Amazing stuff, mate!
    The use of pyrography is pretty much unique and your designs are exactly what you want it to be: Art.
    Well done, 5 stars and rep. :thumb:
  16. AnG3L
    19 Mar 2009
    Thanks mate for the info!!! :D
    Thanks man!!! Your presence here is much appreciated!!!! :thumb:
  17. AnG3L
    19 Mar 2009
    Here I am again after the problems I had with my bios and the looooooooong delay I experienced with our wonderful post office!
    Anyway I am here for a huge update and a lot of work....!!!!
    I am going to start with the creation of the aluminum part of the door which is going to connect the wood with the moving steel part!
    Here I am using one red spare piece of aluminum that I found (its not going to be red).
    Some measurements and the cutting of the first main piece (you can see my dremel just a little before it died).
    And here I measure for the bending point:
    And my bending bench!!!
    Is it good???? Yes it is!!!
    And here I create a teeth pattern by using this bit and .... a lot of filing!
    Measurements and drilling of the holes that they will connect the steel part with the aluminum.
    Testing. testing, one two one two :p
    Here I start drawing some main lines for the final design:
    And let the cutting begins!!! :p
    One pattern......
    Changed my mind.... Second pattern!!!!
    More details
    To give an emphasis on the uneven technique which this mod is based, this design its different than the other. One has sharp corners, the other rounded.
    Here I use the same dremel bit I used for the teeth effect to create an uneven surface on the aluminum.
    Water sanding and lets get ready for some painting techniques!
    The steel black gloss....
    Aluminum... red! (for now :p)
    And yes!!! Black splash technique for a unique finish!!!!
    7 layers of clear coat:
    And now the bezzel! I will create a video later on showing that specific technique step by step for the first time!!!! Stay tuned!!!
    7 layers of clear coat as I did with the aluminum.
    I decided to create something extra for the door. 2 pieces of red gloss acrylic for the upper and bottom part. Enjoy the process !!!
    Diamond wheel for the acrylic:
    Measurements for the holes:
    Same for wood so it wont crack,
    Black chipboard screws!!!
    Some epoxy:
    And voila!!!!
    And now the rest of the process! M4 screws with nuts to fix the aluminum with the steel.
    And the wood fixed with the aluminum and steel using black chipboard screws:
    And here is how I created some stoppers for the door:
    So .... thats all for now guys, I will be back veeeeery soon with the rest of the updates and the video!!! Till then, keep on modding and please feel free to comment!!
    ps: The door its not finished yet....
  18. The boy 4rm oz
    10 Apr 2008
    Looking seriously good buddy, keep it up. The red and black paint effect is awesome.
  19. AnG3L
    19 Mar 2009
    Thanks brother I am going to upload a video of these techniques in a while!!! :)
  20. stonedsurd
    11 Mar 2009
    Looks amaaaaaaaaaaaaaaazing, but for one thing.
    You really should countersink those screws. They sort of 'stick out' (literally and figuratively).
