Case Mod - In Progress ProJeCt : ToTecHniKa by AnG3L (09 April - Totechnika's video)
Discussion in 'Project Logs' started by AnG3L, 3 Sep 2009.
  1. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Thanks buddy! I will use some tree seeds (yes I am not total crazy!) to cover the screws!
    As soon as I do that you will see the difference. Ii will look like needles but I believe it will be nice. If it isnt I will do what you told me! Thanks for the tip bro! :)
  2. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Countersinking the screws would look much cleaner but I'll wait for your solution. You're the artist, after all.
  3. AnG3L
    19 Mar 2009
    Yes I will do that even though my original idea was that. I wanted to give an emphasis to the screws cause its a piece of art but your idea its good too. I will think about it! Thanks! :)
  4. AnG3L
    19 Mar 2009
    And the video as I promised!!!
    Enjoy!
  5. masbuskado
    masbuskado Compulsive Modder
    15 Sep 2008
    Nice...!!!
    luv the technique... mod on AnG3L!!!
    Hand of the Gods!!!
  6. AnG3L
    19 Mar 2009
    Yeah brother!!!! Thank you!
    Hand of the Gods all the way!!! :)
  7. RuSGaMeR
    RuSGaMeR No Pain No Gain...
    10 Sep 2009
    YES!!!!!!!!!FINALLY :) You're back))) I like how the door starts to look :) Can't wait 4 more :p
  8. AnG3L
    19 Mar 2009
    My friend RusGamer thank you so much!!! More to come soon!!! :)
  9. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    very nice work there! i really liked the color of the aluminium before you painted it
    ah well..... your one looks great too! great stuff :thumb:
  10. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    Great work till now , and great painting tutorial , u live in the Brazilian jungle or what?
    Because of the palm trees at your house..
    Keep updating this , its getting great !
  11. AnG3L
    19 Mar 2009
    Thank you my island friend! :) Yes indeed the color was nice but from close it looked kinda pinky so I had to change it to fit with the rest, more trouble for me but at the end I believe it will be nice!
    Thanks man! No I dont live in the Brazilian jungle my friend! LoL I live in Cyprus and it happens in my yard to have a lot of these! :) :D
  12. AnG3L
    19 Mar 2009
    One more quick update guys with the work I ve done and the packages I received while I was experiencing the bios problem.
    I will begin with the various thingies I received from my sponsors and some things I ordered!
    Here are the first two packages with the Murder Mod sleeving and the awesome PSU from Nesteq.
    Here is the 850 Watt PSU from Nesteq. Really guys I ve never seen something like it before. Modular cables for a really clean job, a power monitoring panel for checking the voltages and so many other unique options. Really the best PSU a modder and a pc enthusiast can get.
    Here is the site for you to see more info : http://www.nesteq.net/gb/products/powersupplies/e2cs_xstrike/index.html
    And here is what I received from Aquatuning.de !!
    Here is the brand new Phobya Radiator with a lot of unique features!!!
    ...more modifications on these rads later on!
    Now lets see the sleeving of the Nesteq's awesome fan controller and how you can do that.
    First of all you need a small screwdriver or something kinda like needle. There are some white clips that you have to slightly raise upwards so you will be able to remove the wires.
    As you can see I didnt sleeved that untill the end of the wire because first of all it wont be visible and second I wanted the flexibility and I didnt want to rush the cables near the clips.
    Now lets go to the pump sleeving and assembling.
    As you will see I cut the monitoring cable cause I never use it and I used a heatshrink to close it so it wont make contact anywhere.
    Here is the XSPC dual bay and pump reservoir and the process of assembling it with the pumps.
    Now the 24 pin extension. I didnt want to sleeve the PSU's 24 pin so I used the extension which at the end it will look beautiful too!
    Now the 8 pin extension!
    And the cathodes! Watch how you can remove the pins to sleeve them all.
    And here are all the fans (the transparent ones are going to be painted)
    .....more in a few minutes!!!
  13. stonedsurd
    11 Mar 2009
    Your sleeving work is top notch :thumb:
  14. AnG3L
    19 Mar 2009
    Thank you brother!!! :) Much appreciated! :)
  15. AnG3L
    19 Mar 2009
    So here I am going to show you the painting of the rads. First some (a lot!)
    masking !
    Then some sanding!
    And painting!!
    After almost 2 weeks I watersanded the rads and applied 3 more layers of black gloss paint.
    And here is the assembly and the final look! :)
    Till next people, keep on modding!!! :)
  16. perplekks45
    9 May 2004
    Looking great. Will you cover them so they won't "ruin" the look of the project?
  17. AnG3L
    19 Mar 2009
    Thanks bro! One rad is going to be hidden into a cabin I am going to create about the other one I am planning to install it at the bottom and yes probably I ll do something with aluminum or wood! Will see! :)
  18. The boy 4rm oz
    10 Apr 2008
    Lots of goodies for you ;), can't wait for my next project lol.
  19. AnG3L
    19 Mar 2009
    Yeah, did you plan something? I would really like to see you modding again bro!
  20. riekmaharg2
    riekmaharg2 has started the PowerCore scratch build
    22 Feb 2009
    Why do you need two pumps, is there going to be an epic amount of tubing, and waterblocks?
    Nice work on the spray painting :thumb:
