Case Mod - In Progress ProJeCt : ToTecHniKa by AnG3L (09 April - Totechnika's video)
Discussion in 'Project Logs' started by AnG3L, 3 Sep 2009.
  1. The boy 4rm oz
    10 Apr 2008
    I actually have 4 case mods coming up and 2 monitor mods (hopefully). The first mod is one I promised my brother for his birthday in January, the second is a slight upgrade for dad, the third is a media PC I am building from dads old hardware and the 4th is going to be my next LEXA mod, that's a long way off. I will have my brothers and dads upgrade done by Christmas, the media PC will take longer because I am going for a custom built and bent alu chassis :D.
    @riekmaharg2 - The duel pumps are for the duel loops, one for the CPU and motherboard components, the other for the GPUs, hence the twin radiaators and pumps.
  2. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Thanks brother! As my friend The boy 4rm oz said I will do dual loops one for the Cpu and mobo and one for the Gpu's! :D
    That sounds interesting brother and.... a lot of work!!!! I want you to inform me with the links of your worklogs if you do any pls! Thanks again!!! :thumb:
  3. MIGUI
    MIGUI What's a Dremel?
    27 Feb 2009
    Excellent works my friend.:thumb:
  4. AnG3L
    19 Mar 2009
    Thanks brother!!! :)
  5. woody_294
    woody_294 Wizard Ninja :P
    31 Dec 2008
    Looking great man! Looks to be stunning when it's finished :D
  6. AnG3L
    19 Mar 2009
    Thanks woody my friend!! Where have you been? Long time no see! :)
  7. woody_294
    31 Dec 2008
    You're welcome bud :) Been working, no time to mod :(
  8. AnG3L
    19 Mar 2009
    Mod on le mita cola!!! (le mita cola - my friend in Apache language!) :)
  9. AnG3L
    19 Mar 2009
    Here I am for one more update!
    I finished working on the door except from the locking mechanism which I will do later on.
    Here I crystallized a real feather using varnish and I attached it using epoxy.
    So here you can see some eucalyptus seeds! Yes I am not crazy, I am an artist! (worst than crazy!) I measured them to find the right ones and then I sanded them to bring an equal height length ratio so they will look alike!
    Here I panted them black and red metallic creating that effect:
    As you can see I followed my friends stonesurd advise to countersink the screws but with unexpected results!! So I did another one piece of red acrylic again!
    So here I use some isopon to fit the seeds on the screws.
    And here are some shots on various lighting environments after I applied 7 layers of varnish. Enjoy!
    So excuse me now cause I have to go back to work! :) Thanks for watching and commenting!
  10. RuSGaMeR
    RuSGaMeR No Pain No Gain...
    10 Sep 2009
    Damn...Just Stunning!!!
  11. The boy 4rm oz
    10 Apr 2008
    No worries mate, I will definitely send you the links when I start something new.
    Nice idea with those beads, a really nice result.
  12. AnG3L
    19 Mar 2009
    Thanks bro! :)
  13. AnG3L
    19 Mar 2009
    Thanks brother! I will wait for your work 2! :thumb:
  14. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    Great work .. this is going to be the fron part of the case??
  15. AnG3L
    19 Mar 2009
    Yes my friend, this is the front door! I will create a locking mechanism probably later on!
  16. woody_294
    31 Dec 2008
    That looks sweeeet! Look forward to the rest of it :D
  17. AnG3L
    19 Mar 2009
    Thanks woody my friend! I ll keep you updated!!! :)
  18. stonedsurd
    11 Mar 2009
    The door is looking stunning./
  19. AnG3L
    19 Mar 2009
    Thanks buddy! You see? I followed your advice bro! Thanks for that! :)
  20. stonedsurd
    11 Mar 2009
    Yep, I noticed that! :thumb:
