Project: Touch of Red
Discussion in 'Project Logs' started by Shadowed_fury, 18 Sep 2005.
  1. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Having started on the steps of my first watercooled rig, I thought I might aswell make a log.
    So here you all are! ;)
    The main theme is going to be White lighting, but with (and as the title suggests) a Touch of red. My Gainward card helps here ;) hehe.
    Specs are:
    Gigabyte K8NXP-9 Motherboard
    AMD64 Venice 3000+
    Gainward 6600GT Golden Sample
    512mb Crucial Ballistix
    80Gb Seagate Hard Disk
    Samsung CDrw/DVD combo
    Black Floppy drive
    ...and maybe a pioneer slot loader.
    Watercooling Specs:
    PolarFLO CPU Block
    PolarFLO VGA Block
    Bay Res
    1xCSP-MAG pump
    Thermochill HE.120
    So far, I've stripped the case, drilled out some rivets that were holding a second hard disk bay, and installed the rad.
    Anyway, Pics are better than words!
    Out with the old, In with the new... ;)
    And again ;)
    Before...
    After...
    Close up of rad :)
    Overall look (you can just about see the res)
    Thats all for now, tmoz, install begins! ;)
  2. shplade
    shplade What's a Dremel?
    10 Dec 2004
    That gpu block is hella sexeh!
  3. Shadowed_fury
    21 Nov 2003
    And built like a tank, seriously. ;)
  4. Altron
    Altron Minimodder
    12 Dec 2002
    Nice case. Make sure you throw away the 80mm fan that came with it. It's a crappy little fan that tends to catch fire and kill the PSU, or at least it did with mine.
  5. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Way to keep us hanging ;) Keep it up dude!
  6. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    looking good so far!
    named after an 'In Flames' Song is it?
  7. Shadowed_fury
    21 Nov 2003
    Altron, Theres no 80mm fans in this thing now ;) (cept on the Hiper PSU)
    Leeum, Thanks ;) More to come soon! hehe
    Cookie for you! Only the best damn metal band ever! :p
  8. GuardianStorm
    26 Apr 2005
    woot! biscuits for Me!
    have you got a pic of the front bezel, pre modding? whats the plans for it?
  9. Shadowed_fury
    21 Nov 2003
    The front bezel - no pics yet, but the black behind the plex, was black, is going crimson.
    And i'm adding some more plexi over the drive bays... I think :)
  10. Shadowed_fury
    21 Nov 2003
    And the pics...
    Pump installed
    PSU awaiting components ;)
    Mid install
    more...
    adding the water ;)
    VGA shot
    Pump/Rad
    CPU shot :D
    Another running pic
    Running windows at 23c Idle (according to bios!)
  11. frodo
    frodo What's a Dremel?
    1 Nov 2003
    wow... do you like water over components??? just the fact you havent secured the other pipe - barb's at all!!! LEAK!
    as soon as that gets warm the pipe will become flexible and it will piss water over your stuff!!! just a little warning
  12. Shadowed_fury
    21 Nov 2003
    Crap, really?
    Must go hunt cable ties. (its off for now lol ;))
  13. frodo
    1 Nov 2003
    yes... really
    as soon as it gets under load, the water will warm up, and then the tube will become very flexible, and just slip off the barbs basically, so yes, get those cable ties boy!
  14. Shadowed_fury
    21 Nov 2003
    Sorry! Its my first loop! :(
  15. Leeum
    16 Feb 2004
    Was just about to say :lol: No worries, it's for the good of your components :)
  16. Shadowed_fury
    21 Nov 2003
    Oh, and just so everyone knows, that MAG did so well tbh, its really decent on its own.
    I can't imagine how powerful a MCP600 is etc ;)
  17. koola
    koola Minimodder
    11 Jul 2004
    Nice ;)
    Just a bit of uv dye from coolercases and uv cathode and it'll look sweeet!
  18. Shadowed_fury
    21 Nov 2003
    Cable ties now on, eventually :/ They were a bitch to get on lol ;)
    Not sure if I want to add UV dye. There is Zerex in that, about a cap and a bit (but I can't see any purpleness)
  19. Altron
    Altron Minimodder
    12 Dec 2002
    Going Bliss-II style... nice!
    IMO, you should do what DDK never did. Put the front thumbscrews in a drill and file them down so that they are the same outside diameter as a 1/2" copper tube. Then get 4 1/2" copper 90* bends for the corners and 2 1/2" copper T joints for the thumbscrews in the middle. Something like this"
    Code:
    the leftmost line being the front of the case, the right parallel lines being the copper tubing, and the dashes being copper joints covering thumbscrews. It would look really nice, but I keep forgetting to pick up the tubing when I'm at home depot, which is why I haven't done it yet.
  20. Shadowed_fury
    21 Nov 2003
    Nice idea, but I think thats slightly extreme for this ;) I'm going for clean lines :)
