Case Mod - Complete ⭐ Project Tower 900 Taichi Style
Discussion in 'Project Logs' started by Cristianodanna mod, 2 Sep 2017.
  1. Cristianodanna mod
    Cristianodanna mod Minimodder
    16 Dec 2016
    IMG_8388.JPG IMG_8389.JPG IMG_8390.JPG IMG_8391.JPG Hello all, Boys, I will soon mix my next project, which will take place on the Thermaltake tower 900, which will be all in Taichi style, like the motherboard that montero .. It will be made of a double blue and purple loop, there will be some Side panels made by CNC DA Danilo Lettieri and backlit, with many other modifications you will see during the worklog. I attach the photos of the side panels in advance, as I did not plan because I have the ideas quite clear. Good worklog at all;)
    COMPONENT
    CASE THERMALTAKE TOWER 900
    MONTHERBOARD ASROCK Z270 TAICHI
    PROCESSOR INTEL I5 6600K
    VGA ASUS 1070 FOUNDERS EDITION
    RAM Apacer Panther rage 32 gb
    SSD Armor 240 gb
    WATERCOOLING THERMALTAKE
    Sponsor Thermaltake Thanks Andy cheng
    Sponsor Asrock Thanks Chris
    Sponsor Apacer Thanks Julie
  2. Cristianodanna mod
    16 Dec 2016
  3. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    First rule of bit-tech -
    first post of a buildlog has to contain "WORKPROGRESS".
  4. davido_labido
    davido_labido Your Alphacool Contact.
    11 Oct 2013
    Dietec likes this.
  5. Cristianodanna mod
    16 Dec 2016
    Sorry, I seem to have done almost everything
  6. Cristianodanna mod
    16 Dec 2016
    however I update you, led soldering for the box lighting installed on the bottom
  7. Cristianodanna mod
    16 Dec 2016
    This is an approximate rendering of the project.
  8. Cristianodanna mod
    16 Dec 2016
    small upgrade, paint the Thermaltake riing plus fans of Blue Fluo
  9. Cristianodanna mod
    16 Dec 2016
    here are the first two Cut Cnc panels by Danilo Lettieri
    Dietec likes this.
  10. Cristianodanna mod
    16 Dec 2016
    other material for the Mod, Thanks for the support for Thermaltake and Andy
  11. Cristianodanna mod
    16 Dec 2016
    I made the holes with the Dremel on the plexiglass is set the Reservoir
  12. Cristianodanna mod
    16 Dec 2016
    a bit of updates, a blue fluo midplate panel, I installed the internal panels and the reservoirs, and here's the fantastic Z270 taichi. Thanks to Asrock support
  13. Cristianodanna mod
    16 Dec 2016
    hey guys here are other updates
    Dietec likes this.
  14. Cristianodanna mod
    16 Dec 2016
    Hi all guys, I'm almost at the end of the project, I attach some update
  15. galvinD
    galvinD What's a Dremel?
    6 Nov 2017
    Looking great man! Well done
  16. Dietec
    Dietec Minimodder
    2 Oct 2017
    Those backlit cogs look awesome! I'm pumped to see the finished product. Good stuff :)
  17. Cristianodanna mod
    16 Dec 2016
    Thanks you,today's final photos, stay tuned
  18. Cristianodanna mod
    16 Dec 2016
  19. Cristianodanna mod
    16 Dec 2016
    Hi Guys, here are the final photos, hope you like it.
    thank you all my sponsors!
  20. Cristianodanna mod
    16 Dec 2016
