Case Mod - In Progress Project : Toxicity - Completed! 13/11
Discussion in 'Project Logs' started by craigr1982, 9 May 2010.
  1. craigr1982
    craigr1982 What's a Dremel?
    29 Jun 2006
    It's too cold for modding in the garage right now, so I've spent a little time overclocking the Q9450.
    Stock was 2.66Ghz. I've stuck a modest overclock on it for now, although I may push it a little further. It would be nice to have it at 3.6Ghz as I had the Q6600 if not more, but for now it will be fine. Got my RAM at 1066mhz too which is all fine and dandy although I've not overclocked the 275GTX yet, it's on my to do list.
    Checked the Temps with HWMonitor
    Idle -
    CPU - 18C - 22C (across 4 cores)
    GPU - 39C
    Full load - 2x Orthos + Furmark for 30mins
    CPU - 35C - 42C
    GPU - 45C
    Not bad if I do say so myself. Although that is with both side panels off (as they are still in the garage..brrrrrrr). Even with them on I can't see it being a problem tho.
  2. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    I wouldn't trust HWMonitor. 18C-22C when idle seems untrustworthy. How hot is the room?
  3. craigr1982
    29 Jun 2006
    never had any problems with HWMonitor. what else would you suggest?
    Room temp is approx 14C, (said it was cold :brrr:)
  4. Nutman
    21 Oct 2008
    Well, what do your BIOS readings say?
  5. craigr1982
    29 Jun 2006
    BIOS (from cold boot and 10 mins of idle), reports 24.
    Went through a few checks in HWMonitor and my TJMax at 90 instead of 95.:duh:
    Retested and now idling at 20C - 26C across the 4 cores.
    Full load is still at 35C - 42C.
  6. Nutman
    21 Oct 2008
    Those are very neat temps!
    Didn't realise that your ambient temp was 14C!
    However, I've NEVER had a WC loop where my CPU idled below 30C, so you got a keeper there, I'd say.
  7. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Looks great craig! I'm looking forward to seeing the side panels too :thumb:
  8. craigr1982
    29 Jun 2006
    Cheers Nutman and Bill
    I can't believe how long it's been since I was here. Work has really taken it's toll on me..
    I'll have a small update up in the next few days but in the meantime.
    I've been featured on another blog site by Ron Leec (doing the Biohazard Scratchbuild)
    http://www.bluehorsestudios.blogspot.com/
    Woot ! :)
  9. Baekkel
    Baekkel Picky Picture Villian
    17 Jan 2010
    I've went and got the I7-930, bought i together with a pal of mine,
    (and yes, the 950 is just about the same price here in DK )
    They shipped me the 930, and screwed his order, and shipped him a 950.
    and this is where it gets funny.
    His 950, tops out at a stable OC of 3,8Ghz...
    Haven't OC'ed mine yet, but it made us wonder, and then i suddently got very pleased with my decision.
    The 950 apparently has issues getting past the 4Ghz barrier. where as the 930, blasts trough with 4.2 easy..
    kinda makes the 930, more future proof? I don't know..
  10. Nutman
    21 Oct 2008
    Baekkel: How hot is his 950 at 3.8 compared to your 930 at 3.8?
  11. CoolModder2010
    CoolModder2010 What's a Dremel?
    7 Nov 2010
  12. Paradox42
    Paradox42 What's a Dremel?
    15 Oct 2010
    Hey CoolModder- welcome to the forums!
    And that box is his custom watercooling resevoir. He built it from scratch to simulate a waterfall, the fluid cascades down each individual acrylic slot.
  13. Elledan
    Elledan What's a Dremel?
    4 Feb 2009
    It's the coolest reservoir I have seen so far. That's what it is :D
  14. BLUEHORSESTUDIOS
    BLUEHORSESTUDIOS I haven't lost a finger yet!
    19 Apr 2010
    looking good Craig, Im just so in love with this build!
  15. Baekkel
    17 Jan 2010
    Honestly, no idea...
    He's using a True black something or other, and i'm running stock..
    Just got a half deck of 1600Mhz Dom-GT's (7-7-7-20) to fill in for the single 2gb HyperX i could borrow from a friend.
    So i'll see what that does to the machine, and hear him on the temps of his 3.8 clock..
    It would be kinda non relative though, since we're in two very different environments.
    His is sitting in a fairly small room with fair insulation making ambient fairly high.
    Mine is sitting in a fairly uninsulated room in our third floor apartment..
    (i got the advantage me thinks..)
  16. CoolModder2010
    7 Nov 2010
    Hey Paradox, thanks for the welcome. Thanks for telling me what that box is, that thing is cool. I guess Im just curious to know if it is just a visual thing or if it really aids in cooling. But again thanks for the welcome, hope to get my build going here soon. Cheers
    :thumb:
  17. craigr1982
    29 Jun 2006
    Coolmodder2010 - welcome to the forums and thanks for the comments :) To be honest I can't imagine it does much for cooling, although I'd like to think that having the water moving more than other more conventional reservoirs increases the cooling capability..Even if it doesn't it looks cool so I'm not fussed. :thumb:
    Paradox - Cheers for doing the honours :) I'm not on here as much as I'd like just now.
    Elledan - Glad you like it :thumb:
    Bluehorsestudios - Cheers :)
    So another new update based solely on the side panels. It's a bit shorter than my usual videos, but then most of it is covering old ground, cutting and painting etc.
    Now that the side panels are finished I just need to get some good photos of it completed and running.
    With the weather closing in it makes it difficult to take photos outside and I don't really have the space for a full on photo booth in the house..
    Have to see how it comes out.
  18. CoolModder2010
    7 Nov 2010
    Hey Craig, thanks for the welcome as well. Yeah weather or not it actually dose help or not, it does look nice. And I would seem to think that it would help some. :thumb: Cheers
  19. craigr1982
    29 Jun 2006
    COMPLETED!!
    Yes it's done, and here are the photos to prove it :)
    Also a video showing the case "in the flesh" so to speak. Don't forget it's available in 720p as with all the other worklog videos.
    Here are the specs.
    Toxicity -
    Asus P5KE-WiFi
    Intel Q9450 @ 3.52Ghz
    XFX GTX275
    4Gb Kingston 1066 DDR2
    60Gb OCZ Vertex 2 SSD
    2x 1Tb HDD
    G15 Keyboard
    G9x Laser Mouse
    Watercooled with
    D-Tek Fusion V2 block
    EK GTX275 waterblock
    Swiftech MCP655 (Laing D5 Vario)
    Custom Reservoir
    Waynio likes this.
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    Ahh, phew I was thinking the awesome res would be hidden, that part really needed a showing :). +rep for completion mate :thumb:.
