Scratch Build – In Progress Project: Tri-Box supported by DangerDen and MNPCTECH
Discussion in 'Project Logs' started by Kylevdm, 14 Jun 2008.
  1. ry@n
    ry@n Minimodder
    31 Aug 2005
    Everything I was about to say has already been said by the looks of it lol, but ye the curves looks awesome, simple and clean.
  2. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    Thanks, I am currently on daytona beach, but it is raining... so there may be some more idea updates before long.
    Thanks, I like it too :D. I am love stuff that is minimalistic, well everything. I am ordering samples of both LEDs and acrylic to see how many LEDs I will need etc. I am also busy designing a all the circuits in the case so that even if I don't take the DVD box all the fans and one of the LED circuits will work, as this is one less thing to drag to LANs :p
  3. Kylevdm
    4 Oct 2007
    oops, I missed your comment it was on page 2 :wallbash:, but yer thanks for the comment, I now just need to pull off the build, but with the help of all of you guys (and girls :p) I am sure I will get through it :lol:
  4. Kylevdm
    4 Oct 2007
    Hello all,
    I would like to thanks the first sponsor of TriBox, DangerDen.
  5. ComputerKing
    8 Sep 2006
    WOOOOOOOOOOOOOOOOOOOOOOT :clap:
    Well done ;) the ball played with you this time :) DangerDen
  6. Kylevdm
    4 Oct 2007
    Thanks ComputerKing, hopefully the help from DangerDen will enable me to finish this mod quicker for you and me to enjoy
  7. ComputerKing
    8 Sep 2006
    Can't Wait. So tell me what they are giving you? :geek:
  8. Kylevdm
    4 Oct 2007
    Due to this being my first scratch build they cannot give me components but they have given me 30% off there store.
  9. ComputerKing
    8 Sep 2006
    Not bad at all :) Take care of your self and :rock: ON
  10. Kylevdm
    4 Oct 2007
    well expect an update next week because I leave Canada tomorrow. I will be going to get the MDF for the sidepanels and ordering the alu. I will also order acrylic samples. I would have done all this today but I had to leave my bank card at home, parents rule dont ask lol.
  11. Stonewall78
    Stonewall78 What's a Dremel?
    21 Oct 2005
    Cool a mod from the future (Started - 6/14/09) :p
    Looking good so far, as for the wood warp you can try getting that portion wet then screwing it down to straighten it out.
  12. Kylevdm
    4 Oct 2007
    lol, thanks the warp makes it look cool in my opinion gives it character lol
  13. Kylevdm
    4 Oct 2007
    Hello all,
    I received my acrylic samples but my camera is broken... so I cant get any pics of them. Due to the white frosted acrylic defusing light so well I need more LEDs than I can put in with my current design. So I am looking at changing the design slightly.
    I may be adding an extra layer of aluminium to the foot/ sticky out bit... So it will be alu-acrylic-alu. Instead of the original alu-acrylic. This will allow me to place lots more LEDs in the acrylic. The acrylic in the centre is just there to support the alu but it may not be needed.
    comments very welcome
  14. karolis
    karolis Code Monkey
    10 Mar 2008
    i remember seeing this tri-box concept in modding forum a few months back, it's good to see you're finally making it.
    this is going to look great.
    about alu-acrylic-alu, the extra aluminum layer will definitely help direct the light towards the edges and prevent lighting the box, but i'd say do a little experiment and see which way looks better :)
  15. The boy 4rm oz
    10 Apr 2008
    Nice design.
  16. Kylevdm
    4 Oct 2007
    I know that the alu-acrylic will look better but I do not have the time or money to try and implant 3mm LEDs in side 5mm acrylic there is too big a chance that I will mess it up and buying extra aluminium is cheaper then re buying acrylic... :sigh:
    Thanks :rock:
  17. Kylevdm
    4 Oct 2007
    Hello all it has been a long time since an update but I had a free afternoon so got modding... I have painted the fingerguards for the HDD and PSU vent, re-cut the backpanel as the I/O tray was the wrong way round, and Tribox has sidepanel!!!!!!!
    I will let the pictures talk now :p
    The full panel window. The mdf is going to be screwed and filled in. However the acrylic is going to slid right out from the back effectively making the window the sidepanel.
    The back panel ready for the jigsaw. I am just checking everything fits and I am happy with the design before I cut...
    The other sidepanel. There is a small lip which is only there because I am making the motherboard tray out of acrylic which is yet to arrive...
    any way I will get you more pictures tomorrow as the camera I am using does not like my memory stick so I can only take 4 picture at a time...
    Questions and comments are always welcome
  18. Jipa
    5 Feb 2004
    Awwh got to hate working with wood for that! I tried to make a wooden case once and that was always the issue no. 1. MDF board seems tempting as it doesn't warp, but then again, it looks like crap.
    Good luck with the project, interesting design!
  19. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    NO MDF :p Really, stuff works great, but it isnt wood.
    Just buy some wood which isnt warped.
  20. Kylevdm
    4 Oct 2007
    As I have said before it adds character... as for not buying warped wood it is not really an option in Scotland everything warps....
